Hello, we will certifed two devices in CHINA SRRC with two Intel wireless modules:looking for SW support to set following functions for certification and compliance testing.
Thank you,
In Wifi
Function to select the channel
Function to select the power output in dBm
Function to change Antenna mode
Function to change Transmission rates in Mbps
Selection of bandwidth (For example 20MHz, 40MHz)
In Bluetooth
Selection of TX or RX tests
Selection of frequency in MHz
Selection of TX or RX testsSelection of modulation mode (GFSK, DQPSK, BLE etc.)
Selection of test patterns
Selection of power level
Hello J-Paul,
Thank you for posting in the communities. I will be sending you a private message regarding this inquiry.
Ramyer M.
Hi Ramyer,
We have exactly the same problem. Can you help me also with some tool for the Chinese certification lab.
best Pascal
