Wireless
8606 Discussions
AX201NGW SOMETIMES cannot connect to 5GHz WiFi
dusky
I’m using MSI GF63 Thin10SCXR with Intel AX201NGW. I have installed multiple driver version (from manufacturer version 19 to the latest 22) of AX201, all failed to connect to 5GHz network. It said connect but no internet, but actually it couldn’t connect to LAN and there is internet connection from the router (my iphone works well on the same 5ghz network). It hasn’t been like this before, only very recently. I have been using the laptop for almost 3 years. Is this a software problem? If the problem is the hardware, what can I do to verify?
dusky
Turns out something was covering my network card and I took the liberty to remove it and now I can connect to 5ghz 80mhz again?…
