Wireless
8626 Discussions
Can't use Wi-Fi 6 with Intel AX200
GN2150
I have a laptop with Intel AX200 Wi-Fi 6 card and a Wi-Fi 6-capable wireless router, but my connection is always stuck in Wi-Fi 5 (802.11ac) mode.
Laptop: HP ProBook 455 G7
Latest BIOS 01.10.00 Rev.A, released in August 2022 (I couldn't find any dedicated settings for Wi-Fi 6 in BIOS)
Windows 10 21H2 with all updates installed
Intel AX200 driver 22.170.0.3 from Intel Download Center, installed manually
802.11ax support is enabled in driver settings by default
Router: Keenetic Giga KN-1011 with MediaTek MT7915 Wi-Fi chipset
Router firmware: v3.8.5, released in September 2022
802.11ax is enabled for both 2.4GHz and 5GHz access points
As far as I'm aware, certain features of Intel Wi-Fi cards (such as Wi-Fi 6 support) can be enabled/disabled automatically based on the geographical location.
I live in Ukraine. Is there currently some restriction in place that's preventing the use of Wi-Fi 6 with Intel AX200 in Ukraine?
I don't know how to check what region my AX200 is currently set to.
DeividA_Intel
Hello GN2150,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello GN2150,
Thanks for your patience. I would like to let you know that the Intel® Wi-Fi 6 AX200 (Gig+) only support wifi band 2,4GHz and 5Ghz, Wifi 6 is the name and makes reference to AX protocol. I also noticed that the router information only mentions 2,4GHz and 5Ghz.
The ones that support the 6GHz band are WiFi 6E products. Please let me know if you are trying to connect to the 6GHz band or if you are having issues with the AX connection on the 2,4GHz and 5GHz bands.
Deivid A.
GN2150
I know that none of my devices support 6GHz.
I am having issues with the AX connection. My laptop always uses 802.11ac (Wi-Fi 5) instead of 802.11ax (Wi-Fi 6) when it connects to the access point.
I've seen other people report the same problem (sometimes with the explicit mention of Ukraine), and even third-party software that's supposed to fix it (which I did not try, since it's only available on Linux).
DeividA_Intel
Hello GN2150,
Thanks for the response. Before we continue further, I would like to confirm the following:
1. When you mentioned "Wi-Fi 5", do you mean the 5GHJz band?
2. Just to confirm, can you connect to the 2.4GHz and 5GHz with the 802.11ax?
Deivid A.
GN2150
1. Yes, I mean 5GHz band.
2. I just tested it again. It seems like I can connect to 2.4GHz with 802.11ax. But I can not connect to 5GHz with 802.11ax - my laptop uses 802.11ac instead.
DeividA_Intel
Hello GN2150,
Thanks for the confirmation. Before we continue further please provide the report from the Intel® System Support Utility (Intel® SSU) to investigate this behavior with your wireless adapter.
Also, you may need to contact the router/modem manufacturer since some of them can limit the features or connection on their products.
Deivid A.
DeividA_Intel
Hello GN2150,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello GN2150,
I was checking your thread and see that we have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
I recommend you check with HP to confirm if they placed any limitations or restrictions on their laptop.
Deivid A.
