Wireless
8664 Discussions
6 GHz Wifi with AX210
SK85
Hi All,
I am facing similar issue mentioned in the thread -
https://community.intel.com/t5/Wireless/6-GHz-Wifi-with-AX210-and-Ubuntu-20-04/td-p/1318011
The 6GHz band is now open in Germany. When we will have support for 6GHz?
The solution given in above thread is not an option for me.
Warm regards,
SK85
ecsv
The current regulatory information (generated from channel control profile map which the firmware intel firmware uses) for Germany is shown in https://lore.kernel.org/all/dd512568-9d9f-289a-bc7b-9b6dfc1c0c8a@simonwunderlich.de/ under"phy#0 (self-managed)". And some more comments can be found in https://lore.kernel.org/all/6520824.1yIjQniEF0@sven-l14/
The test results with iwlwifi-ty-a0-gf-a0-67.ucode (and the respective iwlwifi-ty-a0-gf-a0.pnvm) and linux-next 20211101 can be found at https://lore.kernel.org/all/2019679.eXh7N0oMcK@ripper/ (spoiler: "not working"). Before someone asks, linux-next 20211111 was also used at a later point with the same results.
The reason for buying these cards were the advertised support for 6GHz and the effort of your Linux kernel team (Johannes Berg, Luca Coelho, ...) to get support for it in the upstream kernel. But it doesn't help us when the firmware is not reporting these channels as supported in a response to a MCC_UPDATE_CMD command from iwl_mvm_get_regdomain (via iwl_mvm_update_mcc + iwl_parse_nvm_mcc_info) - even when it should be allowed  according to the documents shown as justification by https://git.kernel.org/pub/scm/linux/kernel/git/sforshee/wireless-regdb.git/commit/?id=cdf854d2ddca01bf126ac138a8ee3e5d6320086f
nEtwORk_EnGineer
I'm experiencing the same issue, so it seems like Intel is still not really aware of this situation.
Hope bumping this thread helps to get an intel engineer to confirm the issue, since all existing threads portray the same picture:
INTEL AX210 does NOT support 6Ghz in Germany, neither with Win10 (registry shows that AX210 is capable of 6Ghz and MS engineers confirmed win10 support), nor Win11 or the newest available linux kernels.
So, Intel please get some engineers attention to the issue!
(Like said before, all other threads show the same, or only got some queer suggestions and closed, but not an actual engineers answer).
INTEL plz get someone with a brain working on the issue!!
ecsv
Seems like this was fixed with 22.100.1. The firmware for it is currently proposed to linux-firmware but can already be downloaded from the iwlwifi fork of the linux-firmware repository. If you use these firmware version with at least the intel kernel development tree a2263adab8bf722b5a4c981d8fc1b7c821820240 then you get following after a scan (in germany):
$ iw reg get
phy#1 (self-managed)
country DE: DFS-UNSET
        (2402 - 2437 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
        (2422 - 2462 @ 40), (6, 22), (N/A), AUTO-BW, NO-80MHZ, NO-160MHZ
        (2447 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
        (5170 - 5190 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (5190 - 5210 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (5210 - 5230 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (5230 - 5250 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (5250 - 5270 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
        (5270 - 5290 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
        (5290 - 5310 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
        (5310 - 5330 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
        (5490 - 5510 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
        (5510 - 5530 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
        (5530 - 5550 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
        (5550 - 5570 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
        (5570 - 5590 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
        (5590 - 5610 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
        (5610 - 5630 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
        (5630 - 5650 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
        (5650 - 5670 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, PASSIVE-SCAN
        (5670 - 5690 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
        (5690 - 5710 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, PASSIVE-SCAN
        (5735 - 5755 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ
        (5755 - 5775 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ
        (5775 - 5795 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ
        (5795 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ
        (5815 - 5835 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
        (5945 - 5965 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (5965 - 5985 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (5985 - 6005 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (6005 - 6025 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (6025 - 6045 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (6045 - 6065 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (6065 - 6085 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (6085 - 6105 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (6105 - 6125 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (6125 - 6145 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (6145 - 6165 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (6165 - 6185 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (6185 - 6205 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (6205 - 6225 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (6225 - 6245 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (6245 - 6265 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (6265 - 6285 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (6285 - 6305 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (6305 - 6325 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (6325 - 6345 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (6345 - 6365 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (6365 - 6385 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (6385 - 6405 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (6405 - 6425 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
$ iw phy1 channels
Band 1:
	* 2412 MHz [1]
	  Maximum TX power: 22.0 dBm
	  Channel widths: 20MHz HT40+
	* 2417 MHz [2]
	* 2422 MHz [3]
	* 2427 MHz [4]
	* 2432 MHz [5]
	  Channel widths: 20MHz HT40- HT40+
	* 2437 MHz [6]
	* 2442 MHz [7]
	* 2447 MHz [8]
	* 2452 MHz [9]
	* 2457 MHz [10]
	* 2462 MHz [11]
	* 2467 MHz [12]
	* 2472 MHz [13]
	* 2484 MHz [14] (disabled)
Band 2:
	* 5180 MHz [36]
	  No IR
	  Channel widths: 20MHz HT40+ VHT80 VHT160
	* 5200 MHz [40]
	  No IR
	  Channel widths: 20MHz HT40- VHT80 VHT160
	* 5220 MHz [44]
	  No IR
	* 5240 MHz [48]
	  No IR
	* 5260 MHz [52]
	  No IR
	  Radar detection
	  DFS state: usable (for 714 sec)
	  DFS CAC time: 60000 ms
	* 5280 MHz [56]
	  No IR
	  Radar detection
	* 5300 MHz [60]
	  No IR
	  Radar detection
	* 5320 MHz [64]
	  No IR
	  Radar detection
	* 5340 MHz [68] (disabled)
	* 5360 MHz [72] (disabled)
	* 5380 MHz [76] (disabled)
	* 5400 MHz [80] (disabled)
	* 5420 MHz [84] (disabled)
	* 5440 MHz [88] (disabled)
	* 5460 MHz [92] (disabled)
	* 5480 MHz [96] (disabled)
	* 5500 MHz [100]
	  No IR
	  Radar detection
	* 5520 MHz [104]
	  No IR
	  Radar detection
	* 5540 MHz [108]
	  No IR
	  Radar detection
	* 5560 MHz [112]
	  No IR
	  Radar detection
	* 5580 MHz [116]
	  No IR
	  Radar detection
	* 5600 MHz [120]
	  No IR
	  Radar detection
	* 5620 MHz [124]
	  No IR
	  Radar detection
	* 5640 MHz [128]
	  No IR
	  Radar detection
	* 5660 MHz [132]
	  No IR
	  Radar detection
	* 5680 MHz [136]
	  No IR
	  Radar detection
	* 5700 MHz [140]
	  No IR
	  Radar detection
	  Channel widths: 20MHz VHT80
	* 5720 MHz [144] (disabled)
	* 5745 MHz [149]
	* 5765 MHz [153]
	* 5785 MHz [157]
	* 5805 MHz [161]
	* 5825 MHz [165]
	* 5845 MHz [169] (disabled)
	* 5865 MHz [173] (disabled)
	* 5885 MHz [177] (disabled)
	* 5905 MHz [181] (disabled)
Band 4:
	* 5955 MHz [1]
	  No IR
	* 5975 MHz [5]
	  No IR
	* 5995 MHz [9]
	  No IR
	* 6015 MHz [13]
	  No IR
	* 6035 MHz [17]
	  No IR
	* 6055 MHz [21]
	  No IR
	* 6075 MHz [25]
	  No IR
	* 6095 MHz [29]
	  No IR
	* 6115 MHz [33]
	  No IR
	* 6135 MHz [37]
	  No IR
	* 6155 MHz [41]
	  No IR
	* 6175 MHz [45]
	  No IR
	* 6195 MHz [49]
	  No IR
	* 6215 MHz [53]
	  No IR
	* 6235 MHz [57]
	  No IR
	* 6255 MHz [61]
	  No IR
	* 6275 MHz [65]
	  No IR
	* 6295 MHz [69]
	  No IR
	* 6315 MHz [73]
	  No IR
	* 6335 MHz [77]
	  No IR
	* 6355 MHz [81]
	  No IR
	* 6375 MHz [85]
	  No IR
	* 6395 MHz [89]
	  No IR
	* 6415 MHz [93]
	  No IR
	* 6435 MHz [97] (disabled)
	* 6455 MHz [101] (disabled)
	* 6475 MHz [105] (disabled)
	* 6495 MHz [109] (disabled)
	* 6515 MHz [113] (disabled)
	* 6535 MHz [117] (disabled)
	* 6555 MHz [121] (disabled)
	* 6575 MHz [125] (disabled)
	* 6595 MHz [129] (disabled)
	* 6615 MHz [133] (disabled)
	* 6635 MHz [137] (disabled)
	* 6655 MHz [141] (disabled)
	* 6675 MHz [145] (disabled)
	* 6695 MHz [149] (disabled)
	* 6715 MHz [153] (disabled)
	* 6735 MHz [157] (disabled)
	* 6755 MHz [161] (disabled)
	* 6775 MHz [165] (disabled)
	* 6795 MHz [169] (disabled)
	* 6815 MHz [173] (disabled)
	* 6835 MHz [177] (disabled)
	* 6855 MHz [181] (disabled)
	* 6875 MHz [185] (disabled)
	* 6895 MHz [189] (disabled)
	* 6915 MHz [193] (disabled)
	* 6935 MHz [197] (disabled)
	* 6955 MHz [201] (disabled)
	* 6975 MHz [205] (disabled)
	* 6995 MHz [209] (disabled)
	* 7015 MHz [213] (disabled)
	* 7035 MHz [217] (disabled)
	* 7055 MHz [221] (disabled)
	* 7075 MHz [225] (disabled)
	* 7095 MHz [229] (disabled)
	* 7115 MHz [233] (disabled)
This looks really promising. Also connecting to a 6GHz AP seemed to work for me:
$ iw dev wlp1s0 link
Connected to 00:03:7f:12:59:59 (on wlp1s0)
        SSID: Maverick6g
        freq: 6115
        RX: 2259 bytes (23 packets)
        TX: 1637 bytes (15 packets)
        signal: -50 dBm
        rx bitrate: 313.4 MBit/s 80MHz HE-MCS 6 HE-NSS 1 HE-GI 0 HE-DCM 0
        tx bitrate: 245.0 MBit/s 80MHz HE-MCS 3 HE-NSS 2 HE-GI 2 HE-DCM 0
        bss flags:      short-slot-time
        dtim period:    2
        beacon int:     100
$ ping ff02::1%wlp1s0 -c 5
PING ff02::1%wlp1s0(ff02::1%wlp1s0) 56 data bytes
64 bytes from fe80::feb3:bcff:fef2:698f%wlp1s0: icmp_seq=1 ttl=64 time=0.183 ms
64 bytes from fe80::203:7fff:fe0f:386b%wlp1s0: icmp_seq=1 ttl=64 time=110 ms
64 bytes from fe80::feb3:bcff:fef2:698f%wlp1s0: icmp_seq=2 ttl=64 time=0.214 ms
64 bytes from fe80::203:7fff:fe0f:386b%wlp1s0: icmp_seq=2 ttl=64 time=9.80 ms
64 bytes from fe80::feb3:bcff:fef2:698f%wlp1s0: icmp_seq=3 ttl=64 time=0.214 ms
64 bytes from fe80::203:7fff:fe0f:386b%wlp1s0: icmp_seq=3 ttl=64 time=40.8 ms
64 bytes from fe80::feb3:bcff:fef2:698f%wlp1s0: icmp_seq=4 ttl=64 time=0.213 ms
64 bytes from fe80::203:7fff:fe0f:386b%wlp1s0: icmp_seq=4 ttl=64 time=71.0 ms
64 bytes from fe80::feb3:bcff:fef2:698f%wlp1s0: icmp_seq=5 ttl=64 time=0.212 ms
--- ff02::1%wlp1s0 ping statistics ---
5 packets transmitted, 5 received, +4 duplicates, 0% packet loss, time 4006ms
rtt min/avg/max/mdev = 0.183/25.836/109.888/37.814 ms
