Wireless
8667 Discussions
AX210 iwlwifi /iwlmvm driver crash while connecting to Station
Avinash1992
Hi Team,
We are using kernel's 6.1.36 Intel Ax210 wifi driver, we configured the device in Access point (hostapd-2g attached) mode with 2.4 GHz band and WIFI 6 protocol and when we tried to connect this AP device to STA, we observed the crash in iwlwifi /iwlmvm (driver crashlog attached).
[ 5451.469516] Workqueue: events iwl_mvm_tcm_work [iwlmvm]
[ 5451.474821] Call trace:
[ 5451.477268] dump_backtrace.part.0+0xe0/0xf0
[ 5451.481551] show_stack+0x18/0x30
[ 5451.484872] dump_stack_lvl+0x64/0x80
[ 5451.488541] dump_stack+0x18/0x34
[ 5451.491863] iwl_trans_txq_send_hcmd+0x444/0x450 [iwlwifi]
[ 5451.497440] iwl_trans_send_cmd+0x64/0x120 [iwlwifi]
[ 5451.502477] iwl_mvm_send_cmd+0x1c/0x50 [iwlmvm]
[ 5451.507153] iwl_mvm_config_scan+0xcc/0x170 [iwlmvm]
[ 5451.512175] iwl_mvm_recalc_tcm+0x3a0/0x5b0 [iwlmvm]
[ 5451.517196] iwl_mvm_tcm_work+0x18/0x24 [iwlmvm]
[ 5451.521871] process_one_work+0x1d4/0x330
[ 5451.525887] worker_thread+0x6c/0x430
[ 5451.529553] kthread+0x108/0x10c
[ 5451.532787] ret_from_fork+0x10/0x20
Jose_Intel
Hello @Avinash1992
Thank you for posting on the Intel️® communities.
We sincerely regret you are experiencing issues with your Intel® Wi-Fi 6E AX210 (Gig+), we will be more than happy to assist you.
Please keep in mind that Linux drivers are part of the upstream Linux* kernel. They're available through the regular channels, distributions, or the Linux* kernel archives. We highly recommend updating it, please let us know.
Jose B.
Avinash1992
Hi Jose,
Can we use 6.6.8 kernel version driver for AX210, version is stable. also, do we also need cfg80211 module, in order to enable wifi 6 capabilities?
Avi
Jose_Intel
Hello Avinash1992
Thank you for your reply.
That is ok, you can use the version 6.6.8, since that is a stable version.
Regarding cfg80211, yes, you will need it.
Jose B.
DeividA_Intel
Hello Avinash1992,
I am getting back to you because I would like to know if you were able to update your Linux firmware/kernel to version 6.6.8. I will wait for an update on this matter.
Deivid A.
Jose_Intel
Hello Avinash1992
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
Avinash1992
Hi Jose,
Does Intel AX210 radio support access point mode configuration ?
Avinash
