Wireless
7469 Discussions
Can Not Connect to WiFi with Intel WiMAX 6250
I have a Toshiba Satellite A665. The wireless card/adaptor is a Intel Centrino Advanced-N + WiMAX 6250.
I installed the 'Intel PROSet/Wireless WiMAX Connection Utility. When I start the utility, though, it only gives me the option of searching for WiMAX networks.
I can not get an option to search for my own wifi.
I have turned WiMAX off, then right-clicked on the Utility icon in the taskbar. It does not give me a "Turn wifi On/Off" option as described in the instructions I found in the product's help file.
I believe that when I first installed the software, it asked me to select wifi or WiMAX. I have removed and reinstalled the drivers/software and done a system restore to before the software was even installed, but it still will not give me that option again.
Any help is appreciated.
Hi Jeff,
i think it's a matter of using the correct software version. Here are 2 versions you may try.
here's the link to download driver and proset utility
1. Toshiba website - http://aps2.toshiba-tro.de/wlan/?page=downloads Toshiba Wireless Connection Portal:
2. Intel website - http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Wireless+Networking&ProductLine=Intel%C2%AE+Centrino%C2%AE+Wi-Fi+Products&ProductProduct=Intel%C2%AE+Centrino%C2%AE+Advanced-N+%2b+WiMAX+6250&ProdId=3199&LineId=1784&FamilyId=1783 Download Center
Hope it works
Thank you for your post Jeff.
From your description it appears that you only installed the WiMAX portion of your wireless + WiMAX adapter. To download the drivers and software for the Wireless portion of your adapter click on the appropriate link below:
For Windows* 7 32 bit, download Wireless_15.2.0_s32.exe for Windows* 7 64 bit download Wireless_15.2.0_s64.exe from here:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3199&DwnldID=21560&ProductFamily=Wireless+Networking&ProductLine=Intel%C2%AE+Centrino%C2%AE+Wi-Fi+Products&ProductProduct=Intel%C2%AE+Centrino%C2%AE+Advanced-N+%2b+WiMAX+6250eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3199&DwnldID=21560&ProductFamily=Wireless+Networking&ProductLine=Intel%C2%AE+Centrino%C2%AE+Wi-Fi+Products&ProductProduct=Intel%C2%AE+Centrino%C2%AE+Advanced-N+%2b+WiMAX+6250eng
For another Operating System click on the link below and select the Operating System on the top you would download "Intel® PROSet/Wireless Software and Drivers for Windows XX*:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Wireless+Networking&ProductLine=Intel%C2%AE+Centrino%C2%AE+Wi-Fi+Products&ProductProduct=Intel%C2%AE+Centrino%C2%AE+Advanced-N+%2b+WiMAX+6250&ProdId=3199&LineId=1784&FamilyId=1783 http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Wireless+Networking&ProductLine=Intel%C2%AE+Centrino%C2%AE+Wi-Fi+Products&ProductProduct=Intel%C2%AE+Centrino%C2%AE+Advanced-N+%2b+WiMAX+6250&ProdId=3199&LineId=1784&FamilyId=1783
I hope this helps, best regards.
