Wireless
8640 Discussions
[AC8265NGW] Request and question about manually configuring the WiFi and BT settings
HCKim
Hi all,
We are currently in the process of developing robot using the AC8265NGW module.
In order to meet the certification requirements, we need guidance on manually configuring the WiFi and BT settings for the necessary tests.
The specific configurations we require are as follows:
- Select of Tx and Rx modes
- Select of Channel(frequency) and Data rate(standard, bandwidth and etc..)
 -> ex) Continuous Tx mode @2.4GHz band/1CH(2412MHz)/20MHz BW/Default Tx power level
We are aware the these settings cannot be controlled using regular driver.
Therefore, we would appreciate information on the available manual control methods for the AC8265NGW module, including any specific tools or commands that can be used for this purpose.
HC.
Carlos_L_Intel
Hi @HCKim,
 Thank you for posting on the Intel® communities. Let me check this internally and I will post back with more details soon.
Carlos L.
HCKim
Hi @Carlos_L_Intel
Thank you for your prompt response.
We eagerly anticipate your reply.
HC.
Carlos_L_Intel
Hi @HCKim
Thank you for your time. I would like to let you know that we have a specific forum for this kind of issues and product, it is called the Intel Developer Zone. There you will receive the appropriate support on this and other concern you may have related to this product.
Here you will find the links to access to the website and the community forums:
- https://software.intel.com/content/www/us/en/develop/home.html
- https://community.intel.com/t5/Software/ct-p/software-products
Please keep in mind that this thread will no longer be monitored by Intel.
Carlos L.
