Wireless
8508 Discussions
AX200NGW implementation of driver support on nvidia jetson nano
AVolo2
I have found some reference here: https://unix.stackexchange.com/questions/518571/locating-drivers-for-intel-ax200-wireless-on-5-1-kernel
However, I am trying to implement enablement of the card at the mentioned platform. And so far I can see it with lspci:
01:00.0 Network controller: Intel Corporation Device 2723 (rev 1a)
Could you give a hand with implementing support of it within Linux tegra [4.9] environment [aarch64], please?
Reference:
https://devtalk.nvidia.com/default/topic/1049303/jetson-nano/jetson-nano-wifi-/post/5353638/#5353638
AVolo2
trying
git clone https://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/backport-iwlwifi.gitmake defconfig-iwlwifi-public sed -i 's/CPTCFG_IWLMVM_VENDOR_CMDS=y/# CPTCFG_IWLMVM_VENDOR_CMDS is not set/' .config make -j4sudo make install
rebooting
Reference: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/core_release
AVolo2
depmod will prefer updates/ over kernel/ -- OK!
Note:
You may or may not need to update your initramfs, you should if
any of the modules installed are part of your initramfs. To add
support for your distribution to do this automatically send a
patch against "update-initramfs.sh". If your distribution does not
require this send a patch with the '/usr/bin/lsb_release -i -s'
("Ubuntu") tag for your distribution to avoid this warning.
Your backported driver modules should be installed now.
Reboot.
However, after the reboot there is no card that can be observed
AVolo2
modprobe iwlwifi rfkill list 0: phy0: Wireless LAN Soft blocked: no Hard blocked: no
AVolo2
RESOLVED
Oscar_A_Intel1
Hello Avolo2,
Thank you for posting on the Intel Community.
I'm glad to hear that the issue is resolved.
Our Linux* support is limited, however, you can check this article with the Linux* support options we have for future references.
https://www.intel.com/content/www/us/en/support/articles/000005511/network-and-i-o/wireless-networking.html
I'll proceed to close this inquiry, please make a new post if you have any question.
Oscar A.
Under Contract to Intel Corporation
AVolo2
and bluetooth?
how do I enable the bluetoth?
what module to load into the kernel?
AVolo2
it seems that a specific parameter needs to be passed to the module while loading, right?
something like :
modprobe iwlwifi bt_coex_active=1
 that doesn't appear to get the bluetooth to appear
Oscar_A_Intel1
Hello Avolo2,
The Linux* support for wireless adapters is limited. Please check out this link on how to get Linux* support and report issues.
We highly recommend you to contact the community of the Linux* distribution that you're using for support assistance.
Oscar A.
AVolo2
with the latter kernel available for tegra linux I am getting a device eth1 to appear after installing intel drivers with
git clone --single-branch --branch master https://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/backport-iwlwifi.git cd backport-iwlwifi/ make defconfig-iwlwifi-public sed -i 's/CPTCFG_IWLMVM_VENDOR_CMDS=y/# CPTCFG_IWLMVM_VENDOR_CMDS is not set/' .config make -j8 sudo make install
