Wireless
8871 Discussions
BE200 regulatory information overly restrictive
kai1024
why is Intel Firmware on this HW:
[    7.289780] iwlwifi 0001:01:00.0: BAR 0 [mem 0x1b00000000-0x1b00003fff 64bit]: assigned
[    7.289889] iwlwifi 0001:01:00.0: enabling device (0000 -> 0002)
[    7.294448] iwlwifi 0001:01:00.0: Detected crf-id 0x2001910, cnv-id 0x2001910 wfpm id 0x80000000
[    7.294498] iwlwifi 0001:01:00.0: PCI dev 272b/00f4, rev=0x472, rfid=0x112200
[    7.294502] iwlwifi 0001:01:00.0: Detected Intel(R) Wi-Fi 7 BE200 320MHz
[    7.319000] iwlwifi 0001:01:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.4.196
[    7.320156] iwlwifi 0001:01:00.0: loaded firmware version 96.44729d4e.0 gl-c0-fm-c0-96.ucode op_mode iwlmvm
[    7.722092] iwlwifi 0001:01:00.0: Detected RF FM, rfid=0x112200
[    7.726589] iwlwifi 0001:01:00.0: loaded PNVM version 8af7618d
so overly restrictive? (compared to country=DE regulations)
iw reg get
global
country DE: DFS-ETSI
        (2400 - 2483 @ 40), (N/A, 20), (N/A)
        (5150 - 5250 @ 80), (N/A, 23), (N/A), NO-OUTDOOR, AUTO-BW
        (5250 - 5350 @ 80), (N/A, 20), (0 ms), NO-OUTDOOR, DFS, AUTO-BW
        (5470 - 5725 @ 160), (N/A, 26), (0 ms), DFS
        (5725 - 5875 @ 80), (N/A, 13), (N/A)
        (5945 - 6425 @ 160), (N/A, 23), (N/A), NO-OUTDOOR
        (57000 - 66000 @ 2160), (N/A, 40), (N/A)
phy#0 (self-managed)
country DE: DFS-UNSET
        (2402 - 2437 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
        (2422 - 2462 @ 40), (6, 22), (N/A), AUTO-BW, NO-80MHZ, NO-160MHZ
        (2447 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
        (5170 - 5190 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (5190 - 5210 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (5210 - 5230 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
        (5230 - 5250 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
        (5250 - 5270 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
        (5270 - 5290 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
        (5290 - 5310 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
        (5310 - 5330 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
        (5490 - 5510 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
        (5510 - 5530 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
        (5530 - 5550 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
        (5550 - 5570 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
        (5570 - 5590 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
        (5590 - 5610 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
        (5610 - 5630 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
        (5630 - 5650 @ 220), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
        (5650 - 5670 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, PASSIVE-SCAN
        (5670 - 5690 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
        (5690 - 5710 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, PASSIVE-SCAN
        (5735 - 5755 @ 140), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS
        (5755 - 5775 @ 140), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS
        (5775 - 5795 @ 140), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS
        (5795 - 5815 @ 140), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS
        (5815 - 5835 @ 140), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS
        (5835 - 5855 @ 140), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS
        (5855 - 5875 @ 140), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS
        (5945 - 6425 @ 480), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, PASSIVE-SCAN
Why don't firmware regulations match the country regulations?
This way its impossible to setup 5GHZ hotspot
This doesn't make any sense?
Please fix.
JeanetteC_Intel
Hello kai1024,
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
  1. Is your system a desktop PC or a laptop?
  2. Is the Intel® Wi-Fi 7 BE200 a pre-installed component on your system device or is it an upgrade/replacement component?
  3. Which Linux distribution and version are you using?
  4. Is this a first-time setup for 5GHZ hotspot and won't work or has it previously worked then failed?
Additionally, I highly appreciate you sharing your system configuration so I can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for the Linux* Operating System.
1) Download the Intel® System Support Utility for the Linux* operating system and save the ssu.tar.gz file to your system.
2) Extract the ssu.sh file from ssu.tar.gz and save to your system.
3) To run the ssu.sh script from a Linux* terminal, Open Applications->Accessories->Terminal.
4) From the current directory, navigate to the current folder where the ssu.sh file resides. For example, if you saved the ssu.sh file to a folder called SSU File, the command would be cd SSU File.
5) Run the ssu.sh file using this command: ./ssu.sh <parameter=0|1> where 0 = off and 1 = enabled.
6) Use the parameter definitions included in the readme to determine which parameter to use.
Note:
If no parameter is specified and only ./ssu.sh is run, it captures all system information with the exception of 3rd party logs that must be specified.
    • If no output file is specified, the Intel System Support Utility writes the output to the <systemname>.txt file.
7) You can view or open the output file in most text editors. However, view the file in a word processing software, such as WordPad*, for better formatted viewing. In addition, the Intel® System Support Utility for Windows can open the output file, which provides you with the capability of viewing the Linux information in an easy-to-view user interface.
JeanetteC.
kai1024
its a new Intel BE200NGW M.2 card on Ubuntu 2025.04
But after reading this:
https://bugzilla.kernel.org/show_bug.cgi?id=206469#c2
https://superuser.com/questions/1645797/using-hostapd-on-ubuntu-20-04-to-create-5ghz-access-point-channel-153-primary/1809751#1809751
I came to the conclusion that this is an intentional restriction so I have replaced the card already, so I'm afraid I can't run support utility anymore.
JeanetteC_Intel
Hello kai1024,
Thank you for researching this thoroughly. I understand your decision to replace the card given the restrictions you discovered - that's completely reasonable.
Since you've found an alternative solution, I'll close this case. If you need future assistance with Intel products, please submit a new question as this thread will no longer be monitored.
Sincerely,
JeanetteC.
