Wireless
9023 Discussions
AX210 certifications under Linux with ARM
PPB
i tried to get support in this ticket, but didnt get response, so i try here:
https://community.intel.com/t5/Wireless/AX210-certifications-under-Linux-with-ARM-and-AX211/m-p/1576184/thread-id/52738
We need for certification a tool like j-paul discribed:
Hello, we will certifed two devices in CHINA SRRC with two Intel wireless modules:looking for SW support to set following functions for certification and compliance testing.
Thank you,
In Wifi
Function to select the channel
Function to select the power output in dBm
Function to change Antenna mode
Function to change Transmission rates in Mbps
Selection of bandwidth (For example 20MHz, 40MHz)
In Bluetooth
Selection of TX or RX tests
Selection of frequency in MHz
Selection of TX or RX testsSelection of modulation mode (GFSK, DQPSK, BLE etc.)
Selection of test patterns
Selection of power level
Mike_Intel
Hello PPB,
  1. Can you further explain the specific documentation that you are requesting?
  2. May I know why do you need these documents?
  3. Can you also tell me the purpose of the system that you are building?
Michael L.
PPB
Hi Michael
we want to certify one of our device in China with SRRC. They (the chinese lab) ask for a tool with the described functions above for the measurement process.
It is not that we need a document, we need a Software tool for them. We are using a Linux System which run on a ARM architecture.
We build streaming devices for music, like streaming amplifiers.
Pascal
Mike_Intel
Hello PPB,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Mike_Intel
Hello PPB,
Thank you for patiently waiting for our update.
I sent you an e-mail to the e-mail address associated with your community profile regarding the information you are looking for, please check it out.
Michael L.
