Wireless
8721 Discussions
BE200NGW
dlritter61
I have purchased 2 samples to replace an AX210NGW and found both to lockup/crash an AMD based platform.  Specifically an ASROCK X370 Taichi.  Don't think its intended to give the competition a bigger foot in the wifi7 door.
Anyone else experience the same bug?
Jocelyn_Intel
Hello, @dlritter61
Thank you for posting on the Intel® communities.
It is worth mentioning that Intel does not support wireless integrations (installing a different wireless adapter into your system/laptop). We recommend you speak to the Manufacturer of your equipment for support on wireless integrations and replacement parts to ensure compliance with the regulatory requirements of your country and support. It is important to check for compatibility with the System Manufacturer, as there could be certain cards that will not work with the system.
For more information, read the following article under the title "Regulatory Information Regarding Wireless Hardware Installation or Upgrade.
Jocelyn M.
