Hi Friends,
I have got a question here regarding LAN / Internet / Wifi
Currently I am accessing internet through network LAN cable (Broadband) and wish to share the internet via Laptop as WiFi so that I can connect my smartphone / tablet to internet. Please help.
I am using windows 7 - service pack 1 - 32 bit in Lenovo T410 laptop model. Let me know if you need further details and share the steps using which I can extract those information from system thanks.
DILIPandey
Microsoft MVP - Excel
- Tags:
- WiFi
- « Previous
- 1
- 2
- Next »
Helo Dilip,
I also feel that Android devices are not capable of obtaining the IP address and hence can not connect to a network, to which I want to connect
Can anyone here check and confirm above statement ?? Thanks.
That is actually not true at all, I use my WiFi constantly when I'm bored and shopping to do a little WaR walking. Also, I have no less than four different network configurations on my WiFi. My work, my home, my neighbors, and another friends hotspots.
I can say with certainty that if your device fails to acquire an IP address, it is device specific. By the way, what device are you using and what version Android OS is installed? I'm happy to scratch around and see what I can dig up for your device.
Have you attempted to use other mobile devices to connect to a shared network - WiFi hotspot?
Jason
Thanks Jason for extending your sincere help here
As mentioned earlier I am using Samsung Galaxy ACE | Model No: GT-S5830 with Android version 2.2.1 | Baseband version S5830DDKC1 | Kernel Version 2.6.32.9-perf root @ SE- S605 | Build Number: FROYO.DDKC1
I did not tried other devices to connect. I am planning to try an iPhone to check if that connects.
Let me know if you need any other details.
DILIPandey
Whoops! Missed this bit! ^.^
Since your phone has WiFi capability, and you have not tried any other devices in your configuration, lets focus on your phone for a minute. What I would like you to do is download a free app called https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer&hl=en WiFi Analyzer. It is a mature app and is very useful for WiFi Analysis. Of course, the visible networks will only be 2.4Ghz networks, but you should still see plenty.
Give that app a try, if you don't see any networks with that app, then let me know.
Jason
Dilip,
The android os isn't able to connect to ad-hoc networks, as some new pieces in ICS doesn't allow it to.
Like Jason suggest, WiFi Analyzer, or even an app called Virtual Router could work for you.
Of course, you will need your ICS turned on, on the physical adapter, once you have an app installed and operational.
Neil
Hi Guys..!!
I am done with my research and found that android devices are not able to connect with ad-hoc networks.. even they do not detect that any such type of network is available to connect.
DILIPandey
Hi Dilip,
I'm sure you'd have done this already, but just incase you might have skipped something, writing it here :
Opening Settings and selecting More >> Tethering and portable hotspots >> Enable 'Portable Wi-Fi hotspot, this goes well with Samsung Galaxy S2 though
For other android devices, you'd need to download an application WiFi Ad Hoc enabler for Android
Refer : http://www.arenddeboer.com/wifi-ad-hoc-enabler-for-android/ WiFi Ad Hoc enabler for Android » arenddeboer.com for more info.
There is another reference I could find, but its for a Tablet. You probably want to give it a try if the above doesn't work though : http://androidtablethacks.com/android-tablet-hacks/how-to-enable-adhoc-wifi-on-android-tablets/ http://androidtablethacks.com/android-tablet-hacks/how-to-enable-adhoc-wifi-on-android-tablets/
Hopes it helps.
Barb from WHUK a http://www.webhosting.uk.com/ Webhosting Company in UK
A update to everyone interested
Copying below portion from my post # 9:-
Just to summarize, I am successful in converting my laptop as router when :-
Internet Source:- Mobile Service provider
Broadcasting Wifi using:- Mobile phone (Samsung Galaxy Ace)
Destination (using wifi in) :- Laptop (Dell XPS L502X)
Result :- Successful
Now I am un-successful when :-
Internet Source:- LAN (office LAN Cable / Hotel LAN cable) with free internet facility
Broadcasting Wifi using:- Laptop (Dell XPS L502X) releasing wifi using Intel My Wifi Technology / tried "adhoc connection" as well
Destination (using wifi in) :- Mobile phone (Samsung Galaxy Ace) / tablets etc
I got access to my office WiFi and now I am successful in relation with above point
Internet Source:- Office Wifi
Broadcasting Wifi using:- Intel my wifi Techonlogy (My Wifi Dashboard)
result:- Successful
As the intent is to use internet on my samsung galaxy ace smartphone, I am successful when I connected my laptop to internet via office wifi and shared internet using intel my wifi technology (intel my wifi dashboard) .. my smartphone recognised that there is a wifi to connect and after entering the required password (which I had configured ), I successfully connected my smartphone to internet and found no issues.
and hence not able to understand.. whey I am not able to do the same when I am connecting my laptop to internet via LAN cable ??
Is there any difference for smartphones to connect when the wifi is being released from laptop when
a) laptop connected to internet via wifi
b) laptop connected to internet via LAN
DILIPandey
Dilip,
I've found the time to do some testing and found that it does not matter if the upstream network is Ethernet or WiFi.
NIC: Centrino N 6300
Phone: Droid X2
MyWiFi Dashboard: 15.2.0
ProSet: 15.2.0
So basically, I installed the software and while connected to the Ethernet LAN shared the network with the Hot Spot toggle. Phone was able to see the network, good! Unshared the network.
Next I unplugged the Ethernet and associated with a wireless AP, shared the network again using the Hot Spot toggle. Phone was able to see the network, good!
The only thing I would expect to cause problems for smartphones is the Wiresless Mode, but this did not appear to be an issue for me.
Did you try virtual router plus?
- « Previous
- 1
- 2
- Next »
