Wireless
8506 Discussions
DRTU 2019 Set Up for Single Windows System with Intel® Dual Band Wireless-AC 7265 Installed
JulietD
Hello!
I have a device I made that operates on Windows 10. I have an Intel® Dual Band Wireless-AC 7265 WiFi card installed onto this device.
I am trying to use the DRTU (2019) application, but I'm having some confusion with the set up instructions.
For the device I have - a single Windows system with the Intel WiFi card already installed - would I be using a local or remote connection?
When I attempt to establish a local connection, I leave the remote ID blank and leave the port as "8751", it says "Unable to connect". Is it possible I should use a different port?
When I attempt to establish a remote connection, there are a few things I need clarification on.
Referring to this photo and the set up I described previously, would my device (that has the Wifi card installed) be the DRTU client? And what would be the DUT? Does the DUT need to be a Chrome machine? There were installation instructions, but I didn't understand what system/device to perform these operations on:
To summarize, if I am using a single Windows system with the Intel® Dual Band Wireless-AC 7265 installed, do I use a local or remote connection? If I am using a local connection, what port should I be using or how can I troubleshoot my current set up? If it is a remote connection, would my device (with the WiFi card installed) be the DRTU client or DUT(server)?
RandyT_Intel
Hello JulietD,
I would like to understand more about the context of your question. Could you please let us know the reason for your inquiry? Specifically, are you reaching out on behalf of a company, or are you conducting some testing for personal or other purposes?
Understanding this will enable us to coordinate effectively with our engineering team and provide the specific support needed to address your issue.
Additionally, we would like to know if you are open to communicating via email. If you agree, I will send you a personal email to ensure we can discuss your concerns more comprehensively.
To summarize your inquiry for clarity:
  • If using a single Windows system with the Intel® Dual Band Wireless-AC 7265 installed, should you use a local or remote connection?
  • If it is a local connection, what port should be used, or how can you troubleshoot the current setup?
  • If it is a remote connection, would your device (with the Wi-Fi card installed) act as the DRTU client or DUT (server)?
Your prompt response will help us in providing you with the best possible assistance.
Thank you for your cooperation.
Randy T.
JulietD
I am asking on behalf of a company. We need to do a compliancy test where we test the Wifi card in constant transmit mode. We were told DRTU could be a good application for this.
The summary you provided is good. I am good with communicating via email.
Thank you.
RandyT_Intel
Hello JulietD,
I wanted to inform you that I have already sent you the information needed for your inquiry. Kindly check your email at your earliest convenience and let me know if you have any questions or require further assistance.
Randy T
