Wireless
AC7260
lt6
Does my ac7260 able to run on windows server 2016 64-bit without wired network?What driver should me choose?Thankyou
Marc-Elsen
New Contributor II
  - @lt6                That should  be possible :  you must first enable the Wireless Lan feature  Service feature using :
                                                Install-WindowsFeature Wireless-Networking
                             After that, Windows Server will show the Wi‑Fi interface once the correct driver is installed.
                             You can find the driver here :
                                    https://onedrive.live.com/?redeem=aHR0cHM6Ly8xZHJ2Lm1zL2YvcyFBdGFjWkJVMDRtby1qLXRRMzRCZFNEdjZ5MUJGc2c%5FZT03Z241MFQ&id=3E6AE23415649CD6%21259536&cid=3E6AE23415649CD6
   M.
juyujayav
For Windows Server 2016, it's best to use the Windows 10 drivers, as they are often compatible. You can download the latest drivers directly from Intel's official website or through the Intel Driver & Support Assistant, which can help identify the appropriate driver for your device.
