Wireless
8560 Discussions
DRTU and AX210 under Linux throws "WiFi USC and driver are not compatible" Error
apfel
yes, I guess this is because the driver has a different version than the USC. But: where do I get the version of the USC (and the driver) so I can compare them and find the right one, if possible?
If you ignore it and continue another error pops up: "GetChannelRegulatoryInfo failed, channel 36, rate 13, bandwidth 20 MHz, chain 1" which probably is becaue of driver and USC version differences (or I chose the wrong module).
Kernel: 5.15.40
iwlwifi-Version: iwlwifi-stack-dev:tags/jenkins-Core_build_core74_pv-44^0:jenkins-Core_build_core74_pv-60:128e12f4202f
  ( I used core 72-6855 of the backport-iwl-wifi because the kernel 5.15.49 used there was the best match with out kernel 5.15.40)
WiFi-Module: AX210
DRTU-Tools: OEM_DRTU_12504_10_2127_0G
CITU-Tools: OEM_CITU_5579_11_2126_0G
  install.sh ran with
       os_name="linux"
       device_name="hrp"
       mac_type_name="quasar"
       install_rservice="false"
Thanks in advance
Jose_Intel
Hello @apfel
Thank you for posting on the Intel️® communities.
I am sorry to hear that you have problems with Intel® Wi-Fi 6E AX210 (Gig+), and I’ll be more than happy to help you.
Intel firmware/driver is a part of Linux kernel. To obtain latest Intel wireless firmware, please install the latest (and stable) Linux kernel. In this case the version 6.4.4
I will be waiting for your response.
Jose B.
Jose_Intel
Hello apfel
We hope you are doing fine.
Jose B.
Jose_Intel
Hello apfel
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
