Wireless
8622 Discussions
AC 8265 Driver 20.30.1.2 WIFI speed drops fwhen connecting to VPN
NWill3
I have an ASUS vivobook pro and on my home network I get WIFI speed of 80 mbps which is right for my network. when I connect to my company VPN my speed drops to 1-2 mbps. I have a USB wifi Stick and when I connect it I do not lose any performance when I connect to my VPN
Hello n8,
Thanks for posting.
Please notice that we don't support issues related to VPN as these applications replace our drivers.
However, in order to confirm if there's something we can help you with please provide us with the following information:
- VPN software used.
- Router model.
- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600 Intel® System Support Utility file. Please scan everything and save the file in your system.
- WLAN Interface information before and after connecting to VPN:
  1. Open a command prompt (CMD) as administrator.
  2. Type netsh wlan show interfaces and press Enter.
  3. Capture the information before and after VPN connection.
Please attach the resulting files to your next reply.
Eugenio F.
NWill3
- VPN Software: Sonicwall Global VPN Client
-router hitron 2250 shw (shaw cable provided)
Hello n8,
We haven't heard from you since the creation of this thread.
Please let us know if there's anything else we can do for you.
Eugenio F.
NWill3
I haven't had a chance to try the steps you suggested yet.
Hello n8,
Thanks for your reply.
No hurries, we'll be waiting for your reply if you ever have the chance to gather the information.
Eugenio F.
Hello n8,
Thanks for the information.
Reading online, other users have reported similar issues while using Sonicwall Global VPN*. There's one that offers a solution:
- https://community.spiceworks.com/topic/2096371-global-vpn-client-greatly-slows-internet-when-connected-and-not-connected Spiceworks* Communities - Global VPN Client greatly slows internet
Even though the issue seems to be at layer 3 and linked to the VPN client, please try a driver only installation just to discard this option:
1. Download and extract our latest IT Admin driver package for your adapter: https://downloadcenter.intel.com/download/27485 WiFi_20.30.1_Driver64_Win10.zip
2. Under Programs and Features in the Control Panel, or Apps & Features in Windows* Settings, uninstall any instance of the "Intel® PROSet/Wireless Software." When prompted, choose to "discard settings."
3. Go to the Device Manager > Network Adapters > Right click on your Intel(R) Dual Band Wireless-AC 8265 and uninstall it. Make sure to mark the option to "Delete the driver software for this device."
4. Clear out your temporary files: Press the Windows* Key + R to open the run box. Type Cleanmgr.exe and press OK. Here you will need to make sure Temporary Files are checked, you may uncheck everything else, then press OK.
5. Reboot your computer.
6. Go to the Device Manager > Network Adapters > Right click on your Intel(R) Dual Band Wireless-AC 8265 again, this time choose to "Update driver software..." > Select the option to "Locate and install driver software manually." Here you will need to direct the wizard to the location where you extracted the IT Admin package back in step one.
Please https://www.sonicwall.com/en-us/support/knowledge-base/170505704468100 reinstall the VPN client as well. If the issue persists, please contact https://www.sonicwall.com/en-us/support/support-services Sonicwall* support for further assistance.
NOTE: Links to third party sites are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Let us know if there's anything else we can do for you.
Eugenio F.
