Wireless
8910 Discussions
Bluetooth not working
kinyuasmKE
my bluetooth icon is missing, cant find bluetooth in device manager even after re install of drivers. I have tried everything even clean install of OS.
AlHill
Which bluetooth?
[If you find any Intel driver you might need, download and save it now.]
kinyuasmKE
my pc is dell xps13,windows 10
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
kinyuasmKE
i have attached the intel support utility report
LeonWaksman
kinyuasmKE
still nothing,no solution seems to work at this point.
RamyerM_Intel
Hello kinyuasmKE,
Thank you for patiently waiting and for engaging with our fellow community members! I can see that you have an issue with the Bluetooth of your Intel(R) Dual Band Wireless-AC 8265. Since you have already tried updating your drivers and clean install of the Operating system, you may try following this steps instead:
  1. Run and install a Windows update.
  2. Check for latest firmware and the latest windows version.
  3. Reset default settings of BIOS.
  4. Perform a Complete Powercycle
    1. Shut Down the whole system
    2. Unplug the power cable from PSU power supply
    3. Hold down power button for 60 seconds.
  5. Boot the system.
Let us know if this works. I will be waiting for your reply. You may also visit this article as a reference of this steps: Bluetooth* Adapter Not In Device Manager.
Ramyer M.
kinyuasmKE
still nothing, I think  I will just leave it since no solution seems to be working. Thanks for the help.
RamyerM_Intel
Hello kinyuasmKE,
I am sorry to hear that the issue still persists. Since this is an OEM (Branded Laptop) original equipment manufacturer device, please take into consideration that our support may be limited since we are not familiar with the technology, settings, customizations, custom drivers, and features that the OEM has designed and installed your system. Since the troubleshooting did not work for you, I highly recommend reaching out to your Original Equipment Manufacturer, which is Dell, as they can investigate and suggest a more in depth troubleshooting of your system.
Ramyer M.
