Wireless
8846 Discussions
AX201 unstable connection on Ubuntu 20.04
kiraliu7
Hi! I just built a linux system but the wifi is so unstable it disconnects every couple minutes. Ubuntu is the only OS on my computer. I need to switch wifi on and off to reestablish connection. I tried to refer to this thread on the forum and installed newest firmware (iwlwifi-Qu-*-59) but the issue persists.
I am using the onboard intel AX201on ROG H470i mobo.  Kernel is 5.8.0
Maria_R_Intel
Hello kiraliu7,
Thank you for posting on the Intel® communities.
1. Run Intel® System Support Utility for the Linux* Operating System for more details: https://downloadcenter.intel.com/download/26735/Intel-System-Support-Utility-for-the-Linux-Operating...
3. Run the following commands and send us the outcome:
  • modinfo iwlwifi > If there is no output, then the module isn’t installed this is the distribution installation issue.
  • lsmod | grep iwlwifi > If the result is empty, the driver hasn't been loaded. Most likely to be a distribution issue.
  • To verify, please type: dmesg | grep iwlwifi > If the result is empty, the driver wasn’t initialized and this is a distribution issue. If there is a result populated, proceed with the next step.
  • dmesg | grep “no suitable firmware found!” > If the result is not empty, it means you don't have a suitable FW (api mentioned in the dmesg).
  • Please visit here: h ttps://wireless.wiki.kernel.org/en/users/drivers/iwlwifi  for supported FW,  or here https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ for the latest versions.
4. If the above steps don't work, collect the debug data:
Type: dmesg | grep ASSERT
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging  to extract dmesg and trace-cmd.
If the output has value, please collect it from the wiki FW dump too.
Maria R.
kiraliu7
Thanks for the advice! I tried these steps and unfortunately its still not working. I am attaching the logs to this comment
Maria_R_Intel
Hello kiraliu7,
Thank you for letting us know the outcome.
I will proceed to check the case internally and post back soon with more details.
Maria R.
Maria_R_Intel
Hello kiraliu7,
Thank you for patiently waiting, please follow these steps:
1) Your dmesg log indicates the Wi-Fi fails to load the matching firmware 56 for kernel 5.8.
Please try to load the FW 56 successfully and check if the issue still occurs.
Line 957: [  3.250465] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-56.ucode failed with error -2
2) Does the slow speed issue occur when connecting to the Wi-Fi router at 2.4 GHz band?
If so, please try to connect to the router at the 5 GHz band and see if the issue improves
3). According to the post https://askubuntu.com/questions/1230525/ubuntu-20-04-network-performance-extremely-slow?newreg=89f454f5c3714071a14949ed391721f9 , please have customer check if this issue can be fixed by:
Option 1:
editing /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf and then change the value wifi.powersave from 3 to 2, save the changes and reboot the system.
Option 2:
Remove the backport-iwlwifi-dkms package, type: $ sudo apt remove backport-iwlwifi-dkms
Maria R.
Maria_R_Intel
Hello kiraliu7,
Let me know if you need more assistance.
Maria R.
kiraliu7
Hi Maria,
Thanks for the update. However, it seems that i can not find iwlwifi-QuZ-a0-hr-b0-56.ucode anywhere. Can you send me a download link?
Maria_R_Intel
Hello kiraliu7,
Sure, please let me ask for the link and I will post back soon.
Maria R.
Maria_R_Intel
Hello kiraliu7,
Thank you for patiently waiting.
It seems the iwlwifi-QuZ-a0-hr-b0-56.ucode is no longer available at git tree (https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/), which makes your current firmware 'QuZ-a0-hr-b0-55.ucode' the Max version available for his Kernel 5.8.
In this way, please try the 2) and 3), and let us know if the AX201 works better.
i.e.
Option 1:
Option 2:
Maria R.
Maria_R_Intel
Hello kiraliu7,
Maria R.
kiraliu7
Thanks for the update! Unfortunately I am in Texas and suffering from outage so I wont be able to check it until utility comes back.
Maria_R_Intel
Hello kiraliu7,
Thank you for let us know!
Don't worry we will keep your thread open and may do a follow-up at the end of the next week if we don't have a response for you.
I hope you have a great weekend!
Maria R.
DeividA_Intel
Hello kiraliu7,
Were you able to check the previous post? And were you able to try the steps recommended? Please let me know if you need more assistance.
Maria_R_Intel
Hello kiraliu7,
Please let us know if you need extra time to test and complete the steps.
Maria R.
Maria_R_Intel
Hello kiraliu7,
Maria R.
