Wireless
8659 Discussions
4965AGN on Windows 7 with ProSet GUI Utility?
My question is essentially whether the ProSet connection utility found in the 4965AGN drivers under Windows XP (and that found in the enterprise package for the newer 5000 series under Windows 7) will ever be available for the 4965AGN card on Windows 7. If not, would there be a way to "hack" the driver into working with the utility intended for the 5000 series? It doesn't have to be perfect, I just need support for a WPA2 Enterprise/AES network. Any help appreciated.
Proset GUI utility won't be available for 4965 on Win7. You don't this Proset to connect to WPA2 Enterprise/AES network. This is already supported via Windows native connection manager.
