Wireless
8789 Discussions
AX200 Relocating Internal laptop wifi/bt antenna
WirelessPenguin20
MH4 connector leads were damaged. I have a replacement antenna, but would rather not disassemble the display to replace it.
If I were to relocate the #1 & #2 antenna, would it be safe to do so? Both for the laptops internal components (concerned about interference) and my exposure to RF energy?
I was considering putting it on the bottom of the chassis, nearer to the vents at the back of the laptop.
If I must, I will take the display apart..but would rather not. It isn't the display removal that concerns me-it's that the display itself is taped/glued to the display 'case'.
Jean_Intel
Hello WirelessPenguin20
The ideal to answer your query would be to confirm it with your motherboard manufacturer. All systems are different and vary from one model to another. OEM would have a much better understanding of your systems and can provide a much more appropriate answer to your questions.
I hope you find his information helpful.
Jean O.
Jean_Intel
Hello WirelessPenguin20.
I hope you are doing fine.
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
