Wireless
8659 Discussions
Do we support BT mesh using wireless AC 9560 chipset?
Wanderzhd
Hi, We are using Intel Celeron 4205U + Intel 9560 2×2ac+BT HW running Ubuntu 18.04 system. From the 9560 spec, it can support BT5.1, here we'd like to check if there is driver update to support BT mesh on Ubuntu. BRs. Dong
Esteban_D_Intel
Hello Wanderzhd,
I would like to share with you the information that I was able to confirm.:
1) The Intel Wireless-AC 9560 should support Bluetooth mesh using standard LE commands.
2) Regarding to your question about How to switch among the three BT modes: Classic BT, BLE, and BLE mesh using firmware only?
I need to inform you that the Bluetooth controller is dual mode device which means we have both Classic and BLE. There is no option to switch, based on Host the controller executes the commands.
I hope this helps to answer your concern.
Esteban D.
Intel Technical Support Technician
Esteban_D_Intel
Hello Wanderzhd,
We understand that you are looking for a driver update for your wireless adapter in an Ubuntu* system.
As you know, Linux drivers are part of the upstream Linux* kernel. They’re available through the regular channels, distributions or the Linux* kernel archives. We support use of the drivers only in the kernel version the driver was a part of.
Please check the table in the following link for a list of supported devices by the iwlwifi driver.
For further information please check Linux* Support for Intel® Wireless Adapters.
Please let me know if the information provided was useful.
Esteban D.
Wanderzhd
Esteban,
Thanks for the quick response!
Let me clarify a little bit more on my questions.
Here is hardware spec. We can use BLE feature well, and we want to enable BLE mesh on this hardware with latest BlueZ stack with BLE mesh feature. BLE mesh mainly is a software feature but still depending on the driver layer.  Is current driver of 9260/9560 ready for BLE mesh?
https://www.lenovo.com/us/en/desktops-and-all-in-ones/thinkcentre/m-nano-series/ThinkCentre-M90n-IoT/p/thinkcentre-m90n-iot
BRs.
Dong
Esteban_D_Intel
Hello Wanderzhd,
Thank you so much for the clarification.
I would like to confirm that information on my side. I will provide an update to this thread as soon as possible.
Esteban D.
Wanderzhd
Hi, Esteban.
Any good news about it? Thanks.
BRs.
Dong
Esteban_D_Intel
Hello Wanderzhd,
Thank you so much for your patience.
I would like to provide an update on the thread and share the following information:
There are 2 design approaches for BT mesh.
1.    Host stack running in the Application process (Host stack shall have the BT mesh implementation)
2.    Host stack running in the Controller(Host stack is offloaded to the controller)
Since in approach #1 there is no dependency on the controller, we can tell BT stack on Ubuntu* using our device should support BT mesh out of the box with design #1, only.
I hope this helps.
Esteban D.
Esteban_D_Intel
Hello Wanderzhd,
Please let me know if you need further assistance.
Esteban D.
Wanderzhd
Hi, Esteban.
Thanks for your follow-up.
We will try it out.
BRs.
Dong
Esteban_D_Intel
Hello Wanderzhd,
Perfect, If you have any update on this matter or additional question please let me know.
Esteban D.
Esteban_D_Intel
Hello Wanderzhd,
Esteban D.
Wanderzhd
Hi Esteban,
As our service layer is using Go, we are still in the progress of bring-up BLE mesh.
Will keep you update. Thanks.
BRs.
Dong
Esteban_D_Intel
Hello Wanderzhd,
I understand; If you have an estimated day for me to follow up please let me know.
If not, just let us know as soon as you have an update and we will be more than glad to continue with the assistance.
Esteban D.
Esteban_D_Intel
Hello Wanderzhd,
Please let us know as soon as you have an update on this matter.
Esteban D.
Wanderzhd
Hi Esteban,
As the Edge hardware is provided by 3rd, we are still working with them on rebuilt the system. It takes time, and I will keep you post.
BRs.
Dong
Esteban_D_Intel
Hello Wanderzhd,
Thank you for your response.
As this process may take several time, I would recommend the following:
We can proceed with the temporary closure of this inquiry, so you will have all the necessary time to keep testing the recommendations provided.
 As soon as you have an update you can post a new question and feel free to tag me to check results on this matter.
Please let me know if you would like to proceed that way.
If not, please provide an estimate date for us to follow up with you.
Esteban D.
Wanderzhd
Hi Esteban,
Currently on our other product, we are using Nordic BT chipset, in order to use BLE or BLE mesh, we have to flash different firmware.
Could you please help on how to switch among the three BT mode: classic BT, BLE and BLE mesh using one firmware only, before we proceed with the temporary closure of this inquiry?
BRs.
Dong
Esteban_D_Intel
Hello Wanderzhd,
I am currently verifying that information for you.
I will provide an update as soon as possible.
Esteban D.
Esteban_D_Intel
 Hello Wanderzhd,
I’m still working on getting this information for you.
In the mean time can you please confirm the following:
  • Can you please provide more details about the Bluetooth product that you are developing? Any further detail will help.
  • What is the purpose to enable the Bluetooth mesh in this environment.
We will be waiting for your response.
Esteban D.
Esteban_D_Intel
 Hello Wanderzhd,
Were you able to check the previous post?
Esteban D.
Wanderzhd
Hi Esteban,
Please see below comments:
  • What is the purpose to enable the Bluetooth mesh in this environment.We have a lot of sensors using Nordic nRF52840 chipset and these sensors are using BLE mesh, now we'd like to use Edge gateway(using AC9560) as a mesh node to gather all the sensors data and send them to our cloud platform.
BRs.
Dong
Esteban_D_Intel
Hello Wanderzhd,
We really appreciate your response.
If you have an update after the recommendations provided, please let us know.
Thank you for your patience on this matter.
Esteban D.
