Opération réussie ! Abonnement ajouté.
Opération réussie ! Abonnement supprimé.
Désolé, vous devez procéder à une vérification pour effectuer cette action. Veuillez cliquer sur le lien de vérification dans votre e-mail. Vous pouvez le renvoyer à partir de votre profil.
Hallo,
i have some bluetooth-headphones and they have worked fine on my Windows 10 System. Since an update in late august or early september i was not longer able to connect the headphones with the PC.
It was not sure whether a Windows update or a driver update was the reason for the changes. After a longer session with the Microsoft-support and some "repair"-processes, it seems, that the BT-driver is the reason.
Unfortunately, Windows doesn't allow me to go back to a state before the update.
Problem description:
If I bring the headphones in pairing mode the PC recognizes the headphones an starts to connect them (Message left). After some minutes the message changes to "... not able to connect" (Message right).
Message2
When I look in Computer Management under "Windows System Logs," I see an error message: "Mutual authentication between the local Bluetooth adapter and a device with Bluetooth adapter address (18:4e:16:e1:01:d6) failed.":
I think that is exactly the cause of the connection failures.
Despite many attempts of uninstalling and reinstalling drivers and deleting and including devices, I have not been able to resolve this error.
There are also no abnormalities in the device manager:
Does anyone know what this error is and how to resolve it? I'm grateful for any help.
Thomas
Lien copié
Hello Thomas64,
Michael L.
Hello Mike,
I hope I can answer your questions.
Until last august/september the connection to my headhones works fine.
Thanks for your help and best wishes,
Thomas
Hello Thomas64,
Michael L.
Hello Thomas64,
Thank you for the update.
If the other Bluetooth device can connect to your system, that means it is working properly.
However, let me gather more details for me to provide some recommendations.
Michael L.
Hallo Michael,
it is not a Laptop, it is a workstation with a main board from Asus. I think you will find the informations you need in the Log-file.
I agree that the blutooth hardware works fine. The problem seems to be a "protocol" issue. With the update in august/september security-relevant things may have been changed that now require a different pairing procedure (how I interpret the error message).
Attached is the log file from the SSU tool. I hope it provides some clues to the problem.
Best regards and thanks a lot for your help.
Thomas
L'assistance à la communauté est fournie du lundi au vendredi. D'autres moyens d'entrer en contact sont disponibles ici.
Intel ne vérifie pas l'intégralité des solutions, y compris, entre autres, les transferts de fichiers qui peuvent avoir lieu au sein de cette communauté. Intel décline donc toutes garanties explicites et implicites, y compris, sans s'y limiter, les garanties implicites de qualité marchande, d'adéquation à un usage particulier et de respect des droits de propriété intellectuelle, ainsi que toute garantie découlant des performances, des transactions ou de l'utilisation.
Pour obtenir des informations plus complètes sur l'optimisation des compilateurs, voir notre Avis d'optimisation.
