Wireless
8947 Discussions
Bluetooth AC-7260
timbarlant
Hello, I am using a hp pavilion 15 p053eu laptop with one antenna and I changed the wireless card to an intel dual band ac 7260. I want to ask because I have a problem with bluetooth, if I attach the antenna to aux instead of main , will I have wifi+bluetooth because on main i only get wifi and via bluetooth i can't transfer anything. Will there be another problem with the laptop if I do this swap.
AlHill
You need to consult with HP for any wireless compatibility and integration.
LeonWaksman
Hi @timbarlant
In Intel WiFi adapter the Antenna Connector Functionality is as you say (i.e. Antenna 1 (Aux) WiFi + Bluetooth, Antenna 2 (Main) WiFi). However, you should be aware that both antennas should be connected to achieve proper WiFi performance).
 Leon
