Wireless
8657 Discussions
BE201 WiFi card not working under Linux (latest kernel 6.14.4, Fedora 42)
hcording
There is an issue with the BE201 WiFi card when running Linux.
The drivers were added to the kernel by Intel and are being loaded properly, lspci shows the card.
However, dmesg says:
"RFIm is deactivated, reason = 4"
and
"BIOS contains WGDS but no WRDS"
and it's not possible to connect to any networks. Bluetooth is functional though.
Please find more details in the corresponding Bugzilla post: https://bugzilla.kernel.org/show_bug.cgi?id=220085
I have done additional research and I think the issue relates to the regulatory domain settings enforced by LAR.
iw reg get:
global
country DE: DFS-ETSI
phy#0 (self-managed)
country 00: DFS-UNSET
(2412 - 2413 @ 1), (6, 22), (N/A)
Furthermore, `iw phy0 channels` shows that all channels are disabled.
Since lar_disable doesn't work since Kernel 5.4, I'm unsure how to proceed.
Happy to provide more information. Logs attached.
Thanks!
JeanetteC_Intel
Hello hcording,
I'll look into this internally and provide an update as soon as it's ready.
JeanetteC.
hcording
Hi Jeanette,
thank you for investigating, I look forward to your reply!
Henry
JeanetteC_Intel
Hello hcording,
After reviewing the system specifications, it appears that the supported operating system is Windows OS. Sharing this link for the computer's specifications: https://rog.asus.com/laptops/rog-zephyrus/rog-zephyrus-g16-2025-gu605/spec/
Please provide the following information so I can properly isolate the issue:
  1. Was the wireless functioning properly before?
  2. Is it working well with Windows OS?
  3. Have you already reached out to your system manufacturer support team for this issue?
  4. If it works well with Windows, what prompted you to switch to Linux?
JeanetteC.
hcording
Hi Jeanette,
Please find my answers below.
1. In my case, WiFi was never functional under Linux.
2. Yes, no issues when running Windows.
3. Not yet, but I am happy to do so. The reason I asked here first is that Intel provides the WiFi card and its drivers.
4. Linux is my operating system of choice and has been for years. I am currently dual booting Linux and the Windows 11 installation that came with the device, but this is a temporary setup until the WiFi issue is resolved.
Henry
Mike_Intel
Hello hcording,
Thank you for the update.
Let me ask more details based on your reply.
  1. If you switch to Windows 11, are you also having this issue?
  2. Can you share with us the driver that you use in Linux?
  3. What is the brand and model of your system/laptop?
Michael L.
hcording
Hi Michael,
Thank you for your reply.
1. Wifi works without issues under Windows 11
2. See all.txt attached in my initial post. From dmesg: loaded firmware version 96.44729d4e.0 bz-b0-fm-c0-96.ucode op_mode iwlmvm
3. It's an ASUS ROG Zephyrus G16 (2025), model name GU605CX.
Henry
JeanetteC_Intel
Hello hcording,
Thank you for sharing these important details. I'll continue to work on this internally and will share an update as soon as it's available.
JeanetteC.
JeanetteC_Intel
Hello hcording,
Please review your email inbox, as well as your spam or junk folders, for the private message I sent regarding the final resolution to this issue.
Sincerely,
JeanetteC.
hcording
Hi Jeanette,
thanks for your reply. I'm not sure why you sent me the final information privately via email, since this might be highly relevant for other people with the same issue.
"The log messages "BIOS contains WGDS but no WRDS" and "RFIm is deactivated, reason = 4" pertain to geolocation and radio transmission power limitations stored in the PC BIOS, which can vary based on the BIOS implementation in the computer."
So essentially, it's up to ASUS and/or Linux Distro and kernel developers to develop a fix, and Intel can't support futher.
Either way, thank you for checking this issue with the Intel team. I will try posting an update here if I can manage to get WiFi working.
Henry
ajgallego
I have the exact same problem with the BE201 WiFi card on my ASUS ROG Zephyrus G16 (2025), using Ubuntu 24 with kernel 6.11.0-25. The WiFi card is recognized by the system, but it is not able to connect to any networks, although Bluetooth works fine.
Here are the outputs I get:
$ iw reg get
global
(755 - 928 @ 2), (N/A, 20), (N/A), PASSIVE-SCAN
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 20), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (N/A, 20), (N/A), PASSIVE-SCAN
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
When I run iw phy phy0 channels, I get a long list of disabled channels — everything is disabled across all bands (1, 2, and 4).
The drivers are being loaded correctly, but the issue persists.
Thanks!
Kolya7
I am having the same issue as the person that started the thread. I am on a 2025 Zephyrus G16 GU605CR Intel Core Ultra 285H, 32Gb Ram, 5070Ti model with the BE201 Intel Wifi card.
Wifi works perfectly in Windows, it is not a personal issue, but a widespread issue on this laptop model, the Intel wifi card and Linux regardless of distribution and Kernel version being used. Ethernet using an adapter does work correctly on Linux.
I have tried several distributions, from Debian Sid using the latest kernel, to Fedora, to Arch based distros, and Wifi does not work, no connections show available even though the card is recognized by the OS.
Please look into this, and communicate with Asus as well to find a solution since it is quite frustrating not being able to use Wifi on a high end computer using Linux on this date and age.
Thank you and we'll await for a prompt solution affecting all the users of this laptop with intel hardware in it.
TurboTorsten
I am facing the exact same issue! Having tested, Fedora, Ubuntu, Nobara, and Arch the wireless drivers just would not work. However, I bought a cheap usb wifi adapter (archer t3u nano) which can be a good solution in the meantime.
The bigger issue that I am facing though is that no matter which distro I use, reboot and shutdown just don't work. The laptop displays the asus logo and then freezes. Does anyone have a solution? Otherwise, I may need to return the device. Thanks very much in advance!
hcording
Hi, although unrelated to this thread, you can fix this by adding pci=noaer to the grub cmdline arguments. The reason you cannot shutdown is because there is a pci error message that gets spammed 100s of times per second, so the laptop never reaches the off state and is busy printing. The grub argument disables these error messages (which are harmless btw).
TurboTorsten
Hi, you are an absolute legend - this worked immediately! Now the only problems left are powerdraw during sleep and making the sound work properly.
I tested the 2024 model and there speakers worked out the box and the sound was amazing (after some fine-tuning with easy effects). Do you have any idea how to fix this and whether it is related to the intel chipset?
hcording
Hi, glad I could help!
Regarding power draw during sleep - I noticed some, but not excessive amounts. Definitely install the asus-linux.org tools and the current nvidia driver with open kernel modules. This will allow you to switch between gpu modes easily. When disabling dGPU (only intel graphics active) the laptop runs significantly cooler and probably draws less power during sleep. I have yet to look into sleep mode configuration and testing S0ix.
Regarding the amp: yes I have this issue too, the tweeter is functional but no bass and no mids. For the 2024 model, there was work done by cirrus (the company making the speakers) before the speakers worked under Linux, so I assume this will just take time for the 2025 model to be supported as well, but they try to add support eventually from what I gathered.
TurboTorsten
I really appreciate your support!
Looks like there is some progress regarding the wifi (this thread) and sound: https://bugzilla.kernel.org/show_bug.cgi?id=220152
Spent the whole weekend to see if I can use the machine properly, but whenever I install arch or fedora, I really struggle with the open nvidia drivers. Somehow they won't install properly, even when doing it manually with the run file.
May I ask you how far you managed to push things? Have you encountered any other issues and which distro(s) are you testing? Sorry for all the questions!
WilliamB_reg
Same issue here, Asus Vivobook S14 S5406.
I actually have it working, in a very crippled and barely-controllable fashion, under Ubuntu + kernel 6.11.26. Here's my thread:
https://community.intel.com/t5/Wireless/AX231-erroneously-regs-recognized-as-BE201-I-suspect-in-Linux/m-p/1695600/emcs_t/S2h8ZW1haWx8YW5zd2VyX2FjY2VwdGVkX2FzX3NvbHV0aW9ufE1CTkdYMTFPUkdZRFJRfDE2OTU2MDB8QUNDRVBURURfU09MVVRJT05TfGhL#M60311
In my case, "iw phy0 channels" has Band1, Band2 and Band4 channels alive, though "iw reg get" says "phy0 self-managed DFS-UNSET".
Waiting for a proper solution as well.
WilliamB_reg
Updating for everyone else - with kernel 6.15.1 WiFi driver looks fully operational, both WiFi and BT are working properly and allow connecting as desired. Suggest everyone to try and upgrade the kernel.
cbuchart
Just want to clarify, issue is not fixed on the hardware it was initially created for, i.e. Asus GU605CX, with kernel 6.15.1.
ajgallego
Hi everyone,
Just wanted to provide an update on my situation. I tested kernel 6.15.1 on Ubuntu 24.04, and unfortunately the WiFi issue persists, it still doesn't work at all. What's worse is that with that version of the kernel my NVIDIA GPU stopped working properly. The nvidia-driver-570 does not seem to be compatible or available.
