Wireless
7448 Discussions
Can't update bluetooth drivers on Intel 7260-N card
GDuru
I have a Lenovo U430 Touch laptop with an Intel 7260-N WiFi&BT combo running Win 8.1. I'm stuck with Bluetooth driver 17.0.1405.0464. I tried updating it to the last 2-3 versions, installation works just fine but driver version does not change even after reboot. I tried uninstalling the driver in Device Manager, repairing installation and removing the driver using Intel's driver menu, still stuck with this version. Any ideas on how to update this stubborn driver?
Kevin_M_Intel
Hi waves,
I am sorry you are having this problem but let me help you.
I would like to know some more information about the issue you have so can you provide the following?
  1. If I understand correctly you are installing version 7.1.1406.01 but device manager reflects version 17.0.1405.0464? Is this correct?
  2. Have you tried running all windows updates?
  3. Is your computer running with the latest BIOS update?
Kevin M
GDuru
  1. If I understand correctly you are installing version 17.1.1406.01 but device manager reflects version 17.0.1405.0464? Is this correct? --- Yes
  2. Have you tried running all windows updates? - Windows is up to date.
  3. Is your computer running with the latest BIOS update? - Running latest BIOS.
Kevin_M_Intel
Thanks for the information. Can you please provide your dxdiag report and the MSINFO32? Please attach both documents.
Kevin M
GDuru
I don't see a way to attach files to this post.
GDuru
I shared the files with you Kevin.
GDuru
Any news?
Kevin_M_Intel
Hi waves,
I am sorry for the delay. I have not received the information but you can do the following to attach it here:
1. Click on Reply and use advanced Editor:
2. Click on Attach:
Kevin M
GDuru
Kevin_M_Intel
Hi Waves,
Thank you for the information.
I recommend you uninstalling again completely the driver you currently have (both Wireless and BT) and the install the Wireless driver first:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24170 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24170
After that, try installing the BT driver at this location:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24189 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24189
Try this again and let me know.
Kevin M
GDuru
The links you sent are for Windows 7 drivers and I'm running Windows 8.1. Are you sure you want me to install Win 7 drivers on Win8.1?
