Wireless
9026 Discussions
AX211: Large Difference In TX and RX Rates
DallasP
Dell XPS 13 Plus 9320 with AX211 Wi-Fi. All drivers up to date.
Router is a GL.iNet Flint 2 (GL-MT6000) running OpenWrt 24.10.4
Windows: netsh wlan show interface
    Band                   : 5 GHz
    Channel                : 104
    Connected Akm-cipher   : [ akm = 00-0f-ac:08, cipher =  00-0f-ac:04 ]
    Network type           : Infrastructure
    Radio type             : 802.11ax
    Authentication         : WPA3-Personal  (H2E)
    Cipher                 : CCMP
    Connection mode        : Auto Connect
    Receive rate (Mbps)    : 1922
    Transmit rate (Mbps)   : 865
    Signal                 : 83%
    Rssi                   : -58
On the Router: iw dev phy1-ap0 station get '<mac address of laptop'
        signal:         -80 [-88, -83, -87, -86] dBm
        signal avg:     -79 [-85, -82, -85, -88] dBm
        tx bitrate:     1729.6 MBit/s 160MHz HE-MCS 8 HE-NSS 2 HE-GI 0 HE-DCM 0
        rx bitrate:     576.4 MBit/s 160MHz HE-MCS 3 HE-NSS 2 HE-GI 0 HE-DCM 0
        last ack signal:-70 dBm
        avg ack signal: -73 dBm
I tried many power and advanced adapter settings and I cannot get the TX close to the RX rate.
The HE-MCS values explain the differences, but why?
Thanks all.
JedG_Intel
Hello DallasP,
To address the issue properly, please share the information below.
1. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
2. Were you able to have wireless connection in a normal/expected performance before?
3. Do you remember if this issue happened after a new OS update or Wireless driver update?
4. What driver version are you using?
5. Is this issue happening at home, office environment or both?
Best regards
Jed G.
DallasP
Hi Jed,
- It is the original adapter that came pre-installed in the laptop.
- Yes
- No, it has been happening for at least a year.
- Intel 23.170.0.1
Both
Thanks in advance for your help!
JedG_Intel
Hello DallasP,
Thank you for sharing all this information. To proceed, could you kindly generate a System Support Utility report so we can review your system components and configuration? You can follow the steps outlined here: . You can follow the steps here: How to get the Intel® System Support Utility Logs on Windows*
Additionally, have you had the opportunity to try installing the drivers from Dell? We strongly recommend using drivers provided by your system manufacturer, as these are specifically customized to ensure full compatibility and optimal performance with your device.
If you have any questions, please let me know.
Best regards
Jed G.
DallasP
System Support Utility file attached.
The drivers from Dell are the same version as from Intel. Just one release old that already had the same issue.
JedG_Intel
Hello DallasP,
Thank you for providing the System Support Utility report—I really appreciate your effort in sharing that. After reviewing the manufacturer’s website, I found that the latest available driver version is 36.25.3247. Could you please try installing this version even though this is older than the one coming from Intel and let me know how it goes? If the issue continues to persist after updating, feel free to reach out so we can explore the next steps together.
Best regards
Jed G.
JedG_Intel
Hi DallasP,
I wanted to check if you had the chance to review the recommendation I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
DallasP
Yes, I installed the driver from Dell's website.
I'm still seeing differences in Receive and Transmit rates.
Receive rate (Mbps) : 1297
Signal : 80%
Rssi : -66
JedG_Intel
Hello DallasP,
Thank you for attempting the recommended steps. Since the issue persists, I will need to conduct an internal investigation to determine the next course of action. I will provide you with an update as soon as additional information becomes available.
Best regards
Jed G.
JedG_Intel
Hello DallasP,
I'm reaching out to provide you with an update. After reviewing the System Support Utility logs, it shows that:
Mixed Mode Protection: RTS/CTS Enabled (0)
  • For a stable home network (-35 dBm to -55 dBm, no interference or legacy devices):
Change to: CTS-to-self Enabled (1) → This can improve TX rates.
  • For office or public networks: Keep RTS/CTS Enabled (Mixed Mode Protection).
Also, at -80 dBm signal strength, it’s normal for RX rates to be higher than TX rates due to factors like antenna chains and AP power levels being greater than the client.
If the issue persists, please let me know.
Best regards
Jed G.
VonM_Intel
Hello DallasP,
Best regards
Von M.
JedG_Intel
Hello DallasP,
Jed G.
DallasP
