Wireless
9021 Discussions
AC 7260 Bluetooth problem
IAtak
I have an Acer M3-581TG laptop, where I replaced the original Atheros WiFi/Bluetooth PCIe unit with the Intel AC7260 HMW. I have removed the original drivers and software then installed Intel Proset/Wireless s/w and the BT_17.1.1406.01_s64 drivers. I even used the command "setup.exe LPUSBHUBWA=TRUE" as suggested in another post. However bluetooth does not appear on the Windows Device Manager list.
The WiFi works fine
Can you suggest how I can get the Bluetooth to work?
Jose_H_Intel1
Does it show a Generic Bluetooth adapter?
It is possible that your computer uses a software or hardware switch to enable the Bluetooth* feature.
http://www.intel.com/support/wireless/wlan/sb/CS-034936.htm Intel® Wi-Fi Products — Bluetooth® Technology Management and Configuration
http://www.intel.com/support/wireless/wlan/sb/cs-032541.htm Intel® Wi-Fi Products — How to Install Intel® PROSet/Wireless Software for Bluetooth® Technology
However, we highly recommend asking the http://www.intel.com/support/oems.htm system manufacturer in order to obtain a list of validated wireless adapter models that are compatible with your system and the proper means to accomplish this hardware integration.
http://www.intel.com/support/wireless/sb/CS-006192.htm Wireless Networking — Installation Error when Installing or Swapping Intel Wireless Adapters
http://www.intel.com/support/wireless/wlan/sb/CS-011644.htm Intel® Wi-Fi Products — Regulatory Information Regarding Hardware Installation or Upgrade
IAtak
Thanks Joe
Bluetooth does not appear at all.
when I install a USB bluetooth dongle it appears and generic MS drivers are installed. When I remove the dongle the bluetooth devices disappear. This tells me the Intel bluetooth device is not been recognised!! Is there anything I can do to get Windows 7 to recognise the bluetooth h/w?
Jose_H_Intel1
I understood that you have removed the preinstalled combo (WiFi+Bluetooth*) adapter.
It is possible the BIOS could be designed to accept certain wireless adapter models only; hence the suggestion in the second paragraph above.
