Wireless
8663 Discussions
BSOD with netwtw06.sys when switching AP
AJone13
We have 25 Lenovo T480s computers that have been BSOD for the last couple months. Recently we used Driver Verifier and were able to consistently replicate the BSOD when the netwtw06.sys was selected using Driver Verifier. We've been able to trigger the BSOD by walking with the laptop which I think the change in access point is causing the blue screen. We've updated the driver versions from 20.50 to 20.60 and the issue still occurs. We've tested with slightly older models that have earlier driver versions and the issue does not occur. Any ideas or thoughts would be helpful!
AlHill
What specific T480 do you have (provide specifics)?
What operating system are you running?
What is the processor model number?
Are you using the driver from the Lenovo site?
From where are you getting your drivers?
Provide the information and someone will be able to help you.
P.S. Personally, I would never use a tool like driver verifier.
Doc
AJone13
Below is one of our dump files.
-T480s Type 20L7-002EUS
-Windows 10 Enterprise 1803
-Processor is i5-8350U
We were originally using the drivers from Lenovo, but saw that Intel had newer ones so we tried that as well.
1: kd> !analyze -v
* Bugcheck Analysis *
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff802e59366a1, Address of the instruction which caused the bugcheck
Arg3: ffffc208f86c6b00, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
KEY_VALUES_STRING: 1
TIMELINE_ANALYSIS: 1
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 16299.431.amd64fre.rs3_release_svc_escrow.180502-1908
SYSTEM_MANUFACTURER: LENOVO
SYSTEM_PRODUCT_NAME: 20HF0011US
SYSTEM_SKU: LENOVO_MT_20HF_BU_Think_FM_ThinkPad T470s
SYSTEM_VERSION: ThinkPad T470s
BIOS_VENDOR: LENOVO
BIOS_VERSION: N1WET35W (1.14 )
BIOS_DATE: 07/12/2017
BASEBOARD_MANUFACTURER: LENOVO
BASEBOARD_PRODUCT: 20HF0011US
BASEBOARD_VERSION: SDK0J40697 WIN
DUMP_TYPE: 2
BUGCHECK_P1: c0000005
BUGCHECK_P2: fffff802e59366a1
BUGCHECK_P3: ffffc208f86c6b00
BUGCHECK_P4: 0
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
FAULTING_IP:
nt!ObpFreeObject+131
fffff802`e59366a1 f00fc18600020000 lock xadd dword ptr [rsi+200h],eax
CONTEXT: ffffc208f86c6b00 -- (.cxr 0xffffc208f86c6b00)
rax=00000000ffffffff rbx=ffff8009bfb9b6c0 rcx=0000000000000011
rdx=ffff8009bfb9b670 rsi=4f15c47fb48419ae rdi=00000000000000b6
rip=fffff802e59366a1 rsp=ffffc208f86c74f0 rbp=ffff8009b252b4a0
r8=0000000000000001 r9=0000000000000000 r10=0000000000000000
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=ffff8009bfb9b670 r15=0000000000000000
iopl=0 nv up ei ng nz na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010286
nt!ObpFreeObject+0x131:
fffff802`e59366a1 f00fc18600020000 lock xadd dword ptr [rsi+200h],eax ds:002b:4f15c47f`b4841bae=????????
Resetting default scope
CPU_COUNT: 4
CPU_MHZ: a98
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 8e
CPU_STEPPING: 9
CPU_MICROCODE: 6,8e,9,0 (F,M,S,R) SIG: 62'00000000 (cache) 62'00000000 (init)
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXPNP: 1 (!blackboxpnp)
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: 0x3B
PROCESS_NAME: SearchFilterHost.exe
CURRENT_IRQL: 0
ANALYSIS_SESSION_HOST: DESKTOP-0LUP3S0
ANALYSIS_SESSION_TIME: 06-19-2018 09:19:22.0390
ANALYSIS_VERSION: 10.0.17134.12 amd64fre
LAST_CONTROL_TRANSFER: from fffff802e5936516 to fffff802e59366a1
STACK_TEXT:
ffffc208`f86c74f0 fffff802`e5936516 : 00000000`00000000 ffff8009`bfb9b6a0 ffff8009`bfb9b670 00000000`00000000 : nt!ObpFreeObject+0x131
ffffc208`f86c7550 fffff802`e552f6c6 : 00000000`00000000 00000000`00000000 00000000`00000000 ffff8009`bfb9b6f0 : nt!ObpRemoveObjectRoutine+0x86
ffffc208`f86c75b0 fffff802`e595a3cb : 00000000`ffff8004 ffff8009`b252b4a0 ffff8009`00000001 ffff8009`bfb9b6c0 : nt!ObfDereferenceObjectWithTag+0xc6
ffffc208`f86c75f0 fffff802`e59f9145 : 00000000`00000000 fffff802`e552e7b4 ffff8009`bd7f7700 ffff8009`bd8a5098 : nt!ObCloseHandleTableEntry+0x25b
ffffc208`f86c7730 fffff802`e59e04a9 : ffff8009`bd8a5060 00000000`00000000 ffff8009`bbca7080 ffffffff`ffffff01 : nt!ExSweepHandleTable+0xc5
ffffc208`f86c77e0 fffff802`e599053d : ffffffff`ffffffff ffff8009`bbca7080 ffff8009`bbca7080 ffff8009`00000000 : nt!ObKillProcess+0x35
ffffc208`f86c7810 fffff802`e5914f03 : ffff8009`bbca7080 ffff950f`69e1b900 ffffc208`f86c7a80 00000000`00000000 : nt!PspRundownSingleProcess+0x121
ffffc208`f86c7890 fffff802`e59dc6cf : 00000000`00000000 ffffc208`f86c7a01 00000002`8d23b000 ffff8009`bd7f7700 : nt!PspExitThread+0x583
ffffc208`f86c7990 fffff802`e5625363 : 00000000`0000376c ffff8009`bd7f7700 ffff8009`bbca7080 00000106`f33e0730 : nt!NtTerminateProcess+0xeb
ffffc208`f86c7a00 00000000`595b9e3d : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000002`8d13f7a8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x595b9e3d
THREAD_SHA1_HASH_MOD_FUNC: 5f041c223d6d56e5b50919d5e6ce29f4ce085e7c
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 92fbc344c2d38d0722203ebf00779feb4669ef7a
THREAD_SHA1_HASH_MOD: bc100a5647b828107ac4e18055e00abcbe1ec406
FOLLOWUP_IP:
FAULT_INSTR_CODE: 86c10ff0
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt!ObpFreeObject+131
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 5aeaa6a2
IMAGE_VERSION: 10.0.16299.431
STACK_COMMAND: .cxr 0xffffc208f86c6b00 ; kb
BUCKET_ID_FUNC_OFFSET: 131
FAILURE_BUCKET_ID: 0x3B_nt!ObpFreeObject
PRIMARY_PROBLEM_CLASS: 0x3B_nt!ObpFreeObject
TARGET_TIME: 2018-06-15T15:16:54.000Z
OSBUILD: 16299
OSSERVICEPACK: 431
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 2018-05-03 02:05:22
BUILDDATESTAMP_STR: 180502-1908
BUILDLAB_STR: rs3_release_svc_escrow
BUILDOSVER_STR: 10.0.16299.431.amd64fre.rs3_release_svc_escrow.180502-1908
ANALYSIS_SESSION_ELAPSED_TIME: e7a
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x3b_nt!obpfreeobject
FAILURE_ID_HASH: {c6c66008-ecfb-6f68-152f-8955ff35bc66}
Followup: MachineOwner
Hello ajones12345,
Thank you for joining the Intel Communities.
There is newer version of the wireless adapter which is version 20.70.0.5 and I would like you to give it a try. You may download it from this link https://downloadcenter.intel.com/download/27989/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10?product=94150 https://downloadcenter.intel.com/download/27989/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10?product=94150
Please try doing a clean installation of the wireless driver. This link will give you the steps https://www.intel.com/content/www/us/en/support/articles/000022173/network-and-i-o/wireless-networking.html https://www.intel.com/content/www/us/en/support/articles/000022173/network-and-i-o/wireless-networking.html
If issue persists try changing Wi-Fi Roaming Aggressiveness Setting. This link will show you how https://www.intel.com/content/www/us/en/support/articles/000005546/network-and-i-o/wireless-networking.html https://www.intel.com/content/www/us/en/support/articles/000005546/network-and-i-o/wireless-networking.html
Let me know if issue persists or not.
Fred D.
Hello ajones12345,
I was wondering if you still need assistance regarding the blue screen of death you are having in the computer. In case you still need assistance just let me know.
Fred D.
