Wireless
9023 Discussions
BE201 random hardware address problem
chris53
I'm running into a strange Wi-Fi issue with my laptop. It has the BE201 installed and the newest driver version 23.140.0.
It will only connect to a Wi-Fi network if the "random hardware address" feature is turned ON.
What's really odd is that even if I successfully connect with the random address enabled, and then try to turn that option OFF for that specific Wi-Fi network, it won't reconnect.
It seems insistent on using a random address.
Has anyone else encountered this kind of behavior?
More importantly, does anyone know of a fix or a workaround for this?
JedG_Intel
Hello chris53,
To assist you effectively, please share the information below.
1. Were you able to have wireless connection in a normal/expected performance before?
2. What is the full model of your laptop? If possible, kindly share the link to it.
3. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
4. Is this issue happening at home, office environment or both?
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
I hope to hear from you soon.
Best regards
Jed G.
JedG_Intel
Hello chris53,
Jed G.
JedG_Intel
Hello chris53,
Jed G.
