I made some changes in Regedit to point to the correct DSAtray.exe location and added it for startup in Task Manager. The icon that used to show in the taskbar no longer shows up even though it is a loaded process according to Task Manager. Version 25.2.15.9. I have completely uninstalled and reinstalled twice, no change to the improper installation of DSATray.exe.
Hello iota2k,
Can you confirm that by uninstalling and reinstalling the DSAtray.exe, these were the exact steps you've tried below? If not, please proceed with the steps:
- Open a new tab on any web browser (Firefox, Chrome, or Edge.).
- Download and run the Intel® Driver & Support Assistant Uninstaller .
- Accept the terms & conditions.
- Click on Next.
- Click on Close.
To address the issue you're experiencing with DSAtray.exe, here are a few steps that you can try:
- Double-check the changes you made in Regedit to ensure that the path to DSAtray.exe is correct. Sometimes, a small typo can cause issues.
- Ensure that DSAtray.exe is correctly added to the startup programs in Task Manager. You might want to remove it and add it again to see if that resolves the issue.
- Try running DSAtray.exe in compatibility mode. Right-click on the executable file, select 'Properties,' go to the 'Compatibility' tab, and choose an earlier version of Windows.
- Make sure to run DSAtray.exe as an administrator. Right-click on the file and select 'Run as administrator' to see if this helps the icon appear in the taskbar.
- Ensure that you have the latest version of the software. Sometimes, updates can fix bugs related to taskbar icons.
- If the issue started after making changes in Regedit, consider performing a system restore to revert to a point before the changes were made. I highly suggest contacting Microsoft team for this.
Source:
How to Uninstall the Intel® Driver & Support Assistant (Intel® DSA)
Hopefully, one of these steps will help resolve the issue with the DSAtray.exe icon not appearing in the taskbar. I will wait for your reply.
JeanetteC.
Here's what the Tray20250429.log shows (I attached a copy) after installation.
04/29/2025 09:17:36.655 -07:00 3244:01 Information DSATray.App InitLogging () Started version 25.2.15.9 { }
04/29/2025 09:17:36.845 -07:00 3244:01 Information DSATray.App InitApplication () Registered notification handlers { }
04/29/2025 09:17:37.804 -07:00 3244:01 Information DSATray.App InitTrayWcfHost () Tray communication WCF service started { }
04/29/2025 09:17:37.831 -07:00 3244:01 Information DSATray.App CheckForNewScan () Setting icon to updates available { }
04/29/2025 09:17:37.831 -07:00 3244:09 Information DSATray.App CheckForNewScan () lastCheckDetails.AvailableUpdates: 1 { }
04/29/2025 09:17:37.832 -07:00 3244:09 Information DSATray.App CheckForNewScan () lastCheckDetails.Notifications (non-event triggered): 1 { }
04/29/2025 09:17:37.832 -07:00 3244:09 Information DSATray.App CheckForNewScan () lastNotifiedTicks: 0 (never) { }
04/29/2025 09:17:37.925 -07:00 3244:09 Information DSATray.App NotifyUser () Notified user: 1 notifications { }
04/29/2025 09:17:37.964 -07:00 3244:05 Error DSATray.App StartShowIconTask () Failed to show taskbar icon: System.Exception: 0: The operation completed successfully.|| { }
04/29/2025 09:21:35.508 -07:00 12080:01 Information DSATray.App InitLogging () Started version 25.2.15.9 { }
04/29/2025 09:21:35.716 -07:00 12080:01 Information DSATray.App InitApplication () Registered notification handlers { }
04/29/2025 09:21:36.605 -07:00 12080:01 Information DSATray.App InitTrayWcfHost () Tray communication WCF service started { }
04/29/2025 09:21:36.624 -07:00 12080:01 Information DSATray.App CheckForNewScan () Setting icon to up to date { }
04/29/2025 09:21:36.808 -07:00 12080:05 Error DSATray.App StartShowIconTask () Failed to show taskbar icon: System.Exception: 0: The operation completed successfully.|| { }
I've been troubleshooting software for almost 50 years. This version of DSA or the installation app is malfunctioning or incorrect. That's it. Used to work, new version, doesn't work.
Hello iota2k,
Thank you for providing the logs. I will investigate the app malfunction internally and update you once I have more information.
JeanetteC.
Hello iota2k,
I'm currently addressing the issue you've reported and need some clarification for the following:
- Where is the Intel DSA located, and what is the incorrect directory location?
- Share the IDSA logs. Refer to our article "How to Obtain the Intel® Driver & Support Assistant (Intel® DSA) Folders?" and provide the logs as you reply. If you're not comfortable in sharing the logs here, I also sent you a private message via email, so you may respond to it and attach the logs. *Please make sure to check your email inbox, as well as your junk and spam folders, as it may go directly to those folders.
I'll be waiting for your response.
JeanetteC.
Hello iota2k,
Thank you for providing the DSA logs I requested regarding this issue. I will continue with the investigation and will share an update as soon as it is available.
JeanetteC.
Hello iota2k,
Please note that this issue is still under investigation, and we kindly request that you share your system configuration to assist with further analysis. You can do this by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
- Scan: Check the box Everything.
- Click Scan.
- Review: When finished scanning, click Next.
- Click Save.
Please attach the SSU log file in your response. I look forward to hearing from you soon.
JeanetteC.
Hello iota2k,
Thank you for providing the log file. I will keep investigating this issue internally and will inform you as soon as we have any new information.
JeanetteC.
Hello iota2k,
Please be advised that I am still currently checking into this issue you've raised. I need help gathering the following details below to be use for further investagation:
- What was the path of DSATray.exe set before trying to update it in the registry?
- What new path was being set in the registry?
- Kindly confirm if DSATray.exe existed inside of your DSA folder "C:\Program Files (x86)\Intel\Driver and Support Assistant\x86" and/or if DSATray.exe was located anywhere else outside of the x86 folder.
I hope to hear from you soon.
JeanetteC.
The files reside in C:\Program Files (x86)\Intel\Driver and Support Assistant\x86
I deleted all the DSATray Registry entries when I reinstalled the software. The only change I made after was to copy the executable files in the x86 folder to the parent directory "Driver and Support Assistant."
I hope you find that helpful.
Hello iota2k,
Thank you for providing this information. I will begin the investigation and will update you as soon as possible.
JeanetteC.
Hi @iota2k,
As of the moment, I am taking over this post to further assist you with your concern. With that in mind, my team would like to get a clarification based on the following points below:
Based on your message, I deleted all the DSATray Registry entries when I reinstalled the software. The only change I made after was to copy the executable files in the x86 folder to the parent directory "Driver and Support Assistant.", I would like to know if you were able to capture the file path before you deleted all the DSATray Registry entries? If so, can you provide the path/s.
I do understand that my colleague was already asked this question. However, for our investigation, I'd like to get clarity on this matter.
Brian T.
I did not save the paths or export the registry because the changes didn't work.
Hi @iota2k,
Thank you so much for sharing these details with me.
With the information at hand, I will get back to you as soon as possible to I've completed my consultation with my team.
Brian T.
Hi @iota2k,
Thank you for your patience.
I have sent an email to the address you used to register in the Intel Community. Could you please check your inbox to confirm receipt?
Once again, I appreciate your understanding and cooperation as we continue our investigation.
Brian T.
Has this issue been resolved, because I have downloaded and installed the Intel Driver & Support Assistant and the icon no longer appears in the Windows 10 Pro notification area, when previously it did? TIA.
