Wireless
9036 Discussions
AX201 Wireless + Bluetooth 5.1 Adapter Missing In Device Manager
msong18
Couple days ago, I have finished building a new Intel i9-10900 (NON K)
system and currently having difficulties setting WIFI.
My system's motherboard (ROG STRIX Z490) manufacturer (ASUS) has claimed that this board is equipped with AX201 WIFI6+BT adapter.
After installing all the drivers, the network adapter device can not be found in Device Manager. I only have Intel Ethernet I225-V correctly installed and have been using.
I also dumped out DXDIAG log to see if wirelss ax201 PCI device is present but unfortunately, I could not locate AX201 device (Vendor ID 8086, Device ID 06F0)
Does this mean that I have a defective board?
My local service center keeps telling me to re-install everything from scratch till the Wireless adapter shows off.
I installed from scratch at least 3 times but no luck setting up WIFI.
Please do help me out by giving me technical advises on what could be possible solutions to my problem.
I have attached my DXDIAG log for you to refer.
Thank you very much for your support and help.
I really need one now.
Thnx
ms
n_scott_pearson
Please download and run the Intel System Support Utility for Windows and have it save the report to a file. Then, using the paperclip icon below the edit window, upload and attach this file to a response post.
msong18
Thank you for your support.
I am attaching SSU log from My system
Please look at the log and let me know if there is HW issue.
Thank you
Wanner_G_Intel
Hello msong18,
Thank you for posting your question on this Intel® Community.
We found another thread describing the same issue you are reporting on this one. To better assist you, we will continue troubleshooting this issue on the other thread:
https://forums.intel.com/s/question/0D50P00004guiCA
Wanner G.
