Wireless
8693 Discussions
AX201 and AX211 compatible?
PeeP
Hello, I have an asus rog strix g17 with cpu i710750H, I had an intel ax201 mounted, I decided to upgrade my network card to Intel AX211 because I saw that it was compatible with the chipset. Once mounted it does not work but is recognized as a network controller and bluetooth with a triangle and an error code 54. I would like to understand how I can solve this problem.
Bluetooth driver:
Problema di avvio del dispositivo USB\VID_8087&PID_0033\5&2ad35be9&0&14.
Nome driver: oem83.inf
GUID classe: {e0cbf06c-cd8b-4647-bb8a-263b43f0f974}
Servizio: BTHUSB
Filtri inferiori: ibtusb
Filtri superiori:
Problema: 0x0
Stato problema: 0xC00000E5
Network controller:
Il dispositivo PCI\VEN_8086&DEV_06F0&SUBSYS_00948086&REV_00\3&11583659&0&A3 è stato configurato.
Nome driver: null
GUID classe: {00000000-0000-0000-0000-000000000000}
Data driver:
Versione driver:
Provider driver:
Sezione driver:
Classificazione driver: 0x0
ID dispositivo corrispondente:
Driver prioritari:
Aggiornamento dispositivo: false
Dispositivo padre: ACPI\PNP0A08\0
Jean_Intel
Hello PeeP,
Thank you for posting on the Intel️® communities. We understand that you are having issues after upgrading your wireless adapter.
As each country may have different regulatory requirements, before you install/change the Intel® Wireless Adapter in a system, you must contact the system manufacturer to determine if the Intel® Wireless Adapters you plan to install are approved for use in your system and country. You are required to follow the manufacturer's post-approval requirements.
Your system manufacturer may have altered the features, incorporated customizations, or made other changes to the software or hardware packaging they provide. Since you have already performed the integration, it is also important to understand that it may not work due to hardware or software compatibility issues or dependencies. You should contact Asus Support to confirm if the AX211 is compatible with your system and the proper integration steps you must follow.
Jean O.
Jean_Intel
Hello PeeP,
We hope you are doing fine.
Best regards.
Jean O.
3Fees
Negative, Intel AX211 requires Intel 600 series chipset. 400, 500 series chipsets wont work-only use AX201, old news. Intel released the AX211 before it was compatible with laptops on the market, big marketing error. When buying a laptop make sure the chipset is what your want before you buy, the bling of processors should not be your only consideration. I have seen several laptops with 12th Gen Intel processors and not 600 series chipset, they cannot upgrade as well using AX201, AX211-Wifi-6E with intel processors require 600 series chipset and cnvio2 connector.
Cheers
3Fees
PeeP
Ok, thanks for the info. My chipset is 400 series so not compatible with AX211.
Do you advise me which wifi card to take to eliminate the problem I have with the AX201 card?
3Fees
I'm using the Intel AX201 WiFi card as well and have 400 series chipset. I researched the whole issue and found out and returned the AX211 card I bought before I installed it. The AX 201 is plenty can accommodate up 2.4Gbs running at 160Mhz,,right now I'm connected at 1.2Gbs  and very stable. 6E requires a 6E wifi card and 6E  wifi router with 600 series chipset for Intel processors to run 6Ghz band, cost of which is ramped up for 6E wifi routers.
      I'd stick with the Intel AX201 if your having problems with it do a clean install, then use Intel wifi software/drivers-latest version of driver. Delete network ect, right down password to your wifi router which should be a wifi 6 router, many around for not too much money.
Cheers
3Fees
lollyter
Hi sono andato sul sito intel per istallare i driver ma dovo un tentativo di refresh la pagina cita:
Invalid configuration data con un pallino rosso
Invalid configuration data. Please click "Refresh Results" to try again.
se potete ditemi come fare
