Wireless
9018 Discussions
AC-9462 Connection Problem
1morerep
I have a connection problem with my Wireless AC 9462 card.  I can see and connect to networks but I get "Connected - No Internet".  I have several other computers and all are able to connect and display content regardless of the network chosen.
I have uninstalled the Wireless adapter card and its driver.  I have downloaded the latest driver for the adapter and installed.
Attached is my detailed system support utility scan.
Sebastian_M_Intel
Hello 1morerep,
Thank you for posting on the Intel® communities.
1. Were you able to have your wireless connection in a normal/expected performance before? If yes, did you make any changes before this behavior started?
2. Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
3. Are you having issues with Wi-Fi, Bluetooth, or both?
4. Try running the following command in the cmd and reconnect back to the network:
  • From Windows Start, search for cmd
  • Right-click on Command Prompt and click Run as administrator
  • In the console, type the following command: ipconfig/flushdns. If the command was successful, you will see the message "Successfully flushed the DNS Resolver Cache".
Sebastian M.
Intel Customer Support Technician.
1morerep
Yes.  The system is back to normal....temporarily.
I tried all the various options dealing with the DNS (ipconfig, dnsflush, install/reinstall driver, etc.).  It is not a problem with the computer or its network adapter but rather with the crappy Xfinity modem.  I am able to connect with my phones hotspot, etc.  It also kicked off my wife's apple.  Not sure what to do with it as Xfinity support is worthless.
Sebastian_M_Intel
Hello 1morerep,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Sebastian M.
Sebastian_M_Intel
Hello 1morerep,
Thank you for the update on this matter, it is good to hear that at least you found the cause of this problem.
In that case, I hope you can get further support from Xfinity* in regard to this behavior since as you mentioned, is something not related to your system or wireless adapter.
We will proceed to close this thread, however; if you need any additional information, please submit a new question as this thread will no longer be monitored
Sebastian M.
