Wireless
8531 Discussions
AX210 sometimes connect failed on Jetson Orin NX
WilsonASRI
Hi all,
I’m testing AX210 on Orin NX.
L4T version is 35.3.1.
According to this link post, the AX210 BT doesn’t work is a know issue with kernel 5.10.
https://community.intel.com/t5/Wireless/AX210-bluetooth-not-working-on-jetson-xavier-nx-on-linux-kernel/m-p/1448385/highlight/true
The WiFi is worked on Orin NX and L4T 35.3.1.
I can use it to connect internet.
But it connect failed many times when I try to connect WiFi router.
If it connect pass, the internet is worked fine.
I can’t find any error log in the dmesg when it connect failed.
Does anyone can help us or share experience? Thanks a lot.
DeividA_Intel
Hello WilsonASRI,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Wi-Fi 6E AX210.
1. Just to confirm, are you connecting the Jetson Orin™ NX to a laptop or desktop computer?
2. Is this the original wireless adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Is the Bluetooth working?
4. Just to confirm, you are able to connect to the internet using an ethernet cable and not using Wi-Fi, is that right?
5. Was the Wi-Fi option working before with your Jetson Orin NX? If so, when did the issue start?
6. What is the operating system installed as well as the kernel and version?
Deivid A.
WilsonASRI
Hi Deivid,
Thanks your reply.
1. Orin NX is a arm base computer. We don't connnect it to a laptop or desktop computer.
2. There is a M.2 E-key PCIE on our custom carrier board. We wnat to use AX210 on the carrier board so we install AX210 on it.
3. No BT of AX210 is not worked. Just like the post.
https://community.intel.com/t5/Wireless/AX210-bluetooth-not-working-on-jetson-xavier-nx-on-linux-kernel/mp/1448385/highlight/true
4. Yes, connect to the internet using an ethernet cable.
5. The issue is start form the beginning when I use AX210 on Orin NX .
6. Nvidia L4T 35.3.1 (Ubuntu 20.04) and kernel 5.10.
DeividA_Intel
Hello WilsonASRI,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello WilsonASRI,
Thanks for the information provided. I will proceed to check the issue internally and post back soon with more details.
Deivid A.
DeividA_Intel
Hello WilsonASRI,
Thanks for your patience. In order to continue, please try to upgrade to the latest stable kernel. You may need to check with your Linux distributor for installation instructions.
Deivid A.
DeividA_Intel
Hello WilsonASRI,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
WilsonASRI
CharlesJoseph
Hi @WilsonASRI ,
It's good to hear that the problem is fixed.
I'm also facing similar problem with Intel AX210 in Nvidia Jetson Orin NX Development kit. For me, Intel AX210 does not even detect/scan any wifi network. WiFi chipset/interface is detected but, it is not detecting any WiFi network as it is showing No Networks.
Can you please share the method/solution that you have followed to resolve the issue? It would be very helpful for me.
Note:
I have not connected antenna to the WiFi chipset but, i don’t think it is an issue.
Firmware Installation:
  1. wget https://github.com/mistelektronik/forecr_blog_files/raw/master/Intel/AX210_driver.zip 1
  2. unzip AX210_driver.zip
  3. cd AX210_driver/
  4. sudo ./apply_patch.sh
  5. Reboot
Setup Details:
Jetson: Orin NX
Jetpack: 5.1.2
Jetson linux: 35.4.1-20230801124926
ubuntu: 20.04.6 LTS,
linux kernel: 5.10.120-tegra
root@test-desktop:/home/test/jetsonUtilities# dmesg | grep -i “iwlwifi”
[ 11.633211] iwlwifi 0001:01:00.0: Adding to iommu group 7
[ 11.633624] iwlwifi 0001:01:00.0: enabling device (0000 → 0002)
[ 11.665220] iwlwifi 0001:01:00.0: api flags index 2 larger than supported by driver
[ 11.676028] iwlwifi 0001:01:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 93.8.63.28
[ 11.676487] iwlwifi 0001:01:00.0: loaded firmware version 59.601f3a66.0 ty-a0-gf-a0-59.ucode op_mode iwlmvm
[ 11.950380] iwlwifi 0001:01:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 12.185734] iwlwifi 0001:01:00.0: base HW address: 88:d8:2e:e5:24:5f
root@test-desktop:/home/test/jetsonUtilities# ifconfig wlan1
wlan1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 88:d8:2e:e5:24:5f txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
DeividA_Intel
Hello WilsonASRI,
Thanks for the confirmation. I am glad to know that know the Intel® Wi-Fi 6E AX210 (Gig+) is working properly with your Jetson Orin NX.
I will proceed to close this thread, however, you can open a new one in case you need further support or if you face any issues with our products.
Deivid A.
