Wireless
8913 Discussions
AX210 Compatibility
91A
Hi all. Currently considering upgrading my laptop (Asus Rog Strix G531GV) which has the Intel AC9560 wifi card. I was wondering if the AX210 with Wifi 6E will be compatible? Tried looking it up online but couldn't find much info. Many thanks!
n_scott_pearson
It is possible that you might be able to use the AX200, AX210 or BE200. I say 'might' because there have been some cases where installing a non-CNVi part like these into this CNVI connector caused the machine to not pass POST. Unfortunately, I know of no way to know other than to try it.
Hope this helps,
P.S. You cannot use the AX201, AX211 or AX411 CNVi parts as the chipset on your board does not have support for these parts.
