I plan to quote a customer a desktop sytem using the D525MW board with a 6300 plugged into its PCIe slot. First, is 6300 actually compatible with the D525MW? Second,what is a recommended external antenna compatible with 6300? I plan to use Intel tested InWin case BP655 which advertises "Universal Antenna Module Mounting Hole Ready" under "Rear Ports" and "Antenna Mounting Hole Ready for WLAN Card" under "Features". Thank you for any help!
Did you ever figure out an answer to your question? I'm trying to get a WLAN adapter to work in the D525MW motherboard and so far Intel hasn't helped.
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
Topic Options
