Wireless
8846 Discussions
AX200 slow upload speed
rhubinak
AX200 is connected to 802.11AC router via 5Ghz band. Tested connection speed with iperf3:
~170 Mbits/sec download
~25 Mbits/sec upload
Tried tweaking following settings for iwlwifi driver without success:
11n_disable
uapsd_disable
bt_coex_active
disable_11ac
disable_11ax
A different network card achieves consistent ~170 Mbits/sec download/upload speed. How can I achieve better upload performance with this card? Is this issue related?
Please find debug information below:
Laptop with AX200 network card
LENOVO 20UHS00W00/20UHS00W00, BIOS R1CET60W(1.29 )
Linux version 5.10.12-200.fc33.x86_64 (mockbuild@bkernel01.iad2.fedoraproject.org) (gcc (GCC) 10.2.1 20201125 (Red Hat 10.2.1-9), GNU ld version 2.35-18.fc33) #1 SMP Mon Feb 1 02:40:52 UTC 2021
iwlwifi driver dmesg
[   16.611578] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[   16.629328] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[   16.629342] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.22
[   16.629695] iwlwifi 0000:03:00.0: loaded firmware version 59.601f3a66.0 cc-a0-59.ucode op_mode iwlmvm
[   16.798811] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[   17.029534] iwlwifi 0000:03:00.0: base HW address: 34:cf:f6:f3:25:37
[   17.049485] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
[   18.198554] Modules linked in: ccm des_generic libdes cmac md4 sunrpc vfat fat snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi iwlmvm snd_hda_intel snd_soc_dmic snd_acp3x_rn snd_acp3x_pdm_dma snd_intel_dspcfg soundwire_intel soundwire_generic_allocation mac80211 snd_soc_core edac_mce_amd snd_compress libarc4 snd_pcm_dmaengine kvm_amd soundwire_cadence snd_hda_codec kvm iwlwifi snd_hda_core snd_usb_audio uvcvideo snd_usbmidi_lib videobuf2_vmalloc ac97_bus snd_rawmidi videobuf2_memops irqbypass videobuf2_v4l2 snd_hwdep rapl snd_seq videobuf2_common snd_seq_device joydev wmi_bmof videodev snd_pcm cfg80211 snd_rn_pci_acp3x sp5100_tco mc k10temp snd_pci_acp3x thinkpad_acpi i2c_piix4 snd_timer ledtrig_audio snd ipmi_devintf ucsi_acpi ipmi_msghandler typec_ucsi soundcore rfkill typec i2c_scmi acpi_cpufreq zram ip_tables dm_crypt hid_microsoft ff_memless amdgpu iommu_v2 gpu_sched ttm i2c_algo_bit drm_kms_helper cec crct10dif_pclmul crc32_pclmul crc32c_intel drm ghash_clmulni_intel
 iwd initialization
Feb 07 09:50:00 rh iwd[1445]: Wireless daemon version 1.11
Feb 07 09:50:00 rh iwd[1445]: Loaded configuration from /etc/iwd/main.conf
Feb 07 09:50:00 rh dbus-broker-launch[1529]: Deprecated policy context in /usr/share/dbus-1/system.d/iwd-dbus.conf +21. The 'at_console' context is deprecated and will be ignored in the future.
Feb 07 09:50:00 rh iwd[1445]: station: Network configuration is disabled.
Feb 07 09:50:00 rh kernel: CPU: 6 PID: 1445 Comm: iwd Tainted: G        W         5.10.12-200.fc33.x86_64 #1
Feb 07 09:50:00 rh audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=iwd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Feb 07 09:50:00 rh iwd[1445]: Wiphy: 0, Name: phy0
Feb 07 09:50:00 rh iwd[1445]:         Permanent Address: 34:cf:f6:f3:25:37
Feb 07 09:50:00 rh iwd[1445]:         Bands: 2.4 GHz 5 GHz
Feb 07 09:50:00 rh iwd[1445]:         Ciphers: CCMP TKIP BIP
Feb 07 09:50:00 rh iwd[1445]:         Supported iftypes: ad-hoc station ap p2p-client p2p-go p2p-device
Feb 07 09:50:01 rh NetworkManager[1638]: <info>  [1612687801.3588] device (wlan0): new IWD device state is connecting
Feb 07 09:50:01 rh NetworkManager[1638]: <warn>  [1612687801.3589] device (wlan0): Unsolicited connection success, asking IWD to disconnect
Feb 07 09:50:01 rh NetworkManager[1638]: <info>  [1612687801.3616] device (wlan0): new IWD device state is disconnected
Feb 07 09:50:01 rh iwd[1445]: Unexpected connection related event -- is another supplicant running?
Feb 07 09:50:01 rh iwd[1445]: Received error during CMD_TRIGGER_SCAN: Operation not supported (95)
iw dev wlp3s0 link
Connected to b8:ec:a3:d8:35:31 (on wlan20)
	SSID: Nellyville
	freq: 5180
	RX: 238465887 bytes (159575 packets)
	TX: 19192614 bytes (13338 packets)
	signal: -59 dBm
	rx bitrate: 325.0 MBit/s VHT-MCS 7 80MHz short GI VHT-NSS 1
	tx bitrate: 526.6 MBit/s VHT-MCS 6 80MHz VHT-NSS 2
	bss flags:	short-slot-time
	dtim period:	2
	beacon int:	100
iw list
Wiphy phy20
	max # scan SSIDs: 20
	max scan IEs length: 365 bytes
	max # sched scan SSIDs: 20
	max # match sets: 8
	Retry short limit: 7
	Retry long limit: 4
	Coverage class: 0 (up to 0m)
	Device supports RSN-IBSS.
	Device supports AP-side u-APSD.
	Device supports T-DLS.
	Supported Ciphers:
		* WEP40 (00-0f-ac:1)
		* WEP104 (00-0f-ac:5)
		* TKIP (00-0f-ac:2)
		* CCMP-128 (00-0f-ac:4)
		* GCMP-128 (00-0f-ac:8)
		* GCMP-256 (00-0f-ac:9)
		* CMAC (00-0f-ac:6)
		* GMAC-128 (00-0f-ac:11)
		* GMAC-256 (00-0f-ac:12)
	Available Antennas: TX 0x3 RX 0x3
	Configured Antennas: TX 0x3 RX 0x3
	Supported interface modes:
		 * IBSS
		 * managed
		 * AP
		 * AP/VLAN
		 * monitor
		 * P2P-client
		 * P2P-GO
		 * P2P-device
	Band 1:
		Capabilities: 0x19ef
			RX LDPC
			HT20/HT40
			SM Power Save disabled
			RX HT20 SGI
			RX HT40 SGI
			TX STBC
			RX STBC 1-stream
			Max AMSDU length: 7935 bytes
			DSSS/CCK HT40
		Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
		Minimum RX AMPDU time spacing: 4 usec (0x05)
		HT Max RX data rate: 300 Mbps
		HT TX/RX MCS rate indexes supported: 0-15
		HE Iftypes: Station
			HE MAC Capabilities (0x78031220abc0):
				+HTC HE Supported
				TWT Requester
				Trigger Frame MAC Padding Duration: 2
				Multi-TID Aggregation Support: 7
				32-bit BA Bitmap
				OM Control
				Maximum A-MPDU Length Exponent: 2
				A-MSDU in A-MPDU
				Multi-TID Aggregation TX: 7
				UL 2x996-Tone RU
			HE PHY Capabilities: (0x0e3f0200fd09800ecff200):
				HE40/2.4GHz
				HE40/HE80/5GHz
				HE160/5GHz
				Punctured Preamble RX: 15
				Device Class: 1
				LDPC Coding in Payload
				NDP with 4x HE-LTF and 3.2us GI
				SU Beamformee
				Beamformee STS <= 80Mhz: 7
				Beamformee STS > 80Mhz: 7
				Sounding Dimensions <= 80Mhz: 1
				Sounding Dimensions > 80Mhz: 1
				PPE Threshold Present
				Power Boost Factor ar
				HE SU PPDU & HE PPDU 4x HE-LTF 0.8us GI
				Max NC: 1
				HE ER SU PPDU 4x HE-LTF 0.8us GI
				20MHz in 40MHz HE PPDU 2.4GHz
				20MHz in 160/80+80MHz HE PPDU
				80MHz in 160/80+80MHz HE PPDU
				DCM Max BW: 3
				Non-Triggered CQI Feedback
				RX Full BW SU Using HE MU PPDU with Compression SIGB
				RX Full BW SU Using HE MU PPDU with Non-Compression SIGB
			HE RX MCS and NSS set <= 80 MHz
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
					 3 streams: not supported
					 4 streams: not supported
					 5 streams: not supported
					 6 streams: not supported
					 7 streams: not supported
					 8 streams: not supported
			HE TX MCS and NSS set <= 80 MHz
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
			HE RX MCS and NSS set 160 MHz
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
			HE TX MCS and NSS set 160 MHz
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
			PPE Threshold 0x61 0x1c 0xc7 0x71
		HE Iftypes: AP
			HE MAC Capabilities (0x780112080840):
				+HTC HE Supported
				BSR
				OM Control
				A-MSDU in A-MPDU
				UL 2x996-Tone RU
			HE PHY Capabilities: (0x0e200200fd09800ccff000):
				HE40/2.4GHz
				HE40/HE80/5GHz
				HE160/5GHz
				SU Beamformee
				Max NC: 1
				DCM Max BW: 3
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
		Bitrates (non-HT):
			* 1.0 Mbps
			* 2.0 Mbps (short preamble supported)
			* 5.5 Mbps (short preamble supported)
			* 11.0 Mbps (short preamble supported)
			* 6.0 Mbps
			* 9.0 Mbps
			* 12.0 Mbps
			* 18.0 Mbps
			* 24.0 Mbps
			* 36.0 Mbps
			* 48.0 Mbps
			* 54.0 Mbps
		Frequencies:
			* 2412 MHz [1] (22.0 dBm)
			* 2417 MHz [2] (22.0 dBm)
			* 2422 MHz [3] (22.0 dBm)
			* 2427 MHz [4] (22.0 dBm)
			* 2432 MHz [5] (22.0 dBm)
			* 2437 MHz [6] (22.0 dBm)
			* 2442 MHz [7] (22.0 dBm)
			* 2447 MHz [8] (22.0 dBm)
			* 2452 MHz [9] (22.0 dBm)
			* 2457 MHz [10] (22.0 dBm)
			* 2462 MHz [11] (22.0 dBm)
			* 2467 MHz [12] (22.0 dBm)
			* 2472 MHz [13] (22.0 dBm)
			* 2484 MHz [14] (disabled)
	Band 2:
			RX LDPC
			HT20/HT40
			RX HT20 SGI
			RX HT40 SGI
			TX STBC
			RX STBC 1-stream
			DSSS/CCK HT40
		VHT Capabilities (0x039071f6):
			Max MPDU length: 11454
			Supported Channel Width: 160 MHz
			RX LDPC
			short GI (80 MHz)
			short GI (160/80+80 MHz)
			TX STBC
			SU Beamformee
			MU Beamformee
		VHT RX MCS set:
			1 streams: MCS 0-9
			2 streams: MCS 0-9
		VHT RX highest supported: 0 Mbps
		VHT TX MCS set:
			1 streams: MCS 0-9
			2 streams: MCS 0-9
		VHT TX highest supported: 0 Mbps
		HE Iftypes: Station
				+HTC HE Supported
				TWT Requester
				32-bit BA Bitmap
				OM Control
				A-MSDU in A-MPDU
				UL 2x996-Tone RU
				HE40/2.4GHz
				HE40/HE80/5GHz
				HE160/5GHz
				Device Class: 1
				SU Beamformee
				Max NC: 1
				DCM Max BW: 3
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
		HE Iftypes: AP
				+HTC HE Supported
				BSR
				OM Control
				A-MSDU in A-MPDU
				UL 2x996-Tone RU
				HE40/2.4GHz
				HE40/HE80/5GHz
				HE160/5GHz
				SU Beamformee
				Max NC: 1
				DCM Max BW: 3
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
					 1 streams: MCS 0-11
					 2 streams: MCS 0-11
		Bitrates (non-HT):
			* 6.0 Mbps
			* 9.0 Mbps
			* 12.0 Mbps
			* 18.0 Mbps
			* 24.0 Mbps
			* 36.0 Mbps
			* 48.0 Mbps
			* 54.0 Mbps
		Frequencies:
			* 5180 MHz [36] (22.0 dBm) (no IR)
			* 5200 MHz [40] (22.0 dBm) (no IR)
			* 5220 MHz [44] (22.0 dBm) (no IR)
			* 5240 MHz [48] (22.0 dBm) (no IR)
			* 5260 MHz [52] (22.0 dBm) (no IR, radar detection)
			* 5280 MHz [56] (22.0 dBm) (no IR, radar detection)
			* 5300 MHz [60] (22.0 dBm) (no IR, radar detection)
			* 5320 MHz [64] (22.0 dBm) (no IR, radar detection)
			* 5340 MHz [68] (disabled)
			* 5360 MHz [72] (disabled)
			* 5380 MHz [76] (disabled)
			* 5400 MHz [80] (disabled)
			* 5420 MHz [84] (disabled)
			* 5440 MHz [88] (disabled)
			* 5460 MHz [92] (disabled)
			* 5480 MHz [96] (disabled)
			* 5500 MHz [100] (22.0 dBm) (no IR, radar detection)
			* 5520 MHz [104] (22.0 dBm) (no IR, radar detection)
			* 5540 MHz [108] (22.0 dBm) (no IR, radar detection)
			* 5560 MHz [112] (22.0 dBm) (no IR, radar detection)
			* 5580 MHz [116] (22.0 dBm) (no IR, radar detection)
			* 5600 MHz [120] (22.0 dBm) (no IR, radar detection)
			* 5620 MHz [124] (22.0 dBm) (no IR, radar detection)
			* 5640 MHz [128] (22.0 dBm) (no IR, radar detection)
			* 5660 MHz [132] (22.0 dBm) (no IR, radar detection)
			* 5680 MHz [136] (22.0 dBm) (no IR, radar detection)
			* 5700 MHz [140] (22.0 dBm) (no IR, radar detection)
			* 5720 MHz [144] (22.0 dBm) (no IR, radar detection)
			* 5745 MHz [149] (22.0 dBm)
			* 5765 MHz [153] (22.0 dBm)
			* 5785 MHz [157] (22.0 dBm)
			* 5805 MHz [161] (22.0 dBm)
			* 5825 MHz [165] (22.0 dBm)
			* 5845 MHz [169] (disabled)
			* 5865 MHz [173] (disabled)
			* 5885 MHz [177] (disabled)
			* 5905 MHz [181] (disabled)
	Supported commands:
		 * new_interface
		 * set_interface
		 * new_key
		 * start_ap
		 * new_station
		 * new_mpath
		 * set_mesh_config
		 * set_bss
		 * authenticate
		 * associate
		 * deauthenticate
		 * disassociate
		 * join_ibss
		 * join_mesh
		 * remain_on_channel
		 * set_tx_bitrate_mask
		 * frame
		 * frame_wait_cancel
		 * set_wiphy_netns
		 * set_channel
		 * set_wds_peer
		 * tdls_mgmt
		 * tdls_oper
		 * start_sched_scan
		 * probe_client
		 * set_noack_map
		 * register_beacons
		 * start_p2p_device
		 * set_mcast_rate
		 * connect
		 * disconnect
		 * channel_switch
		 * set_qos_map
		 * add_tx_ts
		 * set_multicast_to_unicast
	WoWLAN support:
		 * wake up on disconnect
		 * wake up on magic packet
		 * wake up on pattern match, up to 20 patterns of 16-128 bytes,
		   maximum packet offset 0 bytes
		 * can do GTK rekeying
		 * wake up on GTK rekey failure
		 * wake up on EAP identity request
		 * wake up on 4-way handshake
		 * wake up on rfkill release
		 * wake up on network detection, up to 8 match sets
	software interface modes (can always be added):
		 * AP/VLAN
		 * monitor
	valid interface combinations:
		 * #{ managed } <= 1, #{ AP, P2P-client, P2P-GO } <= 1, #{ P2P-device } <= 1,
		   total <= 3, #channels <= 2
	HT Capability overrides:
		 * MCS: ff ff ff ff ff ff ff ff ff ff
		 * maximum A-MSDU length
		 * supported channel width
		 * short GI for 40 MHz
		 * max A-MPDU length exponent
		 * min MPDU start spacing
	Device supports TX status socket option.
	Device supports HT-IBSS.
	Device supports SAE with AUTHENTICATE command
	Device supports low priority scan.
	Device supports scan flush.
	Device supports per-vif TX power setting
	P2P GO supports CT window setting
	P2P GO supports opportunistic powersave setting
	Driver supports full state transitions for AP/GO clients
	Driver supports a userspace MPM
	Driver/device bandwidth changes during BSS lifetime (AP/GO mode)
	Device adds DS IE to probe requests
	Device can update TPC Report IE
	Device supports static SMPS
	Device supports dynamic SMPS
	Device supports WMM-AC admission (TSPECs)
	Device supports configuring vdev MAC-addr on create.
	Device supports randomizing MAC-addr in scans.
	Device supports randomizing MAC-addr in sched scans.
	Device supports randomizing MAC-addr in net-detect scans.
	max # scan plans: 2
	max scan plan interval: 65535
	max scan plan iterations: 254
	Supported TX frame types:
		 * IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
	Supported RX frame types:
		 * IBSS: 0x40 0xb0 0xc0 0xd0
		 * managed: 0x40 0xb0 0xd0
		 * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * mesh point: 0xb0 0xc0 0xd0
		 * P2P-client: 0x40 0xd0
		 * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * P2P-device: 0x40 0xd0
	Supported extended features:
		* [ VHT_IBSS ]: VHT-IBSS
		* [ RRM ]: RRM
		* [ MU_MIMO_AIR_SNIFFER ]: MU-MIMO sniffer
		* [ SCAN_START_TIME ]: scan start timestamp
		* [ BSS_PARENT_TSF ]: BSS last beacon/probe TSF
		* [ FILS_STA ]: STA FILS (Fast Initial Link Setup)
		* [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211
		* [ TXQS ]: FQ-CoDel-enabled intermediate TXQs
802.11AC Router
ZyXel NBG6617
OpenWrt 19.07.4, r11208-ce6496d796
5Ghz (2.4 Ghz band is disabled)
channel 36
80MHz
CCMP (AES)
Reference network card
kernel: DMI: LENOVO 81AX/LNVNB161216, BIOS 6SCN35WW 06/21/2018
kernel: Linux version 4.19.167-1-MANJARO (builduser@LEGION) (gcc version 10.2.0 (GCC)) #1 SMP Tue Jan 12 23:22:39 UTC 2021
iwlwifi dmesg
kernel: iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
kernel: iwlwifi 0000:02:00.0: loaded firmware version 29.198743027.0 op_mode iwlmvm
kernel: iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 3165, REV=0x210
kernel: iwlwifi 0000:02:00.0: base HW address: 98:3b:8f:ca:5c:f1
kernel: iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
NetworkManager[776]: <info>  [1612378919.3862] rfkill2: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.4/0000:02:00.0/ieee80211/phy0/rfkill2) (driver iwlwifi)
AndrewG_Intel
Hello @rhubinak
In order to check this further, could you please provide the following details?
1- Did the wireless upload speed work fine before at any time? If yes, do you remember if this issue happened after a new operating system update or Wireless/Bluetooth driver/firmware update?
2- Is the Intel® Wi-Fi 6 AX200 the original wireless adapter that came pre-installed in your system or did you integrate/replace it on the computer?
3- What is the current Internet speed that you have for your ISP service? Is this behavior happening on the Internet (when browsing the web) and/or the LAN (your local network, for instance, transferring data to another device in your network)?
4- Have you checked if this issue happens on different networks?  Have you tried a different router or Access point for testing purposes? Maybe one that is AX compatible? Have you rebooted your access-point, router, modem?
5- Have you checked if this issue happens testing only the laptop and the router? (no other wireless devices connected to the wireless network during this test).
Andrew G.
rhubinak
Hi Andrew,
Sure, please find below:
Nope, if it did I did not notice.
Yep, it's integrated in the Lenovo T14s model range.
My current Internet speed is 30Mbit upload/download, therefore I cannot really tell if this behavior is happening on the Internet. The issue manifests itself on WLAN.
I haven't tested the issue on different networks. Unfortunately, I don't have access to an AX compatible router. I have rebooted the router and the results are the same.
Yes, I have tested with both "only laptop and router" and "router with 2 laptops" sending data to each other.
AndrewG_Intel
Hello @rhubinak
Thank you for the details provided.
Just for clarification purposes, in the initial post, you mentioned that you get:
However, regarding our question # 3, you mentioned the current Internet speed is "30Mbit upload/download". Is this correct? Or did you mean 300 Mbit?
(We just want to make sure we have the correct information).
Andrew G.
AndrewG_Intel
Hello rhubinak
We are checking this thread and we would like to know if you were able to review our previous post. If you need further assistance, please do not hesitate to contact us back.
Andrew G.
AndrewG_Intel
Hello rhubinak
We have not heard back from you so we will proceed to close this thread now.
This issue seems to be related to OS/Linux kernel so our final recommendation is to check with the Linux community for additional assistance, or with the computer manufacturer (OEM), Lenovo* support since they are the ones that integrated the wireless card on the system.
Andrew G.
*Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel® or any of its products is implied.
