Wireless
9002 Discussions
BE201 is not functioning properly
aiyangsky
我尝试在华硕系统上设置 Ubuntu 24.04,但 Wi-Fi 始终无法正常工作。错误消息如下:
[ 3.560093] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 3.574149] iwlwifi 0000:00:14.3: Detected crf-id 0x2001910, cnv-id 0x1080900 wfpm id 0x80005b20
[ 3.574158] iwlwifi 0000:00:14.3: PCI dev a840/00e4, rev=0x461, rfid=0x20112200
[ 3.574160] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 7 BE201 320MHz
[ 3.581819] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.182.4.1
[ 3.582511] iwlwifi 0000:00:14.3: loaded firmware version 92.67ce4588.0 bz-b0-fm-c0-92.ucode op_mode iwlmvm
[ 4.072943] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[ 4.074516] iwlwifi 0000:00:14.3: loaded PNVM version 35c04ca8
[ 4.093599] iwlwifi 0000:00:14.3: Detected RF FM, rfid=0x20112200
[ 4.180887] iwlwifi 0000:00:14.3: base HW address: c8:6e:08:fb:32:86
[ 4.253352] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[ 21.826164] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[ 21.943780] iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 0
$ uname -r
6.11.0-21-generic
它在 Windows 下完美运行并且运行流畅。
JeanetteC_Intel
Hello aiyangsky,
请注意,我只能用英语为您提供支持。我使用了网络翻译工具来翻译此回复,因此,可能会有一些不准确的翻译。今后,我将用英文回复您。
To properly isolate the issue, kindly help share the following details below for better issue understanding:
  • Is this a first-time setup that is not working with Ubuntu 24.04, or did it previously function correctly and the issue arose recently?
  • If it worked previously, what changes were made before the issue occurred?
  • Is the Intel® Wi-Fi 7 BE201 pre-installed on your ASUS system, or is it an upgrade component?
  • Please share your system configuration to assist with further investigation. You can do this by downloading the Intel® System Support Utility for the Linux* Operating System. Please check the Help Guide for the Intel® System Support Utility on how to generate the log file.
I will wait for your reply.
JeanetteC.
aiyangsky
感谢您的回复。
  • 首次安装 Ubuntu 24.04。
  • 安装后不做任何修改。
  • 华硕系统预装 Intel® Wi-Fi 7 BE201。
  • 附件中提供了日志详细信息。
谢谢
天空
JeanetteC_Intel
Hello aiyangsky,
Thank you for providing this update. I'll look into this internally and will share an update once available.
JeanetteC.
JeanetteC_Intel
Hello aiyangsky,
After thoroughly examining the issue and the computer's specifications, I've noted that it is only compatible with Windows OS.
Could you confirm whether the wireless connection functioned properly with Windows in the past? You can check the specifications here: ASUS Vivobook S 14 OLED S5406.
If the wireless connection operates correctly with Windows, could you share the reason for switching to or using Linux?
I look forward to hearing from you soon.
JeanetteC.
aiyangsky
Thank you for your response.
It functions correctly under Windows;
however, I currently aim to use the Intel® Core™ Ultra 7 258V processor for SLAM (Simultaneous Localization and Mapping) development work, which requires switching to a Linux environment. The lack of wireless connectivity will significantly hinder my workflow.
Sky
JeanetteC_Intel
Hello aiyangsky,
I will make a note of this and continue with my further review. I'll provide an update once it's available.
JeanetteC.
JeanetteC_Intel
Hello aiyangsky,
Kindly check your email inbox, spam and/or junk folders for the update. I will proceed in closing this case. Should you need assistance in the future, please submit a new question as this thread will no longer be monitored.
Sincerely,
JeanetteC.
