Wireless
8851 Discussions
AX201 unstable ubuntu 22.04 (kernel 5.15.0)
FS6
My wifi connexion is very unstable with iwlwifi-Quz-a0-hr-b0-66.ucode firmware
Works better with iwlwifi-Quz-a0-hr-b0-48.ucode but becomes unstable after a few hours
Have tried iwlwifi-Quz-a0-hr-b0-63.ucode but with not much success than iwlwifi-Quz-a0-hr-b0-66.ucode.
Not sure if it is relevant to test all firmwares ???
Any ideas ?
DeividA_Intel
Hello FS6,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Wi-Fi 6 AX201 (Gig+).
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
2. Is this a laptop or desktop computer?
3. What is the brand and model name of your laptop or motherboard (if desktop computer)?
4. Have you tested this issue with Windows 10 or Windows 11?
5. Was this working before? If so, which firmware was working?
6. Is the issue present with both bands (2.4GHz and 5GHz)?
Deivid A.
FS6
Hello Deivid,
Thank you for your quick answer !
This is an original adapter on a Clevo Laptop NK70KJ
Not tested in windows
Not sure if it is new or not, the regular user says it never worked well ... so...
I m trying with 2.4 GHz band only, and I didn't experienced problems since this morning. I ll keep you informed on a more extended period of time
DeividA_Intel
Hello FS6,
Thanks for your response. Please let me know as soon as the issue returns.
also, I would appreciate it if you share the following information once the issue comes back:
1. Can you test the 5GHz band to confirm if the issue is present with both bands?
2. What was the firmware version that was not giving you the issue?
Deivid A.
DeividA_Intel
Hello FS6,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
FS6
Hello Deivid,
The user didn't get any more unstabilities since I switched to 2.4 GHz band.
Didn't get yet the opportunity to check if 5 GHz band is not OK.
I ll make an update when it is done !
Thank you again for your help
Best regards
FS6
Concerning the firmware, I switched back to iwlwifi-Quz-a0-hr-b0-66.ucode
Before disabling 5GHz band, no firmware was satisfactory. I think it was more stable with iwlwifi-Quz-a0-hr-b0-48.ucode
DeividA_Intel
Hello FS6,
Thanks for the information provided. In order to investigate this issue further I would like to confirm the following:
1. Provide the Intel® System Support Utility for the Linux* Operating System for more details:
2. Run the following commands and send us the outcome:
  • modinfo iwlwifi > If there is no output, then the module isn’t installed this is the distribution installation issue.
  • lsmod | grep iwlwifi > If the result is empty, the driver hasn't been loaded. Most likely to be a distribution issue.
  • To verify, please type: dmesg | grep iwlwifi > If the result is empty, the driver wasn’t initialized and this is a distribution issue. If there is a result populated, proceed with the next step.
  • dmesg | grep “no suitable firmware found!” > If the result is not empty, it means you don't have a suitable FW (api mentioned in the dmesg).
  • Please visit here: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi for supported FW, or here https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ for the latest versions.
3. If the above steps don't work, collect the debug data:
  • Type: dmesg | grep ASSERT
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging to extract dmesg and trace-cmd.
If the output has value, please collect it from the wiki FW dump too.
Deivid A.
DeividA_Intel
Hello FS6,
I was reviewing your thread, I would like to know if you were able to check my previous post.
Deivid A.
DeividA_Intel
Hello FS6,
I was checking your thread and see that we have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
I recommend you check this issue with Clevo to confirm if there is a malfunction with the laptop or if there is an incompatibility with Linux.
Deivid A.
