Wireless
8661 Discussions
Ax210 can’t work in 5GHz mode for AP(Ubuntu20.04)
ChunjieHao
It should have something to do with Regulatory Domain,  and  we try to bypass it with the command “iw reg set US”, but failed.
Would you like to help me how to bypass it?
The print from "iw" command as below:
exhxhnc@wifi1:~$ iw list
Wiphy phy0
max # scan SSIDs: 20
max scan IEs length: 365 bytes
max # sched scan SSIDs: 20
max # match sets: 8
Retry short limit: 7
Retry long limit: 4
Coverage class: 0 (up to 0m)
Device supports RSN-IBSS.
Device supports AP-side u-APSD.
Device supports T-DLS.
Supported Ciphers:
* WEP40 (00-0f-ac:1)
* WEP104 (00-0f-ac:5)
* TKIP (00-0f-ac:2)
* CCMP-128 (00-0f-ac:4)
* GCMP-128 (00-0f-ac:8)
* GCMP-256 (00-0f-ac:9)
* CMAC (00-0f-ac:6)
* GMAC-128 (00-0f-ac:11)
* GMAC-256 (00-0f-ac:12)
Available Antennas: TX 0x3 RX 0x3
Configured Antennas: TX 0x3 RX 0x3
Supported interface modes:
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* P2P-client
* P2P-GO
* P2P-device
Band 1:
Capabilities: 0x19ef
RX LDPC
HT20/HT40
SM Power Save disabled
RX HT20 SGI
RX HT40 SGI
TX STBC
RX STBC 1-stream
Max AMSDU length: 7935 bytes
DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 4 usec (0x05)
HT Max RX data rate: 300 Mbps
HT TX/RX MCS rate indexes supported: 0-15
HE Iftypes: Station
HE MAC Capabilities (0x78031220abc0):
+HTC HE Supported
TWT Requester
Trigger Frame MAC Padding Duration: 2
Multi-TID Aggregation Support: 7
32-bit BA Bitmap
OM Control
Maximum A-MPDU Length Exponent: 2
A-MSDU in A-MPDU
Multi-TID Aggregation TX: 7
UL 2x996-Tone RU
HE PHY Capabilities: (0x0e3f0200fd09800ecff200):
HE40/2.4GHz
HE40/HE80/5GHz
HE160/5GHz
Punctured Preamble RX: 15
Device Class: 1
LDPC Coding in Payload
NDP with 4x HE-LTF and 3.2us GI
SU Beamformee
Beamformee STS <= 80Mhz: 7
Beamformee STS > 80Mhz: 7
Sounding Dimensions <= 80Mhz: 1
Sounding Dimensions > 80Mhz: 1
PPE Threshold Present
Power Boost Factor ar
HE SU PPDU & HE PPDU 4x HE-LTF 0.8us GI
Max NC: 1
HE ER SU PPDU 4x HE-LTF 0.8us GI
20MHz in 40MHz HE PPDU 2.4GHz
20MHz in 160/80+80MHz HE PPDU
80MHz in 160/80+80MHz HE PPDU
DCM Max BW: 3
Non-Triggered CQI Feedback
RX Full BW SU Using HE MU PPDU with Compression SIGB
RX Full BW SU Using HE MU PPDU with Non-Compression SIGB
HE RX MCS and NSS set <= 80 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
3 streams: not supported
4 streams: not supported
5 streams: not supported
6 streams: not supported
7 streams: not supported
8 streams: not supported
HE TX MCS and NSS set <= 80 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
HE RX MCS and NSS set 160 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
HE TX MCS and NSS set 160 MHz
1 streams: MCS 0-11
2 streams: MCS 0-11
PPE Threshold 0x61 0x1c 0xc7 0x71
HE Iftypes: AP
HE MAC Capabilities (0x780112080840):
+HTC HE Supported
BSR
OM Control
A-MSDU in A-MPDU
UL 2x996-Tone RU
HE PHY Capabilities: (0x0e200200fd09800ccff000):
HE40/2.4GHz
HE40/HE80/5GHz
HE160/5GHz
SU Beamformee
Max NC: 1
DCM Max BW: 3
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
Bitrates (non-HT):
* 1.0 Mbps
* 2.0 Mbps (short preamble supported)
* 5.5 Mbps (short preamble supported)
* 11.0 Mbps (short preamble supported)
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 2412 MHz [1] (22.0 dBm)
* 2417 MHz [2] (22.0 dBm)
* 2422 MHz [3] (22.0 dBm)
* 2427 MHz [4] (22.0 dBm)
* 2432 MHz [5] (22.0 dBm)
* 2437 MHz [6] (22.0 dBm)
* 2442 MHz [7] (22.0 dBm)
* 2447 MHz [8] (22.0 dBm)
* 2452 MHz [9] (22.0 dBm)
* 2457 MHz [10] (22.0 dBm)
* 2462 MHz [11] (22.0 dBm)
* 2467 MHz [12] (22.0 dBm)
* 2472 MHz [13] (22.0 dBm)
* 2484 MHz [14] (disabled)
Band 2:
RX LDPC
HT20/HT40
RX HT20 SGI
RX HT40 SGI
TX STBC
RX STBC 1-stream
DSSS/CCK HT40
VHT Capabilities (0x039071f6):
Max MPDU length: 11454
Supported Channel Width: 160 MHz
RX LDPC
short GI (80 MHz)
short GI (160/80+80 MHz)
TX STBC
SU Beamformee
MU Beamformee
VHT RX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
VHT RX highest supported: 0 Mbps
VHT TX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
VHT TX highest supported: 0 Mbps
HE Iftypes: Station
+HTC HE Supported
TWT Requester
32-bit BA Bitmap
OM Control
A-MSDU in A-MPDU
UL 2x996-Tone RU
HE40/2.4GHz
HE40/HE80/5GHz
HE160/5GHz
Device Class: 1
SU Beamformee
Max NC: 1
DCM Max BW: 3
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
HE Iftypes: AP
+HTC HE Supported
BSR
OM Control
A-MSDU in A-MPDU
UL 2x996-Tone RU
HE40/2.4GHz
HE40/HE80/5GHz
HE160/5GHz
SU Beamformee
Max NC: 1
DCM Max BW: 3
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 5180 MHz [36] (22.0 dBm) (no IR)
* 5200 MHz [40] (22.0 dBm) (no IR)
* 5220 MHz [44] (22.0 dBm) (no IR)
* 5240 MHz [48] (22.0 dBm) (no IR)
* 5260 MHz [52] (22.0 dBm) (no IR, radar detection)
* 5280 MHz [56] (22.0 dBm) (no IR, radar detection)
* 5300 MHz [60] (22.0 dBm) (no IR, radar detection)
* 5320 MHz [64] (22.0 dBm) (no IR, radar detection)
* 5340 MHz [68] (disabled)
* 5360 MHz [72] (disabled)
* 5380 MHz [76] (disabled)
* 5400 MHz [80] (disabled)
* 5420 MHz [84] (disabled)
* 5440 MHz [88] (disabled)
* 5460 MHz [92] (disabled)
* 5480 MHz [96] (disabled)
* 5500 MHz [100] (22.0 dBm) (no IR, radar detection)
* 5520 MHz [104] (22.0 dBm) (no IR, radar detection)
* 5540 MHz [108] (22.0 dBm) (no IR, radar detection)
* 5560 MHz [112] (22.0 dBm) (no IR, radar detection)
* 5580 MHz [116] (22.0 dBm) (no IR, radar detection)
* 5600 MHz [120] (22.0 dBm) (no IR, radar detection)
* 5620 MHz [124] (22.0 dBm) (no IR, radar detection)
* 5640 MHz [128] (22.0 dBm) (no IR, radar detection)
* 5660 MHz [132] (22.0 dBm) (no IR, radar detection)
* 5680 MHz [136] (22.0 dBm) (no IR, radar detection)
* 5700 MHz [140] (22.0 dBm) (no IR, radar detection)
* 5720 MHz [144] (22.0 dBm) (no IR, radar detection)
* 5745 MHz [149] (22.0 dBm) (no IR)
* 5765 MHz [153] (22.0 dBm) (no IR)
* 5785 MHz [157] (22.0 dBm) (no IR)
* 5805 MHz [161] (22.0 dBm) (no IR)
* 5825 MHz [165] (22.0 dBm) (no IR)
* 5845 MHz [169] (disabled)
* 5865 MHz [173] (disabled)
* 5885 MHz [177] (disabled)
* 5905 MHz [181] (disabled)
Band 4:
HE Iftypes: Station
+HTC HE Supported
TWT Requester
32-bit BA Bitmap
OM Control
A-MSDU in A-MPDU
UL 2x996-Tone RU
HE40/2.4GHz
HE40/HE80/5GHz
HE160/5GHz
Device Class: 1
SU Beamformee
Max NC: 1
DCM Max BW: 3
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
HE Iftypes: AP
+HTC HE Supported
BSR
OM Control
A-MSDU in A-MPDU
UL 2x996-Tone RU
HE40/2.4GHz
HE40/HE80/5GHz
HE160/5GHz
SU Beamformee
Max NC: 1
DCM Max BW: 3
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 5955 MHz [191] (disabled)
* 5975 MHz [195] (disabled)
* 5995 MHz [199] (disabled)
* 6015 MHz [203] (disabled)
* 6035 MHz [207] (disabled)
* 6055 MHz [211] (disabled)
* 6075 MHz [215] (disabled)
* 6095 MHz [219] (disabled)
* 6115 MHz [223] (disabled)
* 6135 MHz [227] (disabled)
* 6155 MHz [231] (disabled)
* 6175 MHz [235] (disabled)
* 6195 MHz [239] (disabled)
* 6215 MHz [243] (disabled)
* 6235 MHz [247] (disabled)
* 6255 MHz [251] (disabled)
* 6275 MHz [255] (disabled)
* 6295 MHz [259] (disabled)
* 6315 MHz [263] (disabled)
* 6335 MHz [267] (disabled)
* 6355 MHz [271] (disabled)
* 6375 MHz [275] (disabled)
* 6395 MHz [279] (disabled)
* 6415 MHz [283] (disabled)
* 6435 MHz [287] (disabled)
* 6455 MHz [291] (disabled)
* 6475 MHz [295] (disabled)
* 6495 MHz [299] (disabled)
* 6515 MHz [303] (disabled)
* 6535 MHz [307] (disabled)
* 6555 MHz [311] (disabled)
* 6575 MHz [315] (disabled)
* 6595 MHz [319] (disabled)
* 6615 MHz [323] (disabled)
* 6635 MHz [327] (disabled)
* 6655 MHz [331] (disabled)
* 6675 MHz [335] (disabled)
* 6695 MHz [339] (disabled)
* 6715 MHz [343] (disabled)
* 6735 MHz [347] (disabled)
* 6755 MHz [351] (disabled)
* 6775 MHz [355] (disabled)
* 6795 MHz [359] (disabled)
* 6815 MHz [363] (disabled)
* 6835 MHz [367] (disabled)
* 6855 MHz [371] (disabled)
* 6875 MHz [375] (disabled)
* 6895 MHz [379] (disabled)
* 6915 MHz [383] (disabled)
* 6935 MHz [387] (disabled)
* 6955 MHz [391] (disabled)
* 6975 MHz [395] (disabled)
* 6995 MHz [399] (disabled)
* 7015 MHz [403] (disabled)
* 7035 MHz [407] (disabled)
* 7055 MHz [411] (disabled)
* 7075 MHz [415] (disabled)
* 7095 MHz [419] (disabled)
* 7115 MHz [423] (disabled)
Supported commands:
* new_interface
* set_interface
* new_key
* start_ap
* new_station
* new_mpath
* set_mesh_config
* set_bss
* authenticate
* associate
* deauthenticate
* disassociate
* join_ibss
* join_mesh
* remain_on_channel
* set_tx_bitrate_mask
* frame
* frame_wait_cancel
* set_wiphy_netns
* set_channel
* tdls_mgmt
* tdls_oper
* start_sched_scan
* probe_client
* set_noack_map
* register_beacons
* start_p2p_device
* set_mcast_rate
* connect
* disconnect
* channel_switch
* set_qos_map
* add_tx_ts
* set_multicast_to_unicast
WoWLAN support:
* wake up on disconnect
* wake up on magic packet
* wake up on pattern match, up to 20 patterns of 16-128 bytes,
maximum packet offset 0 bytes
* can do GTK rekeying
* wake up on GTK rekey failure
* wake up on EAP identity request
* wake up on 4-way handshake
* wake up on rfkill release
* wake up on network detection, up to 8 match sets
software interface modes (can always be added):
* AP/VLAN
* monitor
valid interface combinations:
* #{ managed } <= 1, #{ AP, P2P-client, P2P-GO } <= 1, #{ P2P-device } <= 1,
total <= 3, #channels <= 2
HT Capability overrides:
* MCS: ff ff ff ff ff ff ff ff ff ff
* maximum A-MSDU length
* supported channel width
* short GI for 40 MHz
* max A-MPDU length exponent
* min MPDU start spacing
Device supports TX status socket option.
Device supports HT-IBSS.
Device supports SAE with AUTHENTICATE command
Device supports low priority scan.
Device supports scan flush.
Device supports per-vif TX power setting
P2P GO supports CT window setting
P2P GO supports opportunistic powersave setting
Driver supports full state transitions for AP/GO clients
Driver supports a userspace MPM
Driver/device bandwidth changes during BSS lifetime (AP/GO mode)
Device adds DS IE to probe requests
Device can update TPC Report IE
Device supports static SMPS
Device supports dynamic SMPS
Device supports WMM-AC admission (TSPECs)
Device supports configuring vdev MAC-addr on create.
Device supports randomizing MAC-addr in scans.
Device supports randomizing MAC-addr in sched scans.
Device supports randomizing MAC-addr in net-detect scans.
max # scan plans: 2
max scan plan interval: 65535
max scan plan iterations: 254
Supported TX frame types:
* IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
Supported RX frame types:
* IBSS: 0x40 0xb0 0xc0 0xd0
* managed: 0x40 0xb0 0xd0
* AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* mesh point: 0xb0 0xc0 0xd0
* P2P-client: 0x40 0xd0
* P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* P2P-device: 0x40 0xd0
Supported extended features:
* [ VHT_IBSS ]: VHT-IBSS
* [ RRM ]: RRM
* [ MU_MIMO_AIR_SNIFFER ]: MU-MIMO sniffer
* [ SCAN_START_TIME ]: scan start timestamp
* [ BSS_PARENT_TSF ]: BSS last beacon/probe TSF
* [ FILS_STA ]: STA FILS (Fast Initial Link Setup)
* [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211
* [ TXQS ]: FQ-CoDel-enabled intermediate TXQs
exhxhnc@wifi1:~$ sudo iw reg set US
[sudo] password for exhxhnc:
exhxhnc@wifi1:~$ iw reg get
global
country US: DFS-FCC
(2400 - 2472 @ 40), (N/A, 30), (N/A)
(5150 - 5250 @ 80), (N/A, 23), (N/A), AUTO-BW
(5250 - 5350 @ 80), (N/A, 23), (0 ms), DFS, AUTO-BW
(5470 - 5730 @ 160), (N/A, 23), (0 ms), DFS
(5730 - 5850 @ 80), (N/A, 30), (N/A), AUTO-BW
(5850 - 5895 @ 40), (N/A, 27), (N/A), NO-OUTDOOR, AUTO-BW, PASSIVE-SCAN
(57240 - 71000 @ 2160), (N/A, 40), (N/A)
phy#0 (self-managed)
country CN: DFS-UNSET
(2402 - 2437 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
(2422 - 2462 @ 40), (6, 22), (N/A), AUTO-BW, NO-80MHZ, NO-160MHZ
(2447 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
(5170 - 5190 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
(5190 - 5210 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
(5210 - 5230 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
(5230 - 5250 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
(5250 - 5270 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5270 - 5290 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5290 - 5310 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5310 - 5330 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5490 - 5510 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5510 - 5530 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5530 - 5550 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5550 - 5570 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5570 - 5590 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5590 - 5610 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5610 - 5630 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5630 - 5650 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5650 - 5670 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, PASSIVE-SCAN
(5670 - 5690 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5690 - 5710 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, PASSIVE-SCAN
(5710 - 5730 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5735 - 5755 @ 80), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-160MHZ, PASSIVE-SCAN
(5755 - 5775 @ 80), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5775 - 5795 @ 80), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-160MHZ, PASSIVE-SCAN
(5795 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5815 - 5835 @ 40), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-80MHZ, NO-160MHZ, PASSIVE-SCAN
Wiphy phy0
max # match sets: 8
Retry long limit: 4
Supported Ciphers:
* TKIP (00-0f-ac:2)
* CMAC (00-0f-ac:6)
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* P2P-client
* P2P-GO
* P2P-device
Band 1:
RX LDPC
HT20/HT40
RX HT20 SGI
RX HT40 SGI
TX STBC
RX STBC 1-stream
DSSS/CCK HT40
HE Iftypes: Station
+HTC HE Supported
TWT Requester
32-bit BA Bitmap
OM Control
A-MSDU in A-MPDU
UL 2x996-Tone RU
HE40/2.4GHz
HE40/HE80/5GHz
HE160/5GHz
Device Class: 1
SU Beamformee
Max NC: 1
DCM Max BW: 3
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
HE Iftypes: AP
+HTC HE Supported
BSR
OM Control
A-MSDU in A-MPDU
UL 2x996-Tone RU
HE40/2.4GHz
HE40/HE80/5GHz
HE160/5GHz
SU Beamformee
Max NC: 1
DCM Max BW: 3
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
Bitrates (non-HT):
* 1.0 Mbps
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
Band 2:
RX LDPC
HT20/HT40
RX HT20 SGI
RX HT40 SGI
TX STBC
RX STBC 1-stream
DSSS/CCK HT40
RX LDPC
short GI (80 MHz)
TX STBC
SU Beamformee
MU Beamformee
VHT RX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
VHT TX MCS set:
1 streams: MCS 0-9
2 streams: MCS 0-9
HE Iftypes: Station
+HTC HE Supported
TWT Requester
32-bit BA Bitmap
OM Control
A-MSDU in A-MPDU
UL 2x996-Tone RU
HE40/2.4GHz
HE40/HE80/5GHz
HE160/5GHz
Device Class: 1
SU Beamformee
Max NC: 1
DCM Max BW: 3
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
HE Iftypes: AP
+HTC HE Supported
BSR
OM Control
A-MSDU in A-MPDU
UL 2x996-Tone RU
HE40/2.4GHz
HE40/HE80/5GHz
HE160/5GHz
SU Beamformee
Max NC: 1
DCM Max BW: 3
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
Band 4:
HE Iftypes: Station
+HTC HE Supported
TWT Requester
32-bit BA Bitmap
OM Control
A-MSDU in A-MPDU
UL 2x996-Tone RU
HE40/2.4GHz
HE40/HE80/5GHz
HE160/5GHz
Device Class: 1
SU Beamformee
Max NC: 1
DCM Max BW: 3
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
HE Iftypes: AP
+HTC HE Supported
BSR
OM Control
A-MSDU in A-MPDU
UL 2x996-Tone RU
HE40/2.4GHz
HE40/HE80/5GHz
HE160/5GHz
SU Beamformee
Max NC: 1
DCM Max BW: 3
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
1 streams: MCS 0-11
2 streams: MCS 0-11
Bitrates (non-HT):
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
Supported commands:
* new_interface
* set_interface
* new_key
* start_ap
* new_station
* new_mpath
* set_mesh_config
* set_bss
* authenticate
* associate
* deauthenticate
* disassociate
* join_ibss
* join_mesh
* remain_on_channel
* frame
* frame_wait_cancel
* set_wiphy_netns
* set_channel
* tdls_mgmt
* tdls_oper
* start_sched_scan
* probe_client
* set_noack_map
* register_beacons
* start_p2p_device
* set_mcast_rate
* connect
* disconnect
* channel_switch
* set_qos_map
* add_tx_ts
WoWLAN support:
* AP/VLAN
* monitor
max # scan plans: 2
* [ RRM ]: RRM
DeividA_Intel
Hello ChunjieHao,
1. The brand and model number of your system. You can also provide the Intel® System Support Utility for the Linux* Operating System for more details: https://www.intel.com/content/www/us/en/download/18895/26735/intel-system-support-utility-for-the-linux-operating-system.html
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Is this a laptop or desktop computer?
4. What is the brand and model name of your router?
5. Did the 5GHz work before with your device?
6. Can you provide the country where you are located?
Deivid A.
ChunjieHao
Thank you for your support.
  1.  exhxhnc@wifi1:~$ sudo dmidecode | grep "Product"
     Product Name: PowerEdge T440
     Product Name: 021KCD
  2. We installed an adapter(ax210) on the machine.
  3.  Desktop computer
  4.  Set it to AP mode, so don't need router.
  5. Works well in the Windows.
  6. China
DeividA_Intel
Hello ChunjieHao,
I would like to let you know that the no-IR flag is set to meet the regulatory compliance and disable the soft AP mode on 5GHz channels in certain countries. For details, refer to the article Linux Wireless - Regulatory rules.
- https://wireless.wiki.kernel.org/en/developers/regulatory/processing_rules#:~:text=The%20no%2Dir%20flag%20exists,does%20not%20have%20this%20flag.
I recommend you try to enable the AP mode on channels without the no-IR or Passive-scan flags in the county.
Deivid A.
DeividA_Intel
Hello ChunjieHao,
Were you able to check the previous post? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello ChunjieHao,
As a friendly reminder, bear in mind that the no-IR flag is set to meet the regulatory compliance and disable the soft AP mode on 5GHz channels in certain countries.
You can check this link for further information:
Also, our support for Linux is limited since it may vary depending on the operating system version that you are using, so you may need to check this with the distro.
I will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
