After recently upgrading to Debian 12 from Debian 11, my Wifi has been disconnecting frequently.
I am using an AX200 (lspci shows: "Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)") and running dmesg after a wifi disconnect shows the following error messages repeated dozens of times.
[ 2971.238970] iwlwifi 0000:04:00.0: Queue 2 is stuck 0 2 [ 2971.239108] iwlwifi 0000:04:00.0: Microcode SW error detected. Restarting 0x0. [ 2971.239229] iwlwifi 0000:04:00.0: Start IWL Error Log Dump: [ 2971.239233] iwlwifi 0000:04:00.0: Transport status: 0x0000004A, valid: 6 [ 2971.239237] iwlwifi 0000:04:00.0: Loaded firmware version: 72.daa05125.0 cc-a0-72.ucode [ 2971.239241] iwlwifi 0000:04:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN [ 2971.239245] iwlwifi 0000:04:00.0: 0x00002AF0 | trm_hw_status0 [ 2971.239248] iwlwifi 0000:04:00.0: 0x00000000 | trm_hw_status1 [ 2971.239252] iwlwifi 0000:04:00.0: 0x004FBE16 | branchlink2 [ 2971.239255] iwlwifi 0000:04:00.0: 0x00014CB0 | interruptlink1 [ 2971.239258] iwlwifi 0000:04:00.0: 0x00014CB0 | interruptlink2 [ 2971.239261] iwlwifi 0000:04:00.0: 0x0000EFC2 | data1 [ 2971.239264] iwlwifi 0000:04:00.0: 0x01000000 | data2 [ 2971.239267] iwlwifi 0000:04:00.0: 0x00000000 | data3 [ 2971.239269] iwlwifi 0000:04:00.0: 0x1E411BF2 | beacon time [ 2971.239272] iwlwifi 0000:04:00.0: 0x717B5415 | tsf low [ 2971.239275] iwlwifi 0000:04:00.0: 0x00000470 | tsf hi [ 2971.239278] iwlwifi 0000:04:00.0: 0x00000000 | time gp1 [ 2971.239281] iwlwifi 0000:04:00.0: 0x00BF5BA1 | time gp2 [ 2971.239284] iwlwifi 0000:04:00.0: 0x00000001 | uCode revision type [ 2971.239287] iwlwifi 0000:04:00.0: 0x00000048 | uCode version major [ 2971.239290] iwlwifi 0000:04:00.0: 0xDAA05125 | uCode version minor [ 2971.239293] iwlwifi 0000:04:00.0: 0x00000340 | hw version [ 2971.239296] iwlwifi 0000:04:00.0: 0x00C89000 | board version [ 2971.239299] iwlwifi 0000:04:00.0: 0x0200001C | hcmd [ 2971.239302] iwlwifi 0000:04:00.0: 0x80020000 | isr0 [ 2971.239304] iwlwifi 0000:04:00.0: 0x08000000 | isr1 [ 2971.239307] iwlwifi 0000:04:00.0: 0x08F00002 | isr2 [ 2971.239310] iwlwifi 0000:04:00.0: 0x04C3081C | isr3 [ 2971.239313] iwlwifi 0000:04:00.0: 0x00000000 | isr4 [ 2971.239316] iwlwifi 0000:04:00.0: 0x00370103 | last cmd Id [ 2971.239319] iwlwifi 0000:04:00.0: 0x0000EFC2 | wait_event [ 2971.239321] iwlwifi 0000:04:00.0: 0x00000080 | l2p_control [ 2971.239324] iwlwifi 0000:04:00.0: 0x00000020 | l2p_duration [ 2971.239327] iwlwifi 0000:04:00.0: 0x0000003F | l2p_mhvalid [ 2971.239330] iwlwifi 0000:04:00.0: 0x00000080 | l2p_addr_match [ 2971.239333] iwlwifi 0000:04:00.0: 0x00000009 | lmpm_pmg_sel [ 2971.239336] iwlwifi 0000:04:00.0: 0x00000000 | timestamp [ 2971.239339] iwlwifi 0000:04:00.0: 0x0000F054 | flow_handler [ 2971.239387] iwlwifi 0000:04:00.0: Start IWL Error Log Dump: [ 2971.239390] iwlwifi 0000:04:00.0: Transport status: 0x0000004A, valid: 7 [ 2971.239393] iwlwifi 0000:04:00.0: 0x20000066 | NMI_INTERRUPT_HOST [ 2971.239397] iwlwifi 0000:04:00.0: 0x00000000 | umac branchlink1 [ 2971.239400] iwlwifi 0000:04:00.0: 0x80455E3C | umac branchlink2 [ 2971.239402] iwlwifi 0000:04:00.0: 0x80472146 | umac interruptlink1 [ 2971.239405] iwlwifi 0000:04:00.0: 0x80462150 | umac interruptlink2 [ 2971.239408] iwlwifi 0000:04:00.0: 0x01000000 | umac data1 [ 2971.239411] iwlwifi 0000:04:00.0: 0x80462150 | umac data2 [ 2971.239414] iwlwifi 0000:04:00.0: 0x00000000 | umac data3 [ 2971.239417] iwlwifi 0000:04:00.0: 0x00000048 | umac major [ 2971.239420] iwlwifi 0000:04:00.0: 0xDAA05125 | umac minor [ 2971.239422] iwlwifi 0000:04:00.0: 0x00BF5B9E | frame pointer [ 2971.239425] iwlwifi 0000:04:00.0: 0xC088624C | stack pointer [ 2971.239428] iwlwifi 0000:04:00.0: 0x0049019C | last host cmd [ 2971.239431] iwlwifi 0000:04:00.0: 0x00000000 | isr status reg [ 2971.239447] iwlwifi 0000:04:00.0: IML/ROM dump: [ 2971.239450] iwlwifi 0000:04:00.0: 0x00000003 | IML/ROM error/state [ 2971.239465] iwlwifi 0000:04:00.0: 0x00005741 | IML/ROM data1 [ 2971.239481] iwlwifi 0000:04:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0 [ 2971.239492] iwlwifi 0000:04:00.0: Fseq Registers: [ 2971.239497] iwlwifi 0000:04:00.0: 0x60000000 | FSEQ_ERROR_CODE [ 2971.239503] iwlwifi 0000:04:00.0: 0x80290021 | FSEQ_TOP_INIT_VERSION [ 2971.239509] iwlwifi 0000:04:00.0: 0x00050008 | FSEQ_CNVIO_INIT_VERSION [ 2971.239515] iwlwifi 0000:04:00.0: 0x0000A503 | FSEQ_OTP_VERSION [ 2971.239522] iwlwifi 0000:04:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION [ 2971.239528] iwlwifi 0000:04:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN [ 2971.239533] iwlwifi 0000:04:00.0: 0x00100530 | FSEQ_CNVI_ID [ 2971.239539] iwlwifi 0000:04:00.0: 0x00000532 | FSEQ_CNVR_ID [ 2971.239545] iwlwifi 0000:04:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP [ 2971.239553] iwlwifi 0000:04:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP [ 2971.239561] iwlwifi 0000:04:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM [ 2971.239570] iwlwifi 0000:04:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR [ 2971.239750] iwlwifi 0000:04:00.0: WRT: Collecting data: ini trigger 4 fired (delay=0ms). [ 2971.239758] ieee80211 phy0: Hardware restart was requested [ 2972.185829] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001) [ 2972.185837] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001) [ 2972.185841] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001) [ 2972.185843] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001) [ 2972.185846] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001) [ 2972.185848] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001) [ 2972.185851] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
The specific queue that gets stuck and the values after "Queue X is stuck" vary between messages, but everything else appears to be the same.
In case it's helpful, I'm running Linux kernel 6.1.0-28-amd64 and the firmware versions for iwlwifi were obtained through Debian's non-free-firmware repo using apt. This is what I get running apt show firmware-iwlwifi:
Package: firmware-iwlwifi
Version: 20230210-5
Priority: optional
Section: non-free-firmware/kernel
Source: firmware-nonfree
Maintainer: Debian Kernel Team <debian-kernel@lists.debian.org>
Installed-Size: 84.3 MB
Suggests: initramfs-tools
Homepage: https://git.kernel.org/cgit/linux/kernel/git/firmware/linux-firmware.git
Download-Size: 9,336 kB
APT-Manual-Installed: yes
APT-Sources: http://deb.debian.org/debian bookworm/non-free-firmware amd64 Packages
Description: Binary firmware for Intel Wireless cards
This package contains the binary firmware for Intel Wireless cards
supported by the iwl3945, iwl4965, and iwlwifi drivers.
Contents:
* Intel Wireless 8260 Bluetooth configuration, version 20.10.0.8
(intel/ibt-11-5.ddc)
* Intel Wireless 8260 Bluetooth firmware, version 20.100.0.3
(intel/ibt-11-5.sfi)
* Intel Wireless 8265 Bluetooth configuration, version 20.30.0.1
(intel/ibt-12-16.ddc)
* Intel Wireless 8265 Bluetooth firmware, version 21.10.0.6
(intel/ibt-12-16.sfi)
* Intel Wireless 9460/9650 (var 0 rev 1) Bluetooth configuration,
version 20.10 (intel/ibt-17-0-1.ddc)
* Intel Wireless 9460/9650 (var 0 rev 1) Bluetooth firmware, version
20.30.0.1 (intel/ibt-17-0-1.sfi)
* Intel Wireless 9460/9650 (var 16 rev 1) Bluetooth configuration,
version 20.60.0.2 (intel/ibt-17-16-1.ddc)
* Intel Wireless 9460/9650 (var 16 rev 1) Bluetooth firmware, version
22.200.0.2 (intel/ibt-17-16-1.sfi)
* Intel Wireless 9160/9260 (var 0 rev 1) Bluetooth configuration,
version 20.10 (intel/ibt-18-0-1.ddc)
* Intel Wireless 9160/9260 (var 0 rev 1) Bluetooth firmware, version
20.30.0.1 (intel/ibt-18-0-1.sfi)
* Intel Wireless 9160/9260 (var 16 rev 1) Bluetooth configuration,
version 20.60.0.2 (intel/ibt-18-16-1.ddc)
* Intel Wireless 9160/9260 (var 16 rev 1) Bluetooth firmware, version
22.200.0.2 (intel/ibt-18-16-1.sfi)
* Intel Bluetooth AX201 (var 0 rev 0) configuration, version 21.20.0.4
(intel/ibt-19-0-0.ddc)
* Intel Bluetooth AX201 (var 0 rev 0) firmware, version 22.200.0.2
(intel/ibt-19-0-0.sfi)
* Intel Bluetooth AX201 (var 0 rev 1) configuration, version
22.200.0.2 (intel/ibt-19-0-1.ddc)
* Intel Bluetooth AX201 (var 0 rev 1) firmware, version 22.180.0.2
(intel/ibt-19-0-1.sfi)
* Intel Bluetooth AX201 (var 0 rev 4) configuration, version 21.20.0.4
(intel/ibt-19-0-4.ddc)
* Intel Bluetooth AX201 (var 0 rev 4) firmware, version 22.200.0.2
(intel/ibt-19-0-4.sfi)
* Intel Bluetooth AX201 (var 16 rev 4) configuration, version
21.20.0.4 (intel/ibt-19-16-4.ddc)
* Intel Bluetooth AX201 (var 16 rev 4) firmware, version 22.200.0.2
(intel/ibt-19-16-4.sfi)
* Intel Bluetooth AX201 firmware, version 21.110.0.3
(intel/ibt-19-240-1.ddc)
* Intel Bluetooth AX201 firmware, version 22.200.0.2
(intel/ibt-19-240-1.sfi)
* Intel Bluetooth AX201 firmware, version 21.90.0.3
(intel/ibt-19-240-4.ddc)
(intel/ibt-19-240-4.sfi)
* Intel Bluetooth AX201 (var 32 rev 0) configuration
(intel/ibt-19-32-0.ddc)
* Intel Bluetooth AX201 (var 32 rev 0) firmware, version 22.200.0.2
(intel/ibt-19-32-0.sfi)
* Intel Bluetooth AX201 (var 32 rev 1) configuration, version
21.20.0.4 (intel/ibt-19-32-1.ddc)
* Intel Bluetooth AX201 (var 32 rev 1) firmware, version 22.200.0.2
(intel/ibt-19-32-1.sfi)
* Intel Bluetooth AX201 (var 32 rev 4) configuration, version
21.90.0.3 (intel/ibt-19-32-4.ddc)
* Intel Bluetooth AX201 (var 32 rev 4) firmware, version 22.200.0.2
(intel/ibt-19-32-4.sfi)
* Intel Wireless 22161 (var 0 rev 3) Bluetooth configuration, version
22.200.0.2 (intel/ibt-20-0-3.ddc)
* Intel Wireless 22161 (var 0 rev 3) Bluetooth firmware, version
22.180.0.2 (intel/ibt-20-0-3.sfi)
* Intel Wireless 22161 (var 1 rev 3) Bluetooth configuration, version
21.0.0.4 (intel/ibt-20-1-3.ddc)
* Intel Wireless 22161 (var 1 rev 3) Bluetooth firmware, version
22.200.0.2 (intel/ibt-20-1-3.sfi)
* Intel Wireless 22161 (var 1 rev 4) Bluetooth configuration
(intel/ibt-20-1-4.ddc)
* Intel Wireless 22161 (var 1 rev 4) Bluetooth firmware, version
22.200.0.2 (intel/ibt-20-1-4.sfi)
* Intel Wireless AX211 Bluethooth configuration, version 22.80.0.4
(intel/ibt-0040-0041.ddc)
* Intel Wireless AX211 Bluethooth firmware, version 22.200.0.2
(intel/ibt-0040-0041.sfi)
* intel/ibt-1040-0041.ddc
* intel/ibt-1040-0041.sfi
* Intel Wireless AX2100 Bluethooth configuration, version 22.00.0.0
(intel/ibt-0041-0041.ddc)
* Intel Wireless AX2100 Bluethooth firmware, version 22.200.0.2
(intel/ibt-0041-0041.sfi)
* Intel Wireless Bluetooth AX201 configuration, version 22.80.0.4
(intel/ibt-0040-4150.ddc)
* Intel Wireless Bluetooth AX201 firmware, version 22.200.0.2
(intel/ibt-0040-4150.sfi)
(intel/ibt-1040-4150.ddc)
(intel/ibt-1040-4150.sfi)
* Intel Wireless 3160 (B6) Bluetooth firmware patch, version 19.30
(intel/ibt-hw-37.7.10-fw-1.0.1.2d.d.bseq)
* Intel Wireless 3160 (B4) Bluetooth firmware patch, version 19.01
(intel/ibt-hw-37.7.10-fw-1.0.2.3.d.bseq)
* Intel Wireless 7260 (B5) Bluetooth firmware patch, version 20.60.0.2
(intel/ibt-hw-37.7.10-fw-1.80.1.2d.d.bseq)
* Intel Wireless 7260 (B3) Bluetooth firmware patch, version 20.60.0.2
(intel/ibt-hw-37.7.10-fw-1.80.2.3.d.bseq)
* Intel Wireless 7260 Bluetooth firmware generic patch
(intel/ibt-hw-37.7.bseq)
* Intel Wireless 7265 (C0) Bluetooth firmware patch, version 19.30
(intel/ibt-hw-37.8.10-fw-1.10.2.27.d.bseq)
* Intel Wireless 7265 (D0) Bluetooth firmware patch, version 20.60.0.2
(intel/ibt-hw-37.8.10-fw-1.10.3.11.e.bseq)
* Intel Wireless 7265 (D1) Bluetooth firmware patch, version 20.70.0.4
(intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq)
* Intel Wireless 7265 Bluetooth firmware generic patch
(intel/ibt-hw-37.8.bseq)
* Intel Wireless 100 firmware, version 39.31.5.1 (iwlwifi-100-5.ucode)
* Intel Wireless 105 firmware, version 18.168.6.1
(iwlwifi-105-6.ucode)
* Intel Wireless 135 firmware, version 18.168.6.1
(iwlwifi-135-6.ucode)
* Intel Wireless 1000 firmware, version 39.31.5.1
(iwlwifi-1000-5.ucode)
* Intel Wireless 2200 firmware, version 18.168.6.1
(iwlwifi-2000-6.ucode)
* Intel Wireless 2230 firmware, version 18.168.6.1
(iwlwifi-2030-6.ucode)
* Intel Wireless 3160 firmware, version 17.bfb58538.0
(iwlwifi-3160-17.ucode)
* Intel Wireless 3168 firmware, version 29.0bd893f3.0
(iwlwifi-3168-29.ucode)
* Intel Wireless 3945 firmware, version 15.32.2.9
(iwlwifi-3945-2.ucode)
* Intel Wireless 4965 firmware, version 228.61.2.24
(iwlwifi-4965-2.ucode)
* Intel Wireless 5100, 5300 and 5350 firmware, version 8.83.5.1
(iwlwifi-5000-5.ucode)
* Intel Wireless 5150 firmware, version 8.24.2.2
(iwlwifi-5150-2.ucode)
* Intel Wireless 6000 firmware, version 9.221.4.1
(iwlwifi-6000-4.ucode)
* Intel Wireless 6005/6205 firmware, version 18.168.6.1
(iwlwifi-6000g2a-6.ucode)
* Intel Wireless 6030 firmware, version 18.168.6.1
(iwlwifi-6000g2b-6.ucode)
* Intel Wireless 6250 firmware, version 41.28.5.1
(iwlwifi-6050-5.ucode)
* Intel Wireless 7260 firmware, version 17.bfb58538.0
(iwlwifi-7260-17.ucode)
* Intel Wireless 7265 firmware, version 17.bfb58538.0
(iwlwifi-7265-17.ucode)
* Intel Wireless 7265D firmware, version 29.0bd893f3.0
(iwlwifi-7265D-29.ucode)
* Intel Wireless 8000C firmware, version 36.ca7b901d.0
(iwlwifi-8000C-36.ucode)
* Intel Wireless 8265 firmware, version 36.ca7b901.0
(iwlwifi-8265-36.ucode)
* Intel Wireless 9000 firmware, version 34.ba501b11.0
(iwlwifi-9000-pu-b0-jf-b0-34.ucode)
* Intel Wireless 9000 firmware, version 38.755cfdd8.0
(iwlwifi-9000-pu-b0-jf-b0-38.ucode)
* Intel Wireless 9000 firmware, version 46.ea3728ee.0
(iwlwifi-9000-pu-b0-jf-b0-46.ucode)
* Intel Wireless 9260 firmware, version 34.ba501b11.0
(iwlwifi-9260-th-b0-jf-b0-34.ucode)
* Intel Wireless 9260 firmware, version 38.755cfdd8.0
(iwlwifi-9260-th-b0-jf-b0-38.ucode)
* Intel Wireless 9260 firmware, version 46.ea3728ee.0
(iwlwifi-9260-th-b0-jf-b0-46.ucode)
* Intel Wireless 22000 series (QU-B-HR-B) firmware, version
50.3e391d3e.0 (iwlwifi-Qu-b0-hr-b0-50.ucode)
59.601f3a66.0 (iwlwifi-Qu-b0-hr-b0-59.ucode)
72.daa05125.0 (iwlwifi-Qu-b0-hr-b0-72.ucode)
* Intel Wireless 22000 series (QU-B-JF-B) firmware, version
50.3e391d3e.0 (iwlwifi-Qu-b0-jf-b0-50.ucode)
59.601f3a66.0 (iwlwifi-Qu-b0-jf-b0-59.ucode)
72.daa05125.0 (iwlwifi-Qu-b0-jf-b0-72.ucode)
* Intel Wireless 22000 series (QU-C-HR-B) firmware, version
50.3e391d3e.0 (iwlwifi-Qu-c0-hr-b0-50.ucode)
59.601f3a66.0 (iwlwifi-Qu-c0-hr-b0-59.ucode)
72.daa05125.0 (iwlwifi-Qu-c0-hr-b0-72.ucode)
* Intel Wireless 22000 series (QU-C-JF-B) firmware, version
50.3e391d3e.0 (iwlwifi-Qu-c0-jf-b0-50.ucode)
59.601f3a66.0 (iwlwifi-Qu-c0-jf-b0-59.ucode)
72.daa05125.0 (iwlwifi-Qu-c0-jf-b0-72.ucode)
* Intel Wireless 22000 series (QUZ-A-HR-B) firmware, version
50.3e391d3e.0 (iwlwifi-QuZ-a0-hr-b0-50.ucode)
59.601f3a66.0 (iwlwifi-QuZ-a0-hr-b0-59.ucode)
72.daa05125.0 (iwlwifi-QuZ-a0-hr-b0-72.ucode)
* Intel Wireless 22000 series (QUZ-A-JF-B) firmware, version
50.3e391d3e.0 (iwlwifi-QuZ-a0-jf-b0-50.ucode)
59.601f3a66.0 (iwlwifi-QuZ-a0-jf-b0-59.ucode)
72.daa05125.0 (iwlwifi-QuZ-a0-jf-b0-72.ucode)
* Intel Wireless series (CC-A0) firmware, version 50.3e391d3e.0
(iwlwifi-cc-a0-50.ucode)
* Intel Wireless series (CC-A0) firmware, version 59.601f3a66.0
(iwlwifi-cc-a0-59.ucode)
* Intel Wireless series (CC-A0) firmware, version 72.daa05125.0
(iwlwifi-cc-a0-72.ucode)
* Intel Wireless (TY-A0-GF-A0) firmware, version 59.601f3a66.0
(iwlwifi-ty-a0-gf-a0-59.ucode)
* Intel Wireless (TY-A0-GF-A0) firmware, version 66.55c64978.0
(iwlwifi-ty-a0-gf-a0-66.ucode)
* Intel Wireless (TY-A0-GF-A0) firmware, version 72.daa05125.0
(iwlwifi-ty-a0-gf-a0-72.ucode)
* Intel Wireless (TY-A0-GF-A0) PNVM firmware, version 76.27f1c37b.0
(iwlwifi-ty-a0-gf-a0.pnvm)
* Intel Wireless (SO-A0-GF-A0) firmware, version 72.daa05125.0
(iwlwifi-so-a0-gf-a0-72.ucode)
* Intel Wireless (SO-A0-GF-A0) PNVM firmware, version 76.27f1c37b.0
(iwlwifi-so-a0-gf-a0.pnvm)
* iwlwifi-so-a0-gf4-a0-72.ucode
* Intel Wireless (SO-A0-GF4-A0) PNVM firmware, version 76.27f1c37b.0
(iwlwifi-so-a0-gf4-a0.pnvm)
* Intel Wireless (SO-A0-HR-B0) firmware, version 72.daa05125.0
(iwlwifi-so-a0-hr-b0-72.ucode)
* Intel Wireless (SO-A0-JF-B0) firmware, version 72.daa05125.0
(iwlwifi-so-a0-jf-b0-72.ucode)To give a bit of additional context, I've been using my AX200 for years with no issue on Debian 10 and 11, but the problem started when I upgraded to Debian 12 about two months ago. The problem is also pretty sporadic, I can go days without any Wifi problems, but on some days it will constantly disconnect.
Any help will be appreciated.
Thank you,
Daniel
Sounds Like its an issue with Debian 12 since Debian 10 and 11 worked good with AX200. Can you update the Kernel ? I start a thread in Debian User Forums to get resolution on the wifi issues, System and Network Configuration is a good place to start.
Cheers
3Fees
I'd really prefer not to update the kernel since stability is the entire reason I run Debian in the first place. Debian is always a bit behind on software and kernel versions, but their team does a good job of ensuring that all the software available from their official repos works together without issue.
I can certainly switch to their unstable repos and install a newer kernel version, but I'd rather not do that for the only non-free piece of software I'm using (the iwlwifi drivers), especially if I'm not 100% sure upgrading the kernel will fix the issue. It definitely seems like there's some compatibility issue between the kernel and Intel's firmware, but it's strange that it ran fine on older versions of the kernel and I'd prefer to know which pieces aren't cooperating.
I'll certainly try asking on the Debian user forums too, but since Intel's drivers/firmware are proprietary, I'm doubtful they'd be much help.
Cheers
3Fees
Okay, I've posted the issue on the Debian user forum a few days ago, but it seems like a lot of people are having similar issues and none of the suggestions seem to work. I've tried reverting to older firmware versions and have even upgraded my kernel to 6.11 which should fall under what is required for all Intel wireless adapters according to https://www.intel.com/content/www/us/en/support/articles/000005511/wireless.html. In fact my old kernel version should have been sufficient for the AX200.
I'm still getting the same issue.
It really seems like this has more to do with how Intel's firmware interfaces with the more modern versions of the linux kernel than anything specific to Debian. Especially since the error message is claiming it's a microcode error in the iwlwifi firmware.
Look at this post. Briefly try another Channel. There is free wifi channel scanners to download. Pick and use the strongest channel.
Cheers
3Fees
