Wireless
8636 Discussions
AX210 Bluetooth not appearing/working in Windows 11
Vampire
(this is a copy of a post I've made in ISC Discord)
I've just got the AX210 installed on my pc, and downloaded the wireless+bluetooth driver for it. But the bluetooth just don't work, it didn't even show up in windows settings.
The Wi-Fi works, only the bluetooth is having problems.
This is the Wi-Fi driver that i downloaded: https://www.intel.com/content/www/us/en/download/19351/867870/intel-wireless-wi-fi-drivers-for-windows-10-and-windows-11.html
Bluetooth: https://www.intel.com/content/www/us/en/download/18649/intel-wireless-bluetooth-drivers-for-windows-10-and-windows-11.html
Here's what I've done already:
Install the card
Download+install the wireless driver
Reboot
Finds out that bluetooth doesn't show up in the settings
Download+install the bluetooth driver
Reboot
Bluetooth still doesn't show up
Follow this post: https://community.intel.com/t5/Wireless/Intel-AX210-Bluetooth-is-sometimes-missing-and-I-need-to-shut/m-p/1584926
At step 2 i can't seem to find the uninstall button for the Intel PROSet/Wireless Software, so i just skip it.
Uninstall the bluetooth driver
Keep following the post till the last step
The bluetooth is still not appearing in the settings
PC Specs:
MSI PRO H610M-S
Intel i5-12400F
Intel Arc B580 (32.0.101.8250)
32 GB DDR4-3200
1TB SSD Gen 3 NVMe
2 SATA SSDs (one 1TB one 2TB)
Windows 11 Home (last update: KB5066835, 26100.6899)
Vampire
note: it's IIC discord not ISC.
The card did show up in the Device Manager, but it only shows up the "Network Adapters" tab, there's no tabs for bluetooth.
RandyT_Intel
Hi @Vampire,
Thank you for posting in the community. I’ll need some additional time and information to investigate this issue. Kindly provide the following details:
  • Please provide the SSU log report and share it here so I can review your system's configuration.
  • Is this a newly added component to the system?
    • If yes, what was the previous Wi-Fi card?
  • Did it work initially after installation?
    • Were you able to see and use it, or has it never worked?
  • Do you see any error messages in Device Manager?
    • If yes (or none), please provide a screenshot showing the adapter’s status and any reported details.
  • Are there any pending Windows updates on the system?
  • Have you tried updating the motherboard BIOS or at least loading it to default settings for isolation purposes?
  • Have you consulted the motherboard manufacturer prior to installing this card?
    • If yes, what was their advice?
Intel Wireless Bluetooth typically operates over the USB interface. If Bluetooth is not detected, you have to check the USB controller and ensure USB drivers are functioning properly with no reported errors.
Randy T.
Vampire
  • Please provide the  SSU report and share it here so I can review your system's configuration.
Here’s the SSU log. (ISSU.txt)
Yes, this is a newly added component to the system.
I didn’t originally have a Wi-Fi card; I only used Ethernet on this PC.
Yes, but only the Wi-Fi works right after installation. Bluetooth has never worked.
It does show up in the Device Manager under Network Adapters right after I install it, but there’s no Bluetooth entry anywhere in Device Manager.
There are no error messages in Device Manager (Device status.png).
However, there are four drivers listed in this device’s properties (Driver1–4.png).
At the time of writing this, yes (Update.png, KB5068861).
When I originally made the post? No.
I wasn't gonna update windows for some time (like 5 weeks)
But when i finished the BIOS update, Windows automatically updated to KB5068861 (I do NOT want to update), I heard there's issue with this update, but I'm not gonna revert it.
If anything bad happens with this update I'll let you know.
I have done the BIOS update when I'm writing this (https://tw.msi.com/Motherboard/PRO-H610M-S-DDR4/support)
and restore to default setting in the BIOS, but the Bluetooth still doesn't work.
No, i haven't.
RandyT_Intel
Hi @Vampire,
Thank you for providing the requested information. It appears you’ve already completed all the troubleshooting steps I would normally recommend. I’ll coordinate internally for a deeper investigation and share an update here once my analysis is complete. Thank you for your patience.
Randy T.
