Wireless
9035 Discussions
Remembering BSSID
Hiroshi_Y
When connecting to a wireless access point (AP), the load was high and the response was poor, so I intentionally switched to using the SIM card to maintain a stable connection. After that, when I connected to Wi-Fi again, it automatically connected to the closest wireless AP.
<Question>
Is it true for the device (Windows) to remember the previously connected BSSID and continue using it? I contacted Microsoft, and they mentioned that it depends on the driver of the wireless adapter.
Please tell me how to clear or configure BSSID.
OS:Windows 10 Pro
OS:Version 21H2
OS:Build 19044.2965
Processor:11th Gen Intel(R) Core(TM) i5-1145G7 @ 2.60GHz
Best regards.
DeividA_Intel
Hello Hiroshi_Y,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your wireless adapter.
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
2. Is the Bluetooth working?
3. Is this a laptop or desktop computer?
4. What is the brand and model name of your wireless adapter?
5. To confirm, is the adapter connecting to the wrong AP? Or, is it not supposed to connect to any AP?
Deivid A.
Hiroshi_Y
Hi, David A,
The original adapter is.
No. It isn't working.
A laptop is.
Intel(R) Wi-Fi 6 AX201 160MHz
I expected that the laptop released the wrong AP and reconnected neaby the AP.
Regard,
Hiroshi.
DeividA_Intel
Hello Hiroshi_Y,
Thanks for your response. Based on the information provided, please try the following:
1. Update your Windows version (built: 19045) as well as the optional updates.
2. Perform a clean installation of the Intel driver:
3. Try to forget the wrong Wi-Fi network.
  • Type Settings in the search box.
  • Click Network & Internet.
  • Click Wi-Fi on the left pane of the Network & Internet window.
  • Click Manage Wi-Fi settings.
  • Select the network name and click Forget.
4. Try to block the wrong Wi-Fi network. You can check the steps in the following Microsoft forum:
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
Deivid A.
Hiroshi_Y
Hello, Deivid A,
My explanation was bad.
It's not the wrong AP, there are several same name APs that don't allow for a seamless connection.
So, I couldn't forget the wrong Wi-Fi.
Hiroshi.
DeividA_Intel
Hello Hiroshi_Y,
Thanks for the reply. In order to continue further, I will need the following:
1. Please, provide more specific details about the issue.
2. Can you provide steps to replicate this issue?
3. Can you provide a video or pictures of the issue?
4. Please, provide the report from the Intel® System Support Utility (Intel® SSU):
Deivid A.
Hiroshi_Y
Hello, Deivid A,
I attached a explanation file about this issue.
So, could you confirm it.
And, please give me some time to povide the report you requested.
Because it needs administrator privileges to do this.
Hiroshi.
DeividA_Intel
Hello Hiroshi_Y,
Thanks for the information provided. I understand that will need more time to gather the report needed, I will be waiting for your next response.
Deivid A.
DeividA_Intel
Hello Hiroshi_Y,
I reviewed your post, please let me know if the issue was resolved, if not, do not hesitate, just reply back.
Deivid A.
Hiroshi_Y
Hi, Deivid A,
Sorry for the late reply.
I will get the report from the intel SSU next monday.
Please wait a little bit.
Hiroshi.
DeividA_Intel
Hello Hiroshi_Y,
Thanks for the confirmation. I understand that you will need more time to collect the report, I will be waiting for your next response.
Deivid A.
DeividA_Intel
Hello Hiroshi_Y,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
Hiroshi_Y
Hello Deivid A,
I got the report from SSU.
Please check it.
Hiroshi.
DeividA_Intel
Hello Hiroshi_Y,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello Hiroshi_Y,
Thanks for your patience. Based on the information provided and the troubleshooting performed so far, I can only recommend you try the following
Also, I would like to let you know that the networks saved or connected previously are managed by the Operating system (Windows) and not by the drivers or adapter. I recommend you check with Microsoft to confirm if they can provide you with further assistance.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
