Wireless
8310 Discussions
Can i start wirtual wifi router on my Intel(R) Dual Band Wireless-AC 3165?
User1577556761557646
LeonWaksman
  1. Are asking if you can use your WiFi adapter as hot spot?
  2. If is that what you are asking, the answer is yes. For example if your O.S. is Windows 10, open Settings, Network & Internet > Mobile Hotspot, Share my Internet connection with other devices set to ON. Choose Share my Internet connection over WiFi.
Leon
Yes, i asked about using wifi adapter as hot spot. The problem lies in error "The hosted network couldn't be started.
The group or resource is not in the correct state to perform the requested operation" after typing "wlan start hostednetwork" in my command prompt. But as far as I understand it appears because i'm using PPPoE, not because wifi adapter problem (my OS is Win10).
LeonWaksman
Unfortunately i can't because "Mobile hotspot" partition in settings is inactive (look at screenshot). Approximate translation of red text: "Failed to configure mobile hotspot because on PC not established connection to Ethernet or Wifi network or connection for data transfer".
LeonWaksman
Although you are connected to Internet trough Ethernet cable, connect your PC to Internet also with Wifi. Only then switch the Mobile Hotspot to ON.
Leon
I can do this but then i will share internet from wifi connection. I need to share internet from ethernet cable.
LeonWaksman
One more question: were you connected to Internet in any way when you tried to switch the Mobile Hotspot to ON? I'm asking, because on the attached image, I can't see any network ID below the "Share my Internet connection from"
Leon
Yes, i was connected via ethernet cable. I searched some information about this and as far as I understand Win10 does not see this connection because this is PPPoE connection.
I found solution: NoWifi app in Microsoft Store helped me to start hotspot.
LeonWaksman
I'm glad that your problem is solved. Thank you for informing about the solution.
Leon
