Please help.
I have a new Dell 5000 14" laptop computer. The computer has windows 8.1 and an AC-3160
Dual Band wireless card. I have Verizon
FIOS. Right away I noticed a Wi-Fi speed
and strength issue. The bar display
would quickly go back and forth between 1-2 bars and full bars. I also noticed slow connection speeds. I updated the driver via the Intel site to the
latest available.
If I am within about 5 feet of the router the speeds are
25-40 MPs. When I am farther away than
that the speed drops to 1-5 MPs. I have
sat at our kitchen table, which is on the same floor and about 20 feet from the
router, with this computer and 2 other laptop computers and the other computers
get 25-40 MPs but this one only gets 1-5 MPs from the exact same location.
In looking on the internet I see that with the AC-3160,
other owners are seeing the same condition.
This is not an acceptable situation to have to be within 5 feet of the
router to achieve appropriate speeds. I
have called Dell but this does not seem to be their issue.
What do I need to do to get this Intel Wi-Fi card working as
advertised?
Thank you.
Hi hkyfn, I empathize with you since this is, of course, a behavior we would not expect from a brand new system.
This is very likely a problem with the antennas considering such poor signal strength when your system is very close to the router.
I suggest using a tool like inSSIDer 3* to monitor your signal strength. It will be good if you get between 0 to -30 dBm when near to the router but something over -70 dBm is not acceptable at 5 feet.
If indeed it is an antenna issue I recommend you contacting DELL* again.
![](/skins/images/DC0E2679F7049B943291D1ED082A478E/responsive_peak/images/icon_anonymous_message.png)
