Wireless
8530 Discussions
BE200 on 23.90.0.2 driver resets network during prolonged file transfers
EagleEye208
My host keeps having the full network stack restart after large file transfers are initiated. When sending 10 files with size 6 - 10GB each, it will get to file 3 or 4, then the whole network stack dies, restarts. I rolled back the driver to previous version, and now it last longer, but only to 8 or 9 files, and then crash. Below are the best logs I can find. If you know a better location, I can post those too.
Chip: BE200 on E Key
Computer: ASRock 4x4 NUC
OS: Windows 11 Pro 23H2
TCP: IPv4 + IPv6 enabled
WiFi Driver: 23.90.0.2
Rollback Driver: 23.80.1.3
System Event:
"The description for Event ID 7012 from source Netwaw16 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer."
WLAN Log:
"Network Adapter: Intel(R) Wi-Fi 7 BE200 320MHz
Interface GUID: {redacted}
Connection Mode: Automatic connection with a profile
Profile Name: [redacted]
SSID: [redacted]
BSS Type: Infrastructure
Reason: The network is disconnected by the driver."
EagleEye208
Updated to 23.100.0.4. Issue has gone away.
EagleEye208
