Wireless
告知
8581 ディスカッション
AX101 Linux Debian Driver WiFi driver No config found for PCI dev 7af0/0244
WaCe
初心者
3,311件の閲覧回数
Please help the Inte WiFi 6 AX101
kernel version
6.1.0-25-amd64
# dmesg | grep iwlwifi
[    2.597503] Intel(R) Wireless WiFi driver for Linux
[    2.597683] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    2.601668] perf uncore: Cannot find matched IMC device.
[    2.601716] perf uncore: Cannot find matched IMC device.
[    2.601762] perf uncore: Cannot find matched IMC device.
[    2.601808] perf uncore: Cannot find matched IMC device.
[    2.604016] iwlwifi: No config found for PCI dev 7af0/0244, rev=0x430, rfid=0x10c000
[    2.604047] iwlwifi: probe of 0000:00:14.3 failed with error -22
# lspci -kvnn | sed -n '/Network/,/^$/ p'
00:14.3 Network controller [0280]: Intel Corporation Alder Lake-S PCH CNVi WiFi [8086:7af0] (rev 11)
       DeviceName: Onboard - Ethernet
       Subsystem: Intel Corporation Alder Lake-S PCH CNVi WiFi [8086:0244]
       Flags: fast devsel, IRQ 18
       Memory at 9341c000 (64-bit, non-prefetchable) [size=16K]
       Capabilities: [c8] Power Management version 3
       Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
       Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
       Capabilities: [80] MSI-X: Enable- Count=16 Masked-
       Capabilities: [100] Latency Tolerance Reporting
       Capabilities: [164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?>
       Kernel modules: iwlwifi
Bluetooth is working normal.
have download latest linux-firmware-20240811  and copy intel folder to  and iwlwifi-* /lib/firmware/intel/lib/firmware/
0 件の賞賛
12 返答(返信)
JedG_Intel
モデレーター
3,003件の閲覧回数
Hello WaCe,
Could you please elaborate or describe the issue you are having? Please generate System Support Utility (SSU) report to have a better understanding of your system configuration and component. Please follow instructions here and send the report - Intel® System Support Utility for the Linux* Operating System
I hope to hear from you soon!
Jed G.
WaCe
初心者
2,966件の閲覧回数
Hello Jed G.,
Here is the generated file from SSU.
I read the generated txt file, there is no component about the WiFi Component, the WiFi is run normally in Windows.
Best regards
JedG_Intel
モデレーター
2,952件の閲覧回数
Hello WaCe,
I appreciate you for sharing the SSU logs. Please also share the information below for me to address this properly.
1. Was this working fine before?
2. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
3. Did you make recent changes to the system?
I hope to hear from you soon.
Jed G.
WaCe
初心者
2,942件の閲覧回数
Hello Jed G.,
No, this is new system.
This is the original adapter that came pre-installed on the motherboard brand = Maxsun type = H610M 666 WIFI6 link to product = https://www.maxsun.com/products/ms-h610m-666-wifi6
No.
Best regards
JedG_Intel
モデレーター
2,926件の閲覧回数
Hello WaCe,
I appreciate this information. I'll be conducting an investigation with regards to this matter and I'll get back in touch as soon as possible.
Jed G.
JedG_Intel
モデレーター
2,918件の閲覧回数
Hi WaCe,
I'm just following up to gather more information for the investigation.  Please see below.
- Is this a laptop or desktop system?
Additionally, please share the output of the following.
1. $ hostnamectl
2. # lspci​
3. # modinfo iwlwifi​
I'll be waiting for your response.
Jed G.
WaCe
初心者
2,906件の閲覧回数
Hi Jed G.,
It is a desktop system.
Best Regards
JedG_Intel
モデレーター
2,883件の閲覧回数
Hi WaCe,
Thank you for this information. I'll continue to investigate this matter and I'll give you an update as soon as I can.
Jed G.
JedG_Intel
モデレーター
2,800件の閲覧回数
Hello WaCe,
I'm reaching out to give you an update. Based on the investigation, both logs provided do not detect AX101 but shows Qualcomm Atheros AR9485 Wireless Network Adapter and error Module iwlwifi not found. Please check with desktop OEM to see if this system is compatible with 2 wireless cards and Linux OS. Additionally, Kernel version 6.1.0-25 is not the latest. Latest stable kernel version is 6.12 https://www.kernel.org/.
Should you have other questions or concerns, please let me know.
Jed G.
RobbieR_Intel
モデレーター
2,725件の閲覧回数
Hello WaCe,
I would like to check if you were able to see the information my colleague has posted. Your feedback at your earliest convenience would be greatly appreciated so we can move forward with resolving this matter.
Robbie R.
WaCe
初心者
2,687件の閲覧回数
Hello Robbie R.,
I do not know what to do next, since I cannot found documentation about Debian is support 2 WiFi card or not. Thank you Jed G. for the help.
Thank you Robbie R. for the follow up, while I still can use the Atheros WiFi, and I just want to post the No Config message while booting up Debian for the forum to know, and we can close this thread.
Best Regards
JedG_Intel
モデレーター
2,646件の閲覧回数
Hello WaCe,
Thank you for the update. Since you confirmed that we can close this thread, I'll proceed to do so. Should you have other questions or concerns, please create a new thread as this thread will no longer be monitored.
Jed G.
返信
