Wireless
8652 Discussions
AX210NGW LED signals
Yamagy
I think the AX210NGW has two LED signals on the M.2 E key.
LED1# (6 pin) indicates the Wi-Fi status.
Does LED2# (16 pin) indicate the Bluetooth status ?
Is LED2# not working ?
Mike_Intel
Hello Yamagy,
  1. Can you tell me more about this inquiry?
  2. Are you designing system with embedded AX210?
  3. Are you also asking for the pinout on the LED light?
  4. Or you have a system and the LED of the embedded AX210 is not working?
Michael L.
Yamagy
Dear Michael
Thank you for your reply.
I am designing an embedded device using the Jetson Orin NX.
I understand that the pinout for a general M.2 E-Key is as follows:
https://w.electrodragon.com/w/M.2_Pins#M.2_Key_E
On the AX210NGW, I have confirmed that pin 6 (LED1#) indicates Wi-Fi status.
  Low Level: Wi-Fi connect
  High-Z(Open Drain): Not connect
I assumed that pin 16 (LED2#) indicates BT status, but even when the AX210 connects to a BT device, the signal on pin 16 remains fixed at High-Z.
Please let me know if my assumption regarding pin 16 behavior is incorrect.
By the way, Wi-Fi and BT work without any issues when using the AX210NGW with the Jetson Orin NX.
Yamagy
n_scott_pearson
From EPS publicly available on https://fcc.report (whether it should be or not).
Bluetooth LED functionality:
1. LED is OFF when the Bluetooth is in HW or SW RF kill (SW RF kill means also driver disable, etc.).
2. LED is ON otherwise.
Wi-Fi LED functionality:
1. LED is OFF when the Wi-Fi is not powered or in RF kill.
Hope this helps,
Mike_Intel
Hello Yamagy,
Thank you for the quick reply.
Regarding pin assignment and other interfacing information about wireless products. We have a different department who have that information.
You need to contact Intel® Resource & Documentation Center (RDC). Please refer to the link below:
Where to Get the Datasheet for Intel® Wireless Adapters?
Michael L.
Mike_Intel
Hello Yamagy,
@n_scott_pearson
Thanks for the assistance.
Michael L.
Mike_Intel
Hello Yamagy,
I am sending another follow up and I hope you are now talking to RDC regarding this inquiry.
Michael L.
