Wireless
8527 Diskussionen
Does MLO of BE200 work on ubuntu 24.04
Zack1991
Einsteiger
739Aufrufe
Dear Developers,
I installed a be200 on Ubuntu 24.04 system, and would like to use it to test Wi-Fi 7 MLO feature with an Wi-Fi 7. However I didn't see any multi-link information from iw commands.
Here is my kernel version and firmware details for you reference. Could you please help to confirm if I am running on the correct kernel and firmware? Thank you~~~
kernel:
6.12.6-zabbly+
BE200 firmware:
description: Ethernet interface
product: Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlp2s0f0
version: 1a
serial: c8:8a:9a:52:28:df
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical
configuration: broadcast=yes driver=iwlwifi driverversion=6.12.6-zabbly+ firmware=92.67ce4588.0 gl-c0-fm-c0-92.uc ip=10.0.0.50 latency=0 l ink=yes multicast=yes
resources: irq:16 memory:b1500000-b1503fff
1 Antworten
Zack1991
Einsteiger
606Aufrufe
Does anyone have experience on this topic?
Antworten
