Wireless
8663 Discussions
Cannot utilize N / slow / disconnects (Intel 6200, Intel WiFi Link 4965AGN, Linksys WRT150N)
ZGods
Sorry for the odd title... I was trying to grab every buzz word I could for searches because I've seen a lot of these type of threads floating around the internet. This thread was originally posted in a different forum, but I'm trying to get more visibility for it.
**PLEASE READ THE WHOLE POST BEFORE COMMENTING!!!**
I've gone through a gauntlet of trials among 3 different computers and multiple networks, so I'm guessing I've already tried the majority of what would be recommended out of the box.
Previous research:
- (6200 N) http://slickdeals.net/forums/showthread.php?t=2322493 http://slickdeals.net/forums/showthread.php?t=2322493
- (4965AGN) http://slickdeals.net/forums/showthread.php?sduid=325585&t=2169734 http://slickdeals.net/forums/showthread.php?sduid=325585&t=2169734
** Symptoms ******************************
Affected cards:
Intel Wireless WiFi Link 4965AGN in Vista business 32x (in a Dell 1720 Inspiron [old lappy])
Intel Centrino Advanced-N 6200 in Windows 7 Home Prem 64x (in a Dell 1747 Studio [new lappy])
On ANY NETWORK, when N is enabled, these cards operate cripplingly slow (0.5-0.7 Mb/s down on speedtest.net). This causes extremely slow streaming (youtube, mp3s, poor bitrate when streaming movies to peripherals like xbox or ps3), and can cause disconnects/timeouts in games (League of Legends would always disconnect from pvp.net, persistent games would timeout and drop me).
Unfortunately I have not cataloged the routers of all the networks I've been on, but I have played around a lot with my Linksys WRT150N.
** Temporary Solution ************************
Disable N
I don't like this as a solution, but it's the only thing that I've seen work. If the router is in Mixed mode (N is enabled) and the lappy in question is in 802.11n mode, it will be crippled. If EITHER the router is in G, or 802.11n mode is disabled, it will operate great at G speeds (10 - 13 Mb/s on speedtest.net). If the router is turned to N, the lappy will simply not connect.
ALL OTHER TWEAKS have had marginal success/failure. Nothing else effects the speed difference like taking N out of the equation.
Other notes:
Router:
- PSK2 Personal/AES security
- Beacon Interval to 75
- Thresholds @ 2304
NIC:
- Power management - Do not allow device to turn off
- 2.4ghz - Auto
- 5.2ghz - Auto
- Ad Hoc Channel - 1
- Ad Hoc QoS - WMM Disabled
- Fat Channel Intolerant - Disabled
- Mixed Mode Protection - CTS-to-self
- Roaming Aggressiveness - medium
- Transmit Power - Highest
- Wireless mode - a/b/g
** Options Tried ****************************
Testing
- speedtest.net
- Set up iperf on a working machine as server, client on the 6200 N machine to monitor network.
- Checked packet delivery times in HttpFox
- Monitored connections to games/media (League of Legends, Alien Swarm, Borderlands, facebook game load times, youtube downloads)
- Monitored Link Speed - 54Mbps in G, 1-270 changing at an extremely volatile rate in N
Settings:
NIC:
- 802.11n mode disabled (NIC) - WORKS
- Messing w/any of the other NIC settings - Minimal/no difference unless Router is in G
- netsh int tcp set global autoconfig=disabled
- Updated to 13.3.0.24 64-Bit
Router:
- In G - WORKS
- In Mixed B/G - WORKS
- N - DOES NOT CONNECT
- Mixed, 40mhz wide, different channels - Fails/slow unless 802.11n is disabled.
- Mixed, 20mhz, different channels - Fails/slow unless 802.11n is disabled.
- Mixed, auto/auto - Fails/slow unless 802.11n is disabled.
- Mixed, Disabled wireless security - Fails/slow unless 802.11n is disabled.
- Checked DHCP Client tables to make SURE only the one testing device was connected to the network (eliminate a/b/g crosstalk problems).
- Updated firmware to 1.01.9 1. Updated to Draft 802.11n version 2.0.
Physical:
- Moved closer to router
- Moved router antennae around
I'm sure there are other things I've tried, but I can't remember them off the top of my head ATM.
I will keep this thread updated so that hopefully anyone who has this problem has a good, central place to come to.
Hi there,
I have the same problem! I have a HP Pavilion DV8200 with an Intel Advanced 6200 AGN network interface card. And a Linksys WRT320N wireless router. The laptop is running Windows 7 x64 Home Premium.
When I set up the router as Wireless-N (802.11n) then the laptop disconnects and I'm not able to reconnect until I set the router back to Wireless-G.
I installed the latest drivers for the NIC (v3.3.0.24), downloaded it from this website. Sadly it doesn't fix it.
I have another laptop a Toshiba Satellite L670-14K with a Broadcom 802.11n NIC wich works perfect if the router is set to Wireless-N!
Help!
Ok, I'm back.
I turned off the wireless security of my linksys router (so no WAP or WPA keys set) and the NIC now seems to connect fine.
But, thats without security, and I don't want my neighbours to use my network!
Router Setup:
Wireless Band: 2.4 GHz
Network Mode: Wireless-N Only
Channel Width: 20 MHz Only
Channel: Auto
Security Mode: Disabled
ZGods
But do you have your NIC 802.11n enabled??
I actually thought you needed to have PSK2 Personal/AES security to even be able to use N.
Hmm... the copy/paste in my previous post did not work as planned. This is how I set up my router:
Channel: Auto
So, security is disabled and it seems to work fine.
And to answer your question; yes, my NIC's 802.11n mode is set to enabled in Windows.
ZGods
I'll give this a try when I get home tonight, but it would still be nice to find a solution that included security... I don't like the idea of having my router open to anyone.
And the best case scenario would involve changes to the NIC only, so that it can operate well on other networks. That's the part that really bothers me about this whole thing. You shouldn't have to change settings on your card to fit w/other networks...
